Question about Spectra Hello Kitty Digital Alarm Clock & Night Light
Change light bulb in night light for Hello Kitty LED Digital alarm clock, Model NL-HKC 206, does the top pull off where Hello Kitty and base meet? Unfortunately purchased this 2nd handed and it didn't come with a manual. Thanks
  1. change light bulb in night - j23lynne.jpgjames carl
Posted on May 22, 2011
  • gaga2dwyanea
    gaga2dwyanea Jan 08, 2012
    don't understand why this pic is listed as a solution to the question.............
How do you turn off the Alarm on HELLO KITTY CLOCK KT2052P
To disable the either alarm press and hold the ALARM 1 or ALARM 2 button for 2 seconds. The ALARM 1 or ALARM 2 indicator will show when the alarm is active.
Mar 21, 2015 | Audio Players & Recorders
How do you set time and alarm?
If you unplug the clock, then plug it in again, the time should blink. Then you can use the volume buttons to set the hour. Press the Time button after the hour is set and the minutes will start blinking. Follow the same procedure to set the minute.
I have not figured out how to set the alarm time yet. Hope this helps.
Jan 06, 2014 | Hello Kity Hello kitty kt2052 sleeping...
I need help setting the alarm on my radio controlled digital clock.
1- Turn over your Seth Thomas digital clock. Use your finger to remove the cover to the unit's battery compartment. Insert two AA-size alkaline batteries into the battery compartment and replace the cover. Certain Seth Thomas digital clock units will also have an optional alternate power source in the form of a standard AC power cable that plugs into a wall outlet in your home.
  • 2 Place your Seth Thomas solar-powered digital clock in front of a light source, such as on a window sill or beneath a lamp. The black strip on the top of the unit is the solar sensor, so as long as light is shining down on that strip, your clock will be powered on and ready to use. The sensor stores energy throughout the day so that it can work at night with no direct light contact on the sensor.
  • 3 Press the time zone button that indicates your current time zone. These buttons are located on the back of the unit. For example, if you are in the eastern time zone select the "EST" button. Turn the unit back over. It will now be displaying the correct time on its digital screen.
  • 4 Use the "Alarm" switch (if applicable) to enable and disable the clock's alarm. Press the "Alarm" button, followed by the "Hour" and "Minute" buttons, to set the appropriate alarm time based on your needs. Use the "Alarm HI LO" switch to set the volume for the alarm.
  • 5 Press the "Weather" button to tune your Seth Thomas digital clock to its built-in local weather radio station (if applicable). Certain Seth Thomas clocks have this radio weather functionality built in, while others don't. If yours does, the aforementioned "Weather" button will be located on the front of the unit.
  • May 28, 2011 | Seth Thomas Radio-Controlled Howard Wall...
    Is it possible to replace the light on the Timex T 301B and if so, how?
    Yes the lights can be replaced all you have too do is open up the unit locate the led bulbs which serve as the light for the unit and unsolder them and put in replacements.
    But mostly led bulbs are quite difficult to become faulty as they contain few components which make them difficult to become faulty. So instead of replacing the lights get an expert to trace the power source if the lights are bad and check where the inconsistencies are from a the lights are still likely to be good.
    hope this solution has been helpful?
    Apr 10, 2011 | Timex Auto-Set Dual Alarm Digital Clock...
    You lift the Kitty up off of the base and take a butter knife and gently push on the plastic prong on the inside. It is held in place by 4 prongs. The plastic kitty should come right off and there is a small globe that has one screw. Unscrew the globe and replace the light. The light is super small so you might want to go to the store after you have the light bulb out. Hope this helps!! :-)
    Feb 20, 2011 | Spectra Hello Kitty Digital Alarm Clock &...
    The light on my digital clock went out. how do i replace the bulb
    Check for a fuse first . if no fuse replace the clock. digital are LED no bulbs to change.
    Jan 12, 2011 | 2004 Mitsubishi Galant
    I need a I/R setup for these binos...do you have pr can you tell me where i can get one...thanks
    Hello, contact Night Vision Optics they should be able to get you one. You can make your own by using an head light. Get an IR bulb, or change the lens to IR lens. If you want to high tech then get head light will IR LED's. If the white LED's are used don't use IR lens over this white LED's because of the light spectrum is different for the the LED's than incandescent light. They will have to be changed IR LED's..GB...stewbison
    Jan 09, 2011 | Kalinka Baigish 12 Russian Night Vision...
    Fast blinking led indicator on dimmer switch. lights won't turn on. connected to chandelier. changed out all bulbs and now bulbs and indicator blink very fast.
    Which product is this (the one pictured doesn't have an LED indicator on it)?
    I would call their tech support number 1-800-523-9466 to diagnose (available 24/7).
    I suggest this because I can think of a few possibilities (is it a dimmable load or a non-dim CFL - is it an LED load that might not meet the minimum load requirement)? And I think the answer will differ based on what product you're using - do you have a model number of what product it is?
    There's more answers that are needed to diagnose, so I would call tech support.
    Oct 13, 2010 | Lutron 600-Watt Incandescent Dimmer Switch...
    Would like to switch off clock light, esp at night, or even permanently
    Proceed at your own discretion, this will void your warranty. This worked with my Model 3 clock radio:
      1)Remove the four corner screws on the back panel with a long phillips screwdriver.
      2) Do not remove the two other screws on the back panel.
      3)Gently pull the front panel forward, sliding it out of the wooden case leaving the back panel in place. You can pull of the front panel just free of the case and lay it flat before the connected wires are taught.
      4)Unplug the 7 wire harness leading to the back of the clock.
      5)Separate the brown wire from between the black and red wires to make room to cut, or modify it.
      6)The brown wire is the lead wire to the LED light on the clock. To permanently disable the light, cut the brown wire. Better yet, install a switch in line with the brown wire, which I have not attempted yet and is not covered in this fixya.
      Good luck, I have always loved this radio except for the pesky light keeping me up at night.
    May 28, 2009 | Tivoli Model Three Clock Radio
    Alarm clock won't change time with daylight savings
    unless it is an automatic , atomic clock none I have ever owned do the change automatically
    Feb 27, 2017 | RCA Audio Players & Recorders
    Spectra Hello Kitty Digital Alarm Clock & Night Light Logo
    375 people viewed this question
    Top Spectra Toys Experts
    Andrew Taylor
    Andrew Taylor
    ray gallant
    Are you a Spectra Toy Expert? Answer questions, earn points and help others
