Question about Kitchen Ranges
Experiencing a problem with our Lochinvar TNR200-100 water heater. Using it at a hotel and need the fastest help possible. Our maintenence guy says the machine is flashing "valve". What can we do to get this working ASAP?
  • 990 Answers
SOURCE: What would make the high limit trip only at night
Low presure due to low water, dirty filter or dirty pump basket. Could also be a high draft from being to close to a high wall and this will cause a down draft when cool night air gives more ristense than it can get over. hard to say without more info. Make sure all these things are ok and let me know how you do. Good luck.
Posted on Nov 07, 2009
housejess
  • 317 Answers
SOURCE: 2 month old Lochinvar Electric 30 gal heater hot
is it a new well.......it may go away after a while...its sulfer....sometimes when you drill well too deep you get sulpher water......
Posted on Nov 17, 2009
  • 8404 Answers
SOURCE: Lochinvar electric hot water heater reset button
Is this a two element 220 Volt heater? Do you know how old the elements are?
I have a feeling your elements need to be replaced.
What are your thoughts on my remarks?
Posted on Dec 21, 2009
rsmith972278
  • 160 Answers
SOURCE: To fix leak my maintenance guy removed Blanco
Hi, If the the check is put on backwards it will not allow any water to flow. There's usually an arrow. As far as the water pressure goes...check the on - off shut off valve. Also check for obstructions, like bits of O ring or rubber in the supply side of the faucet. They can possibly make it to the valve on the faucet.
Hope this helps, RSMITH972278 P.S. PLEASE RATE MY ASSISTANCE
Posted on Dec 29, 2009
  • 990 Answers
SOURCE: Fixing our hotel's Hayward CSPAXI55 spa heater.
You can probally get a manuel on line if you go through Hayward.
When he took the old one out he probally just wired the circut together where the temp assembly goes into the cabnet in the top right front of cabnet in the upper panel. Then the temp probe runs around the side to the water header or manifold. If this is in the orignal spot it is on the right of the heater and easy to find. I'm not sure but if the exchanger has been turned then it will be around the back side of the header and it will be on the left side of the heater. Geting a manuel for this is a good idea anyway, good luck.
Posted on May 09, 2010
I am looking for a replacement water heater that is in the $500-$600 range. My current water heater is Lochinvar DVN-041. Any ideas?
You can replace with any brand and size to suite your need. But I believe they don't sell you and let you to install by yourself.
You have to buy it in and pay installation fee then they'll
bring in and install for you.
Good luck
Mai
Apr 25, 2017 | Water Water Heaters
Why do they keep leaking
-havent had any leak, need a little more info on where it is leaking from though
Jan 27, 2016 | Lochinvar SIT119 113 Gallon Squire...
What should I do if my pilot light is out
There should be an electronic igniter with instructions on how to start it right on the heater.
Feb 24, 2015 | Lochinvar Shield Water Heater
I keep getting the word temp o/shoot when i turn on
Means that the boiler has over heated to quickly and the delta T is too high.
POSSIBLE CAUSES
- no water in system
- proper water flow not present
- air in system
- bad sensors
Nov 24, 2013 | Lochinvar Water Heaters
I'm thinking of buying a Lochinvar Energyrite 402000 BTU Natural Gas Heater for my pool and spa. Does anyone have experience with this manufacturer or model? I'd like to hear the Good, the Bad and the...
My boss once asked me if I could work on a Lochinvar. I told him I could pronounce it.
Chevy is a car and so is Mercedes Benz. Lochinvar is the same kind of German engineering. Quality product. Tough to find people qualified to work on one and pricey at that. Great heaters though. As far as the model I have only worked on the big ones.(commercial) I have found if you work on them one time they stay fixed.
Nov 30, 2010 | Lochinvar Energyrite 402000 BTU Natural...
May 08, 2010 | Hayward CSPAXI11 11Killowatts Electric Spa...
The Thermostat does not reset!!!
Hi jamaica,the reset pops on tank/water tempature. The unit is overheating or the reset/saftey has become defective.Recommend replace thermo.
Mar 31, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Dec 21, 2009 | Cell Phones
2 month old Lochinvar Electric 30 gal heater hot water has rotten egg smell. Do not have water softener system. Well water with a lot of iron.
Nov 16, 2009 | Emerson InSinkErator W-152 Point-Of-Use...
Kitchen Ranges Logo
71 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
