Question about GE GSF25KGW Side by Side Refrigerator
MY GE GSF25KGW Sise by side water dispenser will not stop. It is stuck open. Had to turn water off to house
  • 1,543 Answers
Replace the water valve (part number WR57X10070) which should run $40 to $50 or so. It is the part the water line connects to at the back of the refrigerator.
Posted on May 22, 2011
I have GE refregrator (side by side) GSS22JERF, water is continuesly flowing through the water dispenser . finally I have to shut down water intlet to refregirator. what will be the issue?
You are describing a problem to be either your water valve is stuck open or you may have air in the line creating a siphon. If with the water on, if you unplug the water valve in the back, does the water stop flowing? If yes, problem is door switch, if not, its the water valve not closing. Have you recently replaced the water filter? Did you flush out the air? If not this is called a siphon effect and can cause the water dispenser to run after dispensing water.
Those are things I would look for.
Sep 14, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser will not stop
Your water control valve is stuck open because of defective microswitch in door dispenser. (Behind where you press your glass) or the water control valve that opens when dispenser is pressed is stuck open due to particals of debris caught in the dual water control valve. For example the=> PSS26MGPACC Item 72 in photo or in dual water control valve itself=> Dual Water control Valve
Sea Breeze
All answers does depend on your model number, Click Model Locator here=> GE Model Number Locator Side by Side
Top Freezer
Bottom Freezer
Please let me know if helpful or if you have other questions, Thanks, Sea Breeze
Feb 14, 2011 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
My whirpool sise by side rrfrigerator leaks d\from
there should be two small holes on each side of the dispensor cover
push a small nail in to those holes and pull forward
it will snap back in when your donr
Oct 07, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker dripping water even in stop position (bar up) and keeps supplying water to device. water dripping from the bottom of the housing unit at a steady rate.
unplug ice maker if you still have water coming in fill valve is stuck on back on the bottom if not more than likly icemaker bad
Jun 26, 2009 | GE Profile 20.7 cu. ft. CustomStyle...
Slow water flow from GE Fridge water dispenser
slow water from my ge refrig side by side. less than a momth old
May 04, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water dispenser won't turn off
The valve has gone bad so please replace the valve and it will work fine.
Aug 09, 2017 | Refrigerators
The water is not working
Put a space heater in front of the door for an hour. If that is not it check the solenoid valve for obstruction.
Mar 01, 2009 | Whirlpool GS6NBEXR Side by Side...
Water dispenser not working
This water line does not run through the freezer. You have a switch in the door where you get water that activates the water valve in the back of the Ref.
One or both of these are bad and needs to be replaced.
Dec 21, 2008 | Refrigerators
Door dispenser stopped dispensing, starting making a constant clicking and now the entire fride isn't working
We had the same problem. Our frigerator is 1.5 year old. Everytime we try to dispence water or ice the dispencer clicks and the whole thing turns of. We had a GE repairman come by: the electronic board needs to be replaced: total cost $350. (cost of the board only: $150. We are considering disconnecting the dispencer by unplugging the board (according to the repain man the ice maker wil still work)or buy a new refrigurator (for sure NO GE!!!!!!)
Aug 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSF25KGW Side by Side Refrigerator Logo
106 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
