Question about Whirlpool MH9181XM 1100 Watts Microwave Oven
F7 error code displayed - Whirlpool MH9181XM 1100 Watts Microwave Oven
  • 794 Answers
Hi jruszas,
This F7 error code that you have on your display is all about the function key stuck on ERC. The only way to resolve this is to replace control board (also called ERC or clock). You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model number ready when you call.
Hope this helps.
Thank you for using FixYa.
Posted on Jun 07, 2011
I have a Kenmore Elite Speedcook Microwave oven, model #665.63783600. What does error code F7 mean on this model?
F7 Error Code On Microwave Ovens With Inverter Board
An F7 error code could be an inverter board failure. Anything else that prevents microwave energy may also cause an F7 error, and must be checked. The technician should perform the following procedure to test for an F7 error code:
1. Check the magnetron.
2. Check the magnetron TCO (it should be closed).
3. Check the 3 interlock switches.
4. Check the harness wiring.
5. Check the electronic controls.
6. Check the inverter board.
For more free help, feel free to contact me via my site with your detailed symptoms and full model number and FCC ID number as shown on the tag in or on the oven.
Nov 18, 2016 | Kenmore Microwave Ovens
How CAN i TEST MY MICROWAVE?
Most common cause of an F7 code on these models is a bad inverter or magnetron. Generally it is best to replace both the magnetron and the 1100 watt inverter board at the same time, since a bad magnetron is usually what burns out the inverter board.
Jul 24, 2014 | Whirlpool Gold GH5184XPS 1.8 Cu. Ft. Over...
Code f 7
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components. It should cover an F7 error code.
A video is available here showing how to remove a typical over the range control panel assembly in under 5 minutes.
This may help:
MODELS: GH9177XL, GH9185XL, MH9180XL, MH7155XMS, & KHHS178L for example
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Oct 15, 2013 | Whirlpool Microwave Ovens
Microwave error message F7
This is for whirlpool models.Try this procedure and see if it helps.what is your model?
Models: GH9177XL GH5176XP GH5184XP GH6178XP GH6177XP
KHHS178L KHHS179L
Microwave will not operate (cook). F7 error code
appears on the display.
Electrical circuit interruption between L1 and Neutral in
the microwave inverter circuit.
Possible reasons:
1. Check door, hinge and cavity front alignment and adjust
as needed.
2. Check the operation of all interlock switches.
3. Check over temperature protector for the magnatron.
4. Check all Cavity Thermostats for closed circuit.
5. Unplug the oven for at least 40 seconds. If this solves
the problem
A. Check the Cooling Fan for proper operation or
blockage
B. Check the resistance of the magnetron thermostat.
It should be 0 Ohms, replace if necessary.
6. Check that the control cable to the 1100 watt inverter
is properly connected to plug P2 on the display PCB
& Adjust or Reconnect
7. If interlock switches operate correctly, replace 1100W
inverter.
8. If problem persists, replace control assembly.
Feb 11, 2013 | Microwave Ovens
MY microwave is giving me an error code F7 - call for service
This is all i could find on this error, Its alot to check. Microwave will not operate (cook). F7 error code
Possible reasons:
as needed.
the problem
blockage
inverter.
Jun 23, 2011 | Whirlpool GMH5205XVS Microwave Oven
Microwave hood combination, model # MH9181XM, is not heating anything and displays an error code of F7
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 20, 2011 | Whirlpool Microwave Ovens
My kenmore elite microwave when turned on shows a f7 error code.
f7 keeps showing up and the microwave keeps cutting off,f7 code shows up. what do i do
Oct 26, 2010 | Kenmore 68361 Microwave Oven
Error F7
Possible reasons:
as needed.
the problem
blockage
inverter.
Nov 18, 2009 | Whirlpool GH9176XMS 1100 Watts Microwave...
F7 Error code
Please reply back with your model number so we can help you.
A full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
May 30, 2008 | Microwave Ovens
Whirlpool MH9181XM 1100 Watts Microwave Oven Logo
233 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
