Pure One Works intermittently, goes off after 5 minutes, comes back on after another10.
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO THE HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
Posted on May 22, 2011
How do I fix Eden Pure Heater? It goes on and off intermittently, mostly off.
You need to clean the filters in the back of the unit. It is not receiving enough air flow. They just snap out and wash the little foam filter and replace it.
Mar 10, 2015 | Eden Heating & Cooling
Hyundai monitor on for 5 minutes and screen goes black
Have you ever opened up the monitor to clean the dust out,it could be your heating up and then letting it sit will bring it back.If your unsure how to do this ask a tech.
Apr 21, 2017 | Hyundai X224W
My Polaroid screen goes black after a few minutes sound stil works but the screen is dark, I can power it down then back on and the screen will come back for a few minutes
Hi there! This may be the Inverter board. This board drives the lamps. There may be loose solder points on the coils or perhaps loose cables. Obviously an intermittent fault so I would start with that. If not familiar with electronic repairs, please refer to a repairer. Always beware of High Current and always unplug before opening. Best Wishes and Good Luck, JUS004
Aug 30, 2009 | Insignia 42" LCD Flat-Panel HDTV
Maytag dryer dg712 does not stay lit
Yeah change the coils read my page on intermittant coils HERE
Apr 12, 2009 | Dryers
Sony grand wega 55in kdf-55a20
Its most likely an intermittent lamp. The lamp door is located behind the front panel. The front panel can be removed after loosening the two thumb wheels located on either end of the TV in the rear. Observe the light coming from the area around the lamp door. If you see that the light is going out, its the lamp. You can also access the self-diagnosis menu by using the remote control. Start with the TV off. Push the "mute", then the number 5 button, and then the volume down button followed by the power button. When the picture appears, the menu will been visable. If there is a failure with the lamp, or a fan, or many other areas in the TV there will be a number value to the right of the parameter that indicates the number of times the error has occurred.
michtech
Feb 16, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Screen Goes Green TV goes to stand by blinking 8 times
try adjusting your color tuners located inside tv behind speakers.
Nov 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Intermittent battery light
replace your alternator" the diodes are going bad
Jun 22, 2008 | 2006 Saturn Vue
Screen goes black, 5 blinking red lights, screen back on for 20 seconds....cycle continues
Let me first say that if you are getting 5 blinks its not the thermal fuse. Your problem is your Lamp. You have what we call an intermittent Lamp. The only way to fix this is to replace the lamp. Part Number A-1085-337-A. Average cost $217.00
Circuitcity
Dec 09, 2007 | Sony KDF-E55A20 55 in. LCD Television
HP mx 70 Monitor
This is a problem usually with the Power Supply unit inside the Monitor. Often it is the Electrolytic Capacitors arround the Heatsink area. They dry out and go faulty.. It is generally a job for the "Shop" I get them all the time... But in saying that intermittent faults are the hardest to find.. If you do take it to a shop, ensure you get a firm "Quote" and explanation B4 proceeding.
May 14, 2007 | HP mx705 17" CRT Monitor
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
