Question about Amcor AF9000E Portable Air Conditioner
I have had the AF11000E Model AMCOR portable AC for about 2 years. It now does not cool. It does seem to attempt to compress when it reaches temperature. Could it need freon, or is there something else going on?
  • 22 Answers
SOURCE: amcor af11000e air conditioner. The fan runs, but
it is either the capacitor or it has no freon you can replace cap but not add freon not worth it. you should return it if you can
Posted on Aug 07, 2009
  • 11 Answers
SOURCE: MAY AMCOR KF9000E PORTABLE AC THE COMPRESOR LIGHT
**** Yo CoUcH *****
OBAMA NATION!!!
Posted on Aug 30, 2009
  • 146 Answers
SOURCE: Does anyone know how to add freon to a Amcor
All i can tell you is the system is a sealed system and you need to install line taps on the suction line. It is the larger one on the compressor. Like i said before you can not buy R-22 with out an epa card. That is how you would charge the system, low side line tap.
Posted on Jun 12, 2010
  • 3074 Answers
SOURCE: dont know how to empty portable ac amcor AF 12000E
sound like the drain plug needs to be removed
Posted on Jul 22, 2010
SOURCE: Parts for Amcor Portable Air Conditioner
need a window kit for amcor kf9000e.
Posted on Jun 09, 2011
Where in Southern California can I get it recharged with freon?
Generally portable a/c units are not recharged because they do not contain a service port like a home or auto a/c unit does. At the factory they charge the unit crimp the tube then weld it closed. And no one can service freon unless then can vacuum recover it.
Aug 05, 2015 | Amcor NanoMax 12,000 BTU NanoMist Portable...
Why did my Hairer 8000 BTU portable A/C quit cooling on cool mode? It was working very well. This afternoon, I went into the bedroom, where the A/C is located, and room was not cool. When I switched t
Do you hear compresser start up noise. If so then please check it with a clamp meter and Amperage the Unit is drwing. If it is less than 8-9 Amps than there is some leakage in the AC and all the collent has leaked. So you got to get it serviced.
Sep 25, 2014 | Haier Heating & Cooling
How do i add refrigerant to a amcor kf900e portable air conditioner"
The compressor picks up the gas that is bringing the heat removed from the house to be compressed to liquid and cooled in the condenser coil When running the compressor is very hot. When the freon is low the compressor will be cooler because it doesn't have as much heat to compress. To add freon you must add a service valve to the low pressure line.
Aug 02, 2014 | Amcor KF 9000 BTU Silver Portable Air...
Amcor portable Air conditioner replacement exhaust hose
I am also looking for a replacement hose for my amcor nanomax portable ac 12000 btu. If I locate one, I will let you know
Jun 26, 2013 | Amcor Heating & Cooling
My amcor air conditioner is leaking water all over the floor. I drain it and it will only last less then 24 hours till it turns off, leaks all over an needs to be drained. Help!
I figured out the problem. My Amcor portable started leaking after the fill light came on for the first time in years. After doing some research I saw that it uses the water to cool some other part of the system to evaporate out the exhaust. So I took the ******* apart and messed with things. Finally I started pouring water into different trays and noticed it would not drain down from the top tray even when running. So I removed the top part and found the drain hole. Blasted that sum ***** with some compressed air and WAMMO it works again.
-madmanmarz
Jul 06, 2011 | Amcor PLM-14000E Portable Air Conditioner
I have 2 Amcor portable AC's and the plastic
I have found that getting parts from Amcor units is like looking for a needle in a haystack. However, other portable AC units, like Goldstar, LG, Comfort Aire, Kenmore and others, use the same type castor wheel.
I have included a link to Appliance Factory Parts. They stock and handle thousands of parts, with good pricing and fast shipping. Check them out, as they may be able to help you.
http://www.appliancefactoryparts.com/search/partinfo.php?partsID=282514&modelsID=&typeName=air%20conditioner
Hope this helps you. Please let me know. Thanks.
Jun 11, 2011 | Amcor V22253 Portable Air Conditioner
Unit vibrates violently
okay locate the screws on the bottom an the sides of the unit to open the system soon as the system is open ,try to locate the fan motor that supplies air to room an cools compressor off thats your problem with vibrations
May 16, 2010 | Amcor PCM 10000EH Portable Air Conditioner
Your parts can be found at amazon, click here and take a look: Finally charging for our multi device world. I hope this was helpful. Cheers
Apr 30, 2010 | Amcor AF9000E Portable Air Conditioner
Amcor af11000e air conditioner. The fan runs, but doesn't cool. The compressor tries to turn on but just clicks back off at regular intervals. The compressor light is on.
Aug 05, 2009 | Amcor AL10000E Air Conditioner
Amcor AF9000E Portable Air Conditioner Logo
263 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Donni Steen
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
