Question about Maytag Dependable Clean Top MAV5920EWW Top Load Washer
The water temperature on my Maytag model 5920eww does not hold the setting and will automatically switch from hot to cold.
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: Water temperature problem
Chief Walley, you have a temperature control board that sits right behind the timer. A thermistor senses the water and sends the info to this board. The thermistor sits at the water injector. The board may be your problem, I have seen many like this. Keep in mind that the target temp for cold is 75 degrees. If your incomming water is higher than this, you are going to get a warm fill, which they think is cold. Without being there, I would go after the board. Catriver...post back.
Posted on Aug 09, 2006
SOURCE: Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Posted on Nov 19, 2008
onthejob5130
  • 640 Answers
SOURCE: cold water inlet on maytag top load washer not working
switch the hoses fill hoses and if no hot enters you have a defective inlet vavle,,replace...onthejob
Posted on Jan 18, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore 70 series washer won't fill during rinse cycle
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
I have a Maytag MAV7700 washer. It can fill with hot or cold water but when warm is selected it doesn't appropriately mix them to get a warm temperature even with the automatic temperature co
Hi etjacobsen.
As 'warm' is a mixture of 'hot' and 'cold' water a simple remedy to your problem might be to reduce the flow in the tap supplying the machine.
Good luck.
Nomess
Jan 12, 2015 | Maytag MAV7700 Top Load Washer
I have a Kenmore washer model 110.98762792 and im having a problem with the cold water. When the water temperature switch is set to the cold/cold position the washer does not fill with cold water. W
Since U get warm water that tells you that the cold and hot water solenoids are both operating. Ergo the anomaly has to be with the device that controls temperature.
Apr 10, 2017 | Kenmore Washing Machines
Automatic warm/cold water temperature setting does
The temperature control board is bad . Pt # 388246
Aug 17, 2009 | Kenmore 22422 Top Load Washer
Maytag washer/hot and cold water
Some whirlpool washers have had A similar problem. They had a intermittent water temperature switch issue. Sometimes they put hot water in when cold was selected. This is probably the same problem as yours. I would replace the water temp switch.
Mar 02, 2009 | Maytag LSE7806A Top Load Stacked...
Hot water will not fill into the tank when starting cycle.
The ECU is at fault.
Change it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 13, 2009 | Washing Machines
You probaby have an inop hot water fill valve.
Dec 19, 2008 | Washing Machines
Maytag washer
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Automatic temperature control
The cold water valve may be defective - the solenoid (coil) burnt open. Coil may be replaced
Regards
Sep 20, 2008 | Maytag Washing Machines
Maytag Dependable Clean Top MAV5920EWW Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
