My laptop does not recognise my external hard drive due possibly to slight water spillage Model No. sde3275xc/97
  • 6,993 Answers
Hello, welcome to Fixya!
Which of the two did the water spill on, it is the external hard drive or the laptop?
Which ever the case may be, the water needs to dry up completely for it to work well again. Keep near heat, after heating, allow it to cool before connecting the laptop and the external hard drive together again.
If the laptop still doesn't recognize external hard drive after heating/drying it, connect the external drive to another computer and observe if it's going to work perfectly on that computer.
Which ever the case ma be, here is what you need to do on your computer;
Insert the external drive into your computer
Go to device manager.
Go to the name of the external drive.
Right click on the external drive and click 'Uninstall"
Allow the external drive uninstall from your computer.
If possible uninstall every other device under the "Universal serial bus controller (usb).
Once this is done, disconnect/remove the external drive from your computer.
Restart your computer.
Wait a while for the computer to boot computer. Also whatever you have uninstalled from the device manager, might install automatically. Which ever the case maybe, make sure your computer has finished booting or installing any device before you attempt to insert the external drive into the usb.
Now insert the external drive and wait for the computer to install the external drive, then observe if it will open this time around.
By now it should open. But if it doesn't open, please let me know so that I may direct you further on what next to do.
I wish you good luck.
Regards.
Posted on May 22, 2011
I've got a samsung m3 portable that has suddenly stopped being recognised
it is not uncommon for external hard drive enclosures to fail. If its not working on multiple computers, this is probably the case. try it in 1 more computer and if it still doesn't work, I would do the following:
1. Open the enclosure to expose the actual Hard Drive and obtain the model number and note the size. if its a laptop hdd, its 2.5". if its a full size hdd like in a desktop pc, its 3.5". the enclosure may be screwed together but likely snaps together.
2. Google the model # to determine the interface and speed (likely SATA 3.0gb/s but could be SATA 6.0gb/s
3. Go to Newegg.com or Amazon.com and buy a new external hard drive enclosure ($5-$35) with the same interface, speed, and size as your hdd (use the filters on the left to narrow your search)
Home Computer Hardware Computer Cases External Enclosures
4. Put your hdd in the new enclosure and check if its working.
Mar 07, 2014 | Computers & Internet
My Toshiba px1394u-3g50 external hard drive is not working, light flashing and not recognised
Try connecting the hard drive to some other laptop and see if its getting recognized. Issue could be either with the hard drive itself of it could be with the usb port which you are using to connect the hard drive to your laptop.
Jan 17, 2012 | Computers & Internet
My laptop doesn't recognise external hard drive
Most Windows versions:
Go to the diskmanagement (run compmgmt.msc) option Disk management.
Locate the drive and add a driveletter.
If the drive is not shown in the list, you need to check your USB drivers or connectors.
Jan 15, 2012 | Medion Computers & Internet
Seagate external HDD used on XP 32 bit laptop, device not recognised on new Win 7 64 bit laptop.
It may be that you need a driver for that particular external hard drive.
Visit: http://www.seagate.com/www/en-us/ and search for your specific model and see if a driver for 64-bit Windows 7 is available.
Sep 04, 2011 | Computers & Internet
My HP DV9740Us entertainment laptop will only recognize one external hard drive at a time! If i plug in another via usb it won't pick it up in My computer but the computer makes the sound as if it did...
If these drives are internally powered by the USB hub, two devices will not be recognised. ie: you can have as many pendrives as you like and they will be seen, because they draw little power from the hub, however, a larger external hard drive requires more power (some of these in fact have two usb connectors to power them). which is why your laptop will only recognise one drive at a time:
Solution: If you can get an externally powered usb drive, this should work.Another and possibly cheaper way would be to get an externally powered USB hub, which would solve the problem
Jul 28, 2011 | HP Pavilion DV9740US Laptop
Hi I own a Samsung G3 Station External Hard Drive 2T. It was working completly fine, however just recently its screwed up. I have tried using it on all my computers and laptops.. but for some reason...
Your external drive may not be coming up due to a defected usb adapter, this might also explain why your computer fails to recognize the device. Try getting a new adapter and see if that works
Jun 16, 2011 | Samsung G3 Station 1.5TB USB 2.0 External...
Hi, Thank you for email . I have a small Philips 250gb external hard drive model No. sde3275xc/97. It came into contact with some water 2 days ago and since then my laptop does not recognise it. It is not...
It's possible that a harddrive coming into contact with water would no longer be usable. You can have a professional recover the data, if the data on the device is important. Please check the info below:
http://www.ontrackdatarecovery.com.au/top-four-data-loss-tips/
You can also try placing the harddrive in a bowl of uncooked rice overnight. The uncooked rice will absorb the moisture from the device. Although I cannot guarantee this fix as its possible that water may have damaged the harddrive.
May 22, 2011 | Philips Computers & Internet
Its worked great for months on my laptop on vista, today my friend borrowed it to watch a movie on her laptop, using windows 7, she watched 2 movies, unplugged it, and ever since then its not being...
you have to "stop" external drives under "safely remove hardware" or they can possibly be damaged. if the data is very important, it *may" ber possible to take the hard drive out of the case, and install it in a new hard drive case. this might work, depending upon the type of hard drive. they doi sell external hard drive kitxs in stores, but you have to know if it is a PATA or SATA hard drive. SATA is the newest, and likely any external drive from the past 2 years will be SATA.
Mar 08, 2011 | Computers & Internet
External Hard Drive not recognising music files
Before opening the external hard drive, try auto playing the external hard drive, usually auto play recognizes the music files and asks u if u want to play it or not
Nov 21, 2009 | LG 10X DVD IDE 452000078
Computer cannot recognise the hard drive ;
inside there is a usb and data port attache in hard drive. some time thise port may be damage and also usb cable which we connect on computer may be damage. we came to know after changing two thing ,change one by one to check,
Sep 30, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
20 people viewed this question
 Grubhead
Grubhead
