Question about Hoshizaki Cubelet Ice MakerDispenser Water Cooled LED Sensor Operation
Hoshizaki ice machine model 150 doesn't turn on. Where is the bin control switch?
  • paul95495 May 22, 2011
    The link doesn't look like our machine which is the hoshizaki model km 150 baf.
    We don't see bin control switch and if we find it, how do we get the machine to start (on/off switch does nothing; circuit breaker fine; water fine; it worked last season and now won't turn on...)
  • paul95495 May 25, 2011
    not sure where exactly to find bin control switches from diagram, ie, where to remove panel to gain access to get the machine to start! see how it works to control ice but not how to get it started
    Genius:
  • 1,400 Answers
Hello
Here is a link for your ice maker.There is alot to explain so im going to give you the page on bin control.
http://www.hoshizakiamerica.com/techspecs/pdf/prplbk.pdf
Page 32 decribes the bin control.
Posted on May 25, 2011
  • 3,018 Answers
  • This bin includes a proximity switch and actuator paddle assembly. The mechanical bin control assembly mounts in the ice drop zone area and will shut the unit down within 3 seconds when ice pushes the actuator paddle to the full right position, away from the proximity switch. Shut down will only occur during the first 5 minutes of the freeze cycle when the paddle is moved away from the proximity switch. If the paddle is moved away from the proximity switch and held at any other time during the sequence, the unit will continue to run until the next freeze cycle occurs. This feature allows for a full batch of ice every cycle so that there are no small cubes in the bin.
  • The bin is in the back and must be pushed all the way to the side (see diagram) You can also read more about this on page 30 of the manual I have provided (below)
Regards, Tony
Posted on May 22, 2011
  • Iron
    Iron May 22, 2011
    • The link is actually to a techs guide to your ice make not a users manual. The techs guide is far more advanced than a simple users manual. Don't loose it :)
    Regards,
    Tony
  • Iron
    Iron May 28, 2011
    • It's inside the icemaker itself. Where the ice sets.
    Guru:
  • 1,833 Answers
To find the location of Bin Control switch you can follow the manual, otherwise please follow this link: " http://www.realcold.co.nz/media/documents/pdf/capital_plant/CP%20Catalogue%20Oct%2008/ALL%20Hoshizaki.pdf". Hope this will help you.
Hoshizaki ice machine will not power up
with not model or serial numbers, I can only suggest that it may very well be the "bin stat". This is a thermostat that has a sensing bulb that is in the bin and senses the ice when it touches it to shut down the machine. If this is bad, no power goes to the control board. Try jumping this out with a jumper wire and see if the machine comes on.
Dec 18, 2016 | Hoshizaki Freezers
Why did my hoshizaki ice machine stopped making ice?
bin stat is what is used to shut machine down. if it goes bad in any way, no power will go to the control board. Start there.
Aug 11, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki km-900mah ice maker won't start the freeze process
cycle is, fill cycle for 1 minute first. If there is not water entering the unit when first turned on, look for that issue. Water turned off, water valve not working or some restriction, clogged water filters, etc. That is got to happen first. Don't over look the bin stat being bad. Nothing happens if teh bin stat is bad. It sends voltage to the control board that runs the unit.
Jul 28, 2012 | Hoshizaki Freezer Commercial Ice Machines...
I STARTED A HOSHIZAKI TOOK TAPE OFF CURTAIN LOWERED BIN CONTROL INTO BIN CONNECTED BIN CONTROL HARDNESS UNIT WORKED GOOD BUT NOW WATER IS LEAKING INTO BIN MELTING ICE IN BIN ANY IDEA OF WHAT COULD BE...
Start by looking for water valve leaking. Turn machine off and if water is entering machine, water valve is not seating. Let me know if you need more than this.
Feb 14, 2011 | Hoshizaki KM-1300S 3-Phase Stackable...
Hoshizaki klm-450mah ice maker: nothing happens when machine is turned on. this unit has been trouble free for the last 5 years. after turning the unit on everything started as it should and one load of...
http://www.hoshizakiamerica.com/manuals/KML_F-and-H_series_serv.pdf
This is the service manual for you machine. The wiring diagrams on pages 56 and 57 shows that the machine does nothing unless the bin control is in the "Closed position. It is a temperature controled switch. If it is broken, not works. Check that out first.
Jan 13, 2011 | Hoshizaki Ice Maker 30in 550lb Crescent...
Hoshizaki ice maker am-50bae . Made ice regularily--- filled ice bin half way...next day-- all ice melted away with no more new ice? next day shut off for 3 hours now o new ice.
make a few quick checks. If there are water filters on the system, be sure they are not restricked. Could be clogged. Next, check the bin stat. It usually is mounted in the ice bin. If it breaks or goes bad, it shuts down the machine. Start there and let me know if I can be of any further help.
May 19, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Model kml-450mah seral mo2237b Hoshizaki Ice machine
start at looking for a stuck float switch. this keeps it in defrost till it senses water level full enough to make ice.
Aug 12, 2009 | Hoshizaki Modular Cuber 680 Lb. with 550...
Bin control
The bin control shuts it off when the ice bin is full. Without a bin control it should keep making ice and never stop.
Dec 27, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki Cubelet Ice MakerDispenser Water Cooled LED Sensor Operation Logo
509 people viewed this question
Top Hoshizaki Kitchen Appliances - Others Experts
Dennis Boxerman
Dan Webster
Dan Webster
Are you a Hoshizaki Kitchen Appliances - Other Expert? Answer questions, earn points and help others
