Want to restore a realistic patrolman pro-77 vhf hi-lo scanner but dont have tech or service manuals.
oldnovii
  • 667 Answers
SOURCE: Changing the Pro-49 Scanner from UHF to VHF channels,
Hi george - You can get the manual in sections that will tell you what you need to know plus you'll have it for reference. It's the way Radio Shack posts them. It's at this link:
http://support.radioshack.com/support_electronics/16429.htm
Or you can go to this site and send an email and they will email you the manual:
http://radiocollector0.tripod.com/id58.html
If this solves your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
Jeff
Posted on Jul 10, 2008
SOURCE: realistic pro 2010 scanner
to program
turn on unit, press program button, key in frequency ###.### press enter. keep advancing thru the channels with the program button until finished
Posted on Aug 03, 2008
SOURCE: I have an old realistic pro 34 scanner that I need
http://support.radioshack.com/support_electronics/26441.htm
try this site
Posted on Sep 11, 2009
BillB-SA
  • 2761 Answers
SOURCE: how do i program my realistic pro-2025 scanner
PROGRAMMING CHANNELS
1. Turn on your scanner by turning the volume clockwise.
2. The scanner might start scanning. If so, press MANUAL to stop the
scanning.
3. Enter the channel number that you want to program and press MANUAL.
4. Enter a frequency including the decimal point. The decimal point shows
up on the display as a -- (dash).
5. Press Enter to store the frequency.
6. To confirm the proper entry, press REVIEW. The programmed frequency
appears on the display one digit at a time.
7. To program more channels repeat steps 3-4.
Posted on Dec 01, 2009
SOURCE: scanner frequencys
http://www.radioreference.com/apps/db/?ctid=2710
Posted on May 11, 2010
Testimonial: "Thanks for the info.right on target.Now i need a manualor instructions for my pro-42 realistic scanner modle20-302.Thanks again"
Need a manual
I tried looking up what kind of scanner it might be by the Model number and 8 to 10 different brands came up; so who makes it is needed to be able to find it.
May 02, 2016 | Radio Communications
Realistic uhf/vhf model 20-400 pro 58 ten channel. Where can I get an owner's manual?
Products associated to Radio Scanners - RadioShack.com
support.radioshack.com/productinfo/ProductResults.asp?...Scanners...
Get Acrobat Reader. Previous Page. Products associated to Radio Scanners. SKU/Catalog #, Model, Description ... 20-139 · Realistic PRO-38 10-Channel Direct Entry Programmable Scanner ... 20-313, Pro-76, Pro-76 200-Channel VHF/AIR/UHFHandheld Scanner ... 20-400 · Realistic PRO-58 Programmable Scanner.
Dec 18, 2015 | Radio Shack Radio Communications
Good Evening Pam
Radio shack has a listing of Scanner resources here:
Radio Shack Realistic Scanner Manuals The materials for the Pro 58 are here
http://support.radioshack.com/support_electronics/8570.htm and gives access to specs, parts list, features, and a guide to scanning. It's very mid-20th century in appearance, including using type-writer style fonts.
Hoping this helps!
D
Looking for a manual for a Realistic Patrolman Pro 40 UHF/VHF Scanner. I don't even know what kind of power supply it needs.. LOL
Hi, that unit looks to be a mobile scanner and if I'm seeing right then you would need a Base power supply that could supply 12volt to it. Course you could also use a computer power supply and find the 12 volt line out on it. Here is the link to some spec's for it. Looks also to be crystal controlled so it cannot be reprogrammed. Good luck.
RadioPics Database RadioShack Realistic PRO 40
RadioShack Realistic Pro 40
Sep 06, 2015 | Radio Communications
Realistic 2004 low audio on vhf brodcast band
Hi Did you get the answer to the low volume on wfm as i have the same problem
Jan 27, 2012 | Radio Communications
How do i program this thing! I know it is almost antique.its a realistic pro-54 patrolman scanner.Do i need to take it and have crystals changed?can i do it myself?please help!!!
The Pro54 is a Radio Shack VHF/UHF crystal scanner. There is no "programming" done to this radio as it is crystal controlled.
Crystals are user changeable and are relatively inexpensive at about $8 each. Availability is declining. You can find suppliers on the internet - one such is scannercrystal.com. You'll need to know the frequency of the service you wish to monitor, make sure it is in either the VHF or UHF band supported by the scanner and finally obtain & install the crystals for those frequencies into the scanner.
The down side is if you move, most if not all the crystals installed will not be in use in the new area - making them worthless to you. You would have to find an interested buyer (probably in your old own) for those specific frequencies to recover some of your original investment.
I hope this helps and good luck! Please rate my reply - thanks.
Jan 26, 2011 | Office Equipment & Supplies
Realistic patrolman pro16A radio scanner, do not know how to program freq, this scanner does not have crystals, does anyone know how or have a manual??
I have checked several sources, and they all show that the PRO-16A is a 16-channel VHF/UHF CRYSTAL scanner. Remove the bottom cover and you should see the crystal sockets.
http://radiopics.com/RS-Realistic/PRO-16A.htm
Bill B.
Listening in since the 60's
Oct 14, 2010 | Radio Shack Radio Communications
Hi my pro 96 scanner recieves nearby stations poorly
If you're talking about a digital trunked system with multiple towers or a simulcast system, then 'welcome to the club'. I have the same problem, but that only applies to digital trunked multisite P25 9600 baud systems. Everything else should be clear. What band are you trying to listen to: VHF Lo, VHF Hi, UHF, 800MHz, analog or digital? RS's more expensive antenna will give you better reception on VHF over the 'stock' rubber antenna that they give you. Let me know what you're trying to hear, and I can help more on this issue. Okay?
Jul 12, 2010 | Radio Shack Pro-96 Scanner
Jeff
Jul 10, 2008 | Uniden BC248CLT Base Scanner
105 people viewed this question
 Grubhead
Grubhead
