Question about ASUS P5LD2 Deluxe Motherboard
Asus p5ld2-v motherboard
Fault no1 system froze then would not work with sata drive fitted paralell drive fitted ,computer now works.but intermittent boot up (computer has mind of its own).bios upgrade has been applied still the same,cant understand why it wont work with sata drive. thank you email venus_jim29@hotmail.co.uk
Har ikke sett manual ennå/ trenger også bedre bilde av
Posted on Nov 17, 2008
Unable to use S-ATA on Asus P5LD2-VM
in the BIOS set the SATA controller to IDE this should fix the problem. And try with AHCI selected.
Apr 16, 2013 | ASUS P5LD2-VM Motherboard
P5ld2-vm/s mother board lan drivers
i have a LAN Driver of model no. p5ld2-vm/s is the branded computer of HCL, that motherboard name is ASUS
Mar 23, 2010 | ASUS P5LD2-VM Motherboard
IDE Ports not working on ASUS P5LD2-VM Mobo
Good Day sir, hi, Have you tried to enable the IDE on BIOS setup. If the Bios setup did not solve the IDE problem, check the IDE port of the HARD drive, check if there are bent pins.
If still wont work, you can buy a PCI to IDE/SATA card, this is an expansion card in PCI format with IDE and SATA port.We use this card incase the IDE or SATA on the motherboard gets bad. Connect it on the available PCI slot. Then connect the IDE cable of the Hard disk to this card. Thats it.
Nov 10, 2009 | ASUS P5LD2-VM Motherboard
Our system has an IDE drive that runs the machine but i have just connected a new sata drive and the machine does not see it, motherboard - ASUS P5L02-VM and hardrive - Seagate 1.5TB
Did you switch the pins in the back of the new drive from master to slave? If you have them set both to master, you might have conflict. good luck
Sep 03, 2009 | ASUS P5LD2-VM Motherboard
My cpu dont see new hdd wd5000avvs ,motherboard Asus P5LD2 SE. i trying omost everything. help;/
are you using ide or sata connection? if your using sata conection between your motherboard and harddrive, you must enable it in your bios, just reboot your pc and keep pressing F2 while its booting to prompt your bios. There you can look for IDE/SATA configuration. After enabling your sata, save any changes before you exit and reboot... Just give it a try...
Jun 22, 2009 | ASUS P5LD2-VM Motherboard
ASUS P5LD2 Raid 5 locks windows at MUP.SYS
A stab in the dark. Sound like the MB BIOS expects and is written to have the OS on the  IDE  slot. After that I would add one SATA drive at a time to see if it matters and to see if one of the drives are causing the problem.
Jan 05, 2009 | ASUS P5LD2-VM Motherboard
Sata hard drive
Check to see if your motherboard has a sata controller on it. The user manual will tell you. You can get a new on on asus.com. If it does support it, you will need sata drivers for it which you can download from the website as well.
If it doesn't work you can add one external by picking up and external drive case for sata controllers. Then all you need is a spare USB 2.0 port. Make sure you get one with a power supply for it because at that size getting 500 gig to work will require extra power to perform properly.
Aug 05, 2008 | ASUS P5LD2-VM Motherboard
Ide problem
just set the sata as first boot hard drive in your bios then connect the other drive :- )
Nov 11, 2007 | ASUS P5LD2 Motherboard
SATA II HDD instaling on ASUS P5LD2
No but you need to ensure that the drivers for your SATA controller are installed correctly (as they probably are not installed) http://uk.asus.com/products1.aspx?l1=3
Oct 25, 2007 | ASUS P5LD2-VM Motherboard
ASUS P5LD2 Deluxe Motherboard Logo
147 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
