Couldn't understand the solution... not very computer literate. Can you explain what I need to do.
I have downloaded the games and they are present when I check on my computer, but when I put it into the DSLite I get this message......help.
Hi
first of all , check your r4 version.
there are many.
have you put the right firmware on your r4?
original : http://r4ds.cn/download/r4_v1.18_kernel.html
r4 revolution pro : http://www.r4dspro.com/download_en.html
r4 ultra and de luxe : http://www.r4deluxe.com/en/down.asp
r4 III : http://www.r4dsl.net/download-en.asp
after that it should work.
or maybe you should format your memory card first.
i cant remember which link from above did not work, i think the 2nd or 3rd one, otherwise the download worked fine and playing Professor Layton and the Curious Village right now! ;-).
remember ds dsi and dslite are region free so dont worry about the game just play even if you cant understand the language.
Hi have a new r4 revolution ndsl/nds card it is always comming up with cant find ds menu u.dat can you help
I found that on the Micro SD card I had managed to put the files in extra folders so the DS couldn't find them.
When I deleted the folders and had just the four files that I'd downloaded (DS Menu dat, moonshell etc) showing along with the games folder, it worked.
The DS was looking for the files and couln't see them because they were within the folder.
I keep getting the message menu ? in red in little box looks like chip can anyone help i cant get anything on there im useing 4mb micro chip r4i helpppppppppppppppppppp please
If you put the micro sd card in the usb then put it in a computer click on open files or view file then go to r4 menu and go ds mrnu dat and drag it in your moon shell document and then duplicate the file (right click new-document - ds menu dat ) then take the ds menu dat to r4 menu then save and/or save and voila all done
My r4 is in chinese i dont know it got like that first it was in english now i dont know what to do....
Guineapig1016 can help!
1. make shoure its not in any folder!
2. make sure the name is correct(DS_MENU of couse)
3. make shore its opened by windows media player
How to get it in windows medai player
1. right click it (dsmenu of courecse)
2. sroll down to open with(i think it that or propertys)-(ok so i forgot a little but i still can help)
3. then scrool down to windows meda player then chose it
4. I REPET DO NOTT DO NOTT CHANGE ANY THNIG ELSE!!!!!!! MAKE SOURE ITS NOT IN ANY FOLDERS!!!! OR ANY THING ELSE!!!!
guinepig1016/aguineapig/hatebot5000(only on heros two wii)
I was getting the 'couldn't find the ds menu.dat' error. It was because I didn't know that the kernal I had downloaded was compressed and I had to use winRAR to uncompress it. Once I'd done that it loaded fine. Also, I had problems loading using a micro SDHC in a R4 flash cartridge that could only read micro SD cards. It would say 'loading...' forever and ever. So anyways, another steep learning curve under this newbie's belt. Hope this helps save a few hours of hair-pulling for someone else.
I had the exact same problem.
I have a Nintendo DS, and R4 card.
Downloaded these files from here:
http://www.r4ds.me/download/r4ds.html
Drag and dropped to DS.
Jobs done! No extracting folders, just as is when winrar opens up.
Chris
This problem can only be solved by bying a new R4 beacause no websites have:how to download it, or waht the problem is.
So don't bother trying anymore!!!!!!
I actually lost the USB that they ssupplied with the R4 kit..
so i was just wondering if i could use a differnt usb card reader so solve my problem.......i jus want 2noe,,, if u hav an answer plzzz comment
biii..xx
SOURCE: couldn't dind ds-menu.dat using R4 card
you can download the files needed for the r4 just google it. You may need to use dslazy or fixit in order for the game to operate. good luck!
Thanks. The main problem was the software disc is no longer supplied and the supplier did not send *any* information about these files.
www.r4ds.com has been down for ages but when I bought another the supplier explained that there was in software included but did siggest the above website and www.r4sdhc.com or www.ndslr4.com.
I downloaded files and it was sorted.
there is no menu the sd is blank
When I turn on my DS lite, There is this message, couldn't find DS_MENU.DAT, What can I do?
when i put the r4 card into the ds lite then i ve got the same script
i got the sme problem
Wonder if anyone can help me please. Have put all the files onto the SD card as dowloaded from http://r4ds.cn/download/r4_v1.18_kernel..... And followed various instructional videos on YouTube. Yet I am still getting the message 'Couldn't find_DS_MENU.DAT' on the DS. Yet I know that there is definately a file called that on the SD card. Very confused!!!
the menu for what game wont open
I also have the same problem, i have tried formating the micro sim card and reloading the files as it sates on the above website
How to update R4?
After downloading and decompressing the new updated files, there will be one shell folder and two files _DS_MENU.DAT、 _DS_MSHL.NDS.Copy these files to the root directory of TF card to replace the former files
But i still get the same error can anyone help?
i just charge my DS, when i put my r4 in it, it didn't work it gave the message i don't know what to do help
i cant find the menu data anywhere on the disc.
it says when u turn it on couldnt find ds menu.dat
iv tried this numerous times. please help!!! :):)
it all ways says that there is no menu data at all
my problem is that i got myself a new 4gb sd card and i downloaded all the firmware for the original r4 and dragged and dropped them in the sd card and i put all my games that i had in my 2gb sd card in my 4gb sd card and when i put it in it just syas "Loading..." i hope someone can help :D
i have exactually the same problem my R4 has arrived today with no instructions and no menu data, so if i went on to this web what do i have to download on to my R4 to get it to work?
when i open my ds it loads and then it has sceen and it sat "cant fing ds menu dat"
i cant find ds menu dat i accidentally deleted every1 gives the same sites! i cant work the sites i dont know anything about computers can u take me through the steps
i went on my r4 card but it says CARN'T FIND_DS_MENU.DAT please help me! and i've also looked on the internet to see if i can find a website to download the _DS_MENU.DAT but carn't find any coz i can download it then put it on my r4 coz i know what i'm doing lol please help me.
when i put my r4 into my (NDSL) i get a dumb message saying couldnt find ds menu data
mine says Menu?
i dragged all the files to my micro sd
my R4 keeps saying MENU? with a red face can u help
for solution number 2, how do you put it in the R4 menu?
