Question about Garden
I bought a used blower and I need to know the gas mix and spark plug number.
    Problem Solver:
  • 11 Answers
The make and model would be useful.
Posted on May 22, 2011
What kind of fuel does a john Deere BH 25 gas leaf blower use that is a 2 stroke. And what kind of spark plug is used?
Spark plug is NGK BMR7A gap is .025 Fuel is any gasoline mixed 40 to 1 with 2 cycle oil.
Aug 26, 2016 | John Deere Garden
Toro Power Clear 418 snowblower wont start after sitting through summer
Check the fuel line to the tank, and see if another one is inside, maybe it fell off, or it's filter is clogged.
Nov 29, 2013 | Toro Power Clear 418 ZR - Single Stage...
Poured in the wrong oil/gas ratio into my Craftsman leaf blower. Stupidly poured entire 2-cycle oil provided directly into the blower reservoir and filled balanced with gas (Should've read instructions...
it only means your spark plug is covered in oil. I do not expect any damage. try and remove and clean spark plug maybe use some gas to wash the excess off. maybe put a small drop of gas into the spark plug hole and replace. this may help start the engine. what you need to do this flush out all the oil so that the correct mix can get in. Also ensure no oil has got into the air filter ensure that is clearn before trying to start it again.
I hope this was useful
Oct 31, 2013 | Echo Inc. 25.4 CC Backpack Blower
I mixed correct oil,gas, but still runs bad,acts like wants to bog out
Plugged air filter or exhaust,maybe?
Fuel restriction?
Nov 12, 2012 | Garden
Gas and oil mixed in 4 cycle backpack leaf blower
If it is a 4 cycle blower, you do not mix oil with the fuel....It takes straight Gas. there is an oil cap to put engine oil in crankcase, this only usually takes 2,3,4 oz. of oil. Sounds like your Spark Plug probably fouled out from having oil mixed in your gas. I would recomend changing your Spark Plug and put some Fresh GAS only in the blower, dump the old stuff out !!! You should be on your way Blowing in No Time !
Nov 27, 2011 | Troy-Bilt 32cc 4Cycle Backpack Blower
I have a Craftsman 2-cycle blower/vac and its only 3 years old and have changed out the spark plug and fresh mixed gas and still won't start. I need some help anyone know?
Check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage. May need to clean or replace carburetor.
Sep 18, 2011 | Craftsman Garden
I need to know what spark plug to use for my snow thrower. My son lost the one I had taken out to be replaced.
If snow thrower uses ordinary gasoline, then go to hardware store and get spark plug for lawn mower.
If snow blower uses 2-cycle engine oil mixed with gas, then get spark plug for weed eater.
Or buy both and try them out.
Hardware store is more likely to have someone familiar with which spark plug you need than box-size home center.
http://www.toro.com/home/customercare/interactivemanuals.html
Dec 26, 2010 | Garden
I can't get it started
Check 1. Compression 2. Gas/oil mix 3. Air filter 4. Spark at spark plug. This is just the beginning of troubleshooting a 2 stroke. They develop fuel line problems and carburetor problems and magneto air-gap problems. Critical though is the oil/gas fuel mix that is used. It needs to be fresh and mixed at the correct ratio. Check all these things that you can and post back.
Dec 14, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
I have an 28 cc McCullogh leaf blower which will
Check for spark in the new spark plug, if you have spark clean the carb fully and try again. make sure you have correct mix of gas to oil and it is not old use fresh gas oil mixture. Good luck pal.
Jan 23, 2010 | McCulloch 26cc Gas Blower Mcb3208
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
