SOURCE: TC-P42C2 Power Indicator
Power LED light indicator are flashing it is the effect of the power supply board are dying and not giving the tv the wright amount of voltages anymore.That the board,where the power a/c cord plug into it.U have all the tools,u understanding basic electronic also can u do basic soldering?Yes,check all over the power supply board for dying parts call capacitors.These dying capacitors are alway bulges up or puffing up on to it tops.By replacing all these dying capacitors are bulges or puffing up on it tops,will solved this flashing LED power light indication,power supply board will work again.Or try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
SOURCE: my TV just turned off and the power light flashes
thought I would post this here for everyone.
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
SOURCE: Panasonic TC-P58S1 won't come on,
Hi Volvo2001,
1 blink is an "unknown SOS" error code sensed by the processor upon self check. Most of this fault came from bad power supply and the caused was the leaky/dried filter electrolytic capacitor in that board. It will dropped the supply voltage and will disable the unit. Plasma TV is the most hardworking TV's nowadays and work in high temperature most especially the power supply board which causes the capacitor to fail after about 2-3 years.
Leaky capacitor has a physical indication of fault like bulged/dome at the top and can be easily be identified by visual inspections. See sample picture of electrolytic capacitor with bulged/dome at the top.
Dried capacitor has no physical indication of fault, you must have a capacitor checker to determine its condition or you may replaced all of them in the output stage. It will not cost you much since this parts is one of the cheapest parts in your unit (price depends on the capacitance and working voltage ratings that is printed on its body).
Click this "Sample Video" "Sample Video" for more info.
You may open the back cover of the unit and check this parts in the power supply board where the power cord is directly connected. Look also for bad solder joints(cracked/dried/cold solder).
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to look for a qualified tv technician or sent it in.
Also, check if your unit is still under warranty/extended warranty, avail it because the manufacturer will fix it for free. Don't attempt to open the back cover because it will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
SOURCE: Power won't come on but red light flashes 7
This problems is common for this tv.The power supply board is the causes and the problems alway for this tv model and make.Try website like Ebay.com to buy a whole refurbish power supply board for the replacement
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there.
