Question about ASUS K8V-MX Motherboard
Floppy not detected
Good morning, as I start my pc and I open the MY COMPUTER window I can't see the floppy disk icon , I looked in my device manager ( everything ok no ??? ) and the floppy disk is not installed . I changed the floppy drive with a new one and the 34 pin and I connect / disconnect the cable several times to make sure that there's no dust or loose connection but I still have the problem. PLS can you tell me what can I check.
windows xp professional-K8V mother board- 1 GB Ram x 2
THANKS
    Brigadier General:
  • 6,966 Answers
Pls go to the CMOS/BIOS setup/configuration page after power up before booting into Windows. Verify that 1.44 FDD is enabled, Save and Exit.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 15, 2008
  • Louie  Role
    Louie Role Aug 17, 2008
    Glad to be of assistance and appreciate the rating.
SOURCE:
Tip
No Hard disk detected / boootable device
<span>When the computer/laptop cannot see a boot file/disk on either the hard disk or floppy drive it gives an error message </span>- <span>"No bootable device. Insert boot disk and press any key"</span><span><br /><br />First thing, check to see if the is a floppy disk inthe floppy drive, if so removes this disk.</span><br /><span>If there was no disk in the floppy drive then it maybe a hard disk problem.<br />Check the BIOS to see if the hard disk is detected, if not open the case and re-seat the data cable on the hard drive and also where it connects to the motherboard disk controller.<br />If it still gives this error message and the BIOS does not detect this hard drive, then the hard drive is probably faulty.<br /><br />A further check on the hard drive, remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port, if this computer does not detect it as an external storage device then the hard drive is faulty.<br /><br />To get the computer operating again, install a new hard drive in your computer and then install Windows on this hard drive plus the computer's device drivers and your programs.</span>
on Jan 17, 2011 | Computers & Internet
Tip
NO BOOTABLE DEVICE
When the computer/laptop cannot see a boot file/disk on either the hard disk or floppy drive it gives an error message - "No bootable device. Insert boot disk and press any key"
on Oct 02, 2010 | Computers & Internet
My laptop says no bootable device insert disk what is wrong?
NO BOOTABLE DEVICE When the PC cannot see a boot file/disk on either the hard disk or floppy drive it gives an error message "No bootable device. Insert boot disk and press any key" First thing, check to see if the is a floppy disk in the floppy drive, if so removes this disk. If there was no disk in the floppy drive then it may be a hard disk problem.
Oct 30, 2012 | Toshiba Computers & Internet
Bootable device has not been dectected
When the PC cannot see a boot file/disk on either thehard disk or floppy drive it gives an error message "No bootable device. Insert boot disk and press anykey" First thing, check to see if the is a floppy disk inthe floppy drive, if so removes this disk. If there was no disk in the floppy drive then it maybe a hard disk problem.
Check the BIOS to see if the hard disk is detected, if not open the case andre-seat the data cable on the hard drive and also where it connects to themotherboard disk controller.
If it still gives this error message and the BIOS does not detect this harddrive, then the hard drive is probably faulty.
A further check on the hard drive, remove the hard drive and connect it to anUSB hard drive adapter and connect it to a working computer's USB port, if thiscomputer does not detect it as an external storage device then the hard driveis faulty.
To get the computer operating again, install a new hard drive in your computerand then install Windows on this hard drive plus the computer's devicedrivers and your programs.
Aug 24, 2011 | Intel D946GZIS Motherboard
I have Dell 4700 Dimension and can start up it, receiving message : Floppy diskette seek failure. But computer doesn't have floppy. Somebody told me it is up to motherboard.
Hello
You need to tap the del key while booting up or select f12 key to go into bios and disable floppy disk.
This way the pc will stop locking for a floppy disk.
Mar 24, 2011 | Dell Refurbished: Desktop Motherboard...
When my computer starts it goes to a black screen and says "no bootable device jnsert boot disk and press any key" what can i do
Normal 0
This error message - "No bootable device. Insert boot disk and press any key" means -
The PC cannot see a boot file/disk on either the hard disk or floppy drive.
Check the floppy drive and remove and floppy disk.
If there was no disk in the floppy drive then it is a hard disk problem.
If it still gives this error message and the BIOS does not detect the hard drive, then the hard drive is probably faulty.
To get the computer working again, install a new hard drive in your computer and then install Windows on the new hard drive plus the computer's device drivers and your programs.
NOT APPEARING IN MY COMPUTER
If the Floppy Drive is not appearing in my Computer, open the PC and check that the cables are connected to the drive properly.
Also open Device Manager and check under Floppy Disk Drives that the drive actually appears there.
Aug 30, 2010 | NEC FD1231M 144MB 35" Internal Floppy Disk...
Floppy disk drive not detected.
It sounds as if you have a registry error. try to go to device manager and uninstall the drive. Turn your computer off and restart and see if Windows detects it automatically
Feb 04, 2010 | Microsoft Windows XP Professional
Bought a usb floppy drive reader to convert my floppies to my laptop. have plugged in the usb cord. what do I do now?
Its easy to use:
Step 1). Just on your lap.
After complete boot
Step2). Insert your floppy connector one end to your USB port of Lap.
Step 3). Double Click on My Computer Icon.
The my Computer will be open.
and if every thing is ok, a floppy disk drive icon [A: or B:] will be shown in the window.
Step 4). Insert your floppy disk into the Drive.
wait till the floppy disk drive light goes off.
Step 5). Double click on floppy disk drive icon [A: or B:].
and the content of the floppy will be open.
have any question... ask me
Thanks
Iqbal
Mar 22, 2008 | Computers & Internet
ASUS K8V-MX Motherboard Logo
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
