Question about Cameras
I think there is sand in my lense ia that covered by my international warranty
  • amandajuliet May 18, 2009
    the lens is stuck on my camera. it will not go back. if i press the button it makes an alrming noise. i cannot take pictures. but i can still review pictures. i don't think there is sand in it.
    can you help?
  • Cameras Master
  • 19,396 Answers
This is a matter co chance, if factory considers that you caused the problem the guaranty may be void.
In many case they just fix the camera and give it back to you validating the guaranty, even when is is sand of water problem.
First blow the outer part of the lens with canned air to remove sand on the outside of lens barrel. see if this can fix the problem.
If you still have the problem go to an authorized repair shop or call factory using phone number at the end of repair manual, and just tell them that you get lens error from time to time.
Naturally , if you have to tell them that your 3 years old buried the camera under a sand castle this will void the guaranty!
good luck
Posted on Aug 15, 2008
Panasonic Lumix DMC TZ30 lens cover only closes half way
These things are super sensitive to ingress of dirt,i just give my lense cover a helping hans sometimes when it locks.
Jan 07, 2014 | Panasonic Lumix DMC-TZ30 Digital Camera -...
Nikon Coolpix 4600. Lense cover does not close when camera is turned off or fully open when camera is turned on. I can move it all the way open with my fingernail. Seems like mechanical mechanism is...
Any sand in a compact camera is bad news - repair will be expensive. In your situation, I would continue to use the camera while it still works, and give serious thought to a replacement.
Jul 20, 2017 | Nikon Coolpix 4600 Digital Camera
My coolpix S210 lense will not go in. Showing lense error on scr
Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to auto focus while the lens is extending, hopefully seating the lens barrel guide pins in their slots. Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Thank you!
Jul 26, 2010 | Nikon Coolpix S210 Digital Camera
I need the part number for the extender lever on a Canon J 33x11 lens. Where can I find that number?
Although I'm not very familiar with Canon's range of professional broadcast grade lenses, I think that you might find the information you need on page 33 of this downloadable (pdf file) Canon catalog. It's an exploded diagram and numbered parts list for a number of lenses which are closely related including the J33ax 11B IAS.
I hope that this helps you and that you rate my answer in return.
Mar 01, 2010 | Canon Cameras
I think some dust or sand has gotten in the zoom,
compressed air is your best bet, but very tricky to take all apart. have you tried using a hover with some sort of small paint brush and direct all the vacume into the areas wher eyou think the sand is. might work best of luck
Nov 30, 2009 | Panasonic DMC-TZ5 Digital Camera
My nikon 17 to 200 vr lens is suddenly making a little grinding noise when i turn camera on..
Send it in for service. If it was purchased in the USA and you sent in the Nikon extended service contract that comes free in every Nikon USA lens then you have a 5 year warranty that covers most parts and defects. The warranty does not cover abuse, dropping sand damage etc.
Oct 16, 2009 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Believe there is sand in my Quantaray len - any way to fix with out spending alot of time and money>
Not really, Most lenses have grease internally, sand/dirt will collect there easily. Sand is harder than any of the materials in the lens, it will wear parts faster. To get it all, a complete tear down would be the only solution, very time consuming
Sep 25, 2009 | Quantaray 28-80mm F3.5-5.6 Auto Focus for...
How do I replace xc90 headlight assembly?
its really easy. Open the hood, you will see two metal flat bars on the backside of each headlight, holding the headlight assembly on. Pull up on each of them.... remove headlight. Ta da.
Sep 19, 2008 | 2004 Volvo XC90
Lense Cover Stuck
Try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and be aware this will void your warranty):
Oct 01, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
Error 411,5,629
Oh yeah, it sure does sound like sand. Sure death to zoom lenses. Kodak will not cover this under warranty either. Unfortunately, Kodak will not sell parts to anyone so you are going to have to deal directly with them.
Apr 04, 2007 | Kodak EasyShare C340 Digital Camera
Cameras Logo
108 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
