Which processor is better intel pentium 4 2.4ghz/1m/533mhz or 2.4ghz/512kb/800mhz
    Brigadier General:
  • 10,406 Answers
Both CPUs are the same speed, if your motherboard can support the faster 800 Mhz clocking.
So, having '1M' of internal "cache" is better than having '512KB' (only 50% of '1M') of "cache".
Posted on May 22, 2011
What are the different cpu's that ux915g motherboard will accept? Can it take a pentium D processor?
This would be the Aopen motherboard from the cube...
They take the following CPU's
Processor Number
Processor Frequency
FSB
Ratio
Cache
5 Series
560
3.60GHz
800MHz
18x
1MB L2
550
3.40GHz
800MHz
17x
1MB L2
540
3.20GHz
800MHz
16x
1MB L2
530
3.00GHz
800MHz
15x
1MB L2
520
2.80GHz
800MHz
14x
1MB L2
3 Series
350
3.20GHz
533MHz
24x
256K L2
345
3.06GHz
533MHz
23x
256K L2
340
2.93GHz
533MHz
22x
256K L2
335
2.80GHz
533MHz
21x
256K L2
Note: With CPU changing rapidly, there might be fastest CPU on the market by the you received this installation guide. This table is kindly for your references only.
May 13, 2014 | Computers & Internet
Cpus it can handle
Hello here is some info:
http://www.dell.com/downloads/global/products/optix/en/spec_optix_gx520-gx620_en.pdf
You need a pdf reader (adobe) to read the content.
Intel 945G chipset with Intel Pentium 4 processor with 800 MHz front side bus and Hyper-Threading and up to 2MB of L2 cache and Celeron D processor with 533MHz and 256K L2 cache.
Intel Pentium 4 800MHz FSB socket T with HT, XD, EM64T, and 1MB L2 cache (5xx series)
The homepage is here:
http://www.dell.com/support/troubleshooting/us/en/ussoho1/Product/optiplex-gx520
Try also to call the dell support in your country for more qualified answer.
Good luck
Nov 25, 2012 | Foxconn Dell Gx520 Ls-36 Rev A01 Pentium...
DELL PRECISION 390
Intel 975X motherboard chipset, and an LGA 775 processor socket.
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Core_2_chipsets
Scroll down to 975X in the left column.
Looking across the chart for the 975X note the processor support.
Intel Pentium D
Intel Pentium Dual Core
Intel Core2 Duo
Intel Quad Core
Listed in order of performance.
Also note that 45nm and 65nm architecture, Intel processors are supported.
(nm = NanoMeter. 1 Billionth of a Meter)
Also look at the Front Side Bus support. (FSB)
Either 533MegaHertz, or 667MHz, or 800MHz or 1066MHz.
Now look at the ram memory frequency rate ('Speed') supported.
533MHz, or 667MHz, or 800MHz.
Depends on what Processor is used.
Rule of thumb is; ram memory typically operates at half of the FSB of the Processor.
Remember that when selecting ram memory for your motherboard.
Or if you have existing ram memory you wish to use, choose your processor using the above rule of thumb.
http://www.dell.com/us/en/bpi/desktops/precn_390/pd.aspx?refid=precn_390&s=bpi
Click on the Tech Specs tab
(Overview / Product Views / Tech Specs )
Supported by the Intel 975X motherboard chipset specs, on Wikipedia link above.
http://support.dell.com/support/edocs/systems/ws390/multlang/DAO_BCC/GH458A00.pdf
http://support.dell.com/support/edocs/systems/ws390/en/ug_en/HTML/index.htm
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 18, 2012 | Dell Precision 390 Motherboard DN075 GH911...
Intel Cpu Pentium Dual-Core E2180 2.0Ghz Fsb800Mhz 1M Lga775 Tray Logo Problem with the Intel Cpu Pentium Dual-Core E2180 2.0Ghz Fsb800Mhz 1M Lga775 Tray I have no audio driver for my pc
every other detail...but...motherboard...assuming it has onboard sound.. google drivers for the make and model of your motherboard soundcard should be there somewhere.
Apr 19, 2011 | Intel Cpu Pentium Dual-Core E2180 2.0Ghz...
I have a motherboard bus speed 533mhz support. i want to put a pentium 4 3.00ghz with system speed of 800mhz. can this be possible?
no :(, you need processor with a bus speed of 533 or lower, where do you live? you can buy a very much better, newer processor and motherboard for less than $120 now :)
Feb 13, 2011 | Intel P4 631 300GHz 800FSB 2MB SKT775 RET...
I want to upgrade my system ram size to 2gb...my system memory configuration as follows mother board: intel102ggc2 system bus speed :800mhz processor (p4):3.0ghz ram slots available:2 and presently i'm...
The below is the contents of Intel published for your board
Intel Desktop Board D102GGC2 Technical Product Specification
System Memory The board has two 240-pin DIMM sockets and supports the following memory features: • 1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts • Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMS with x16 organization are not supported. • 2 GB maximum total system memory. • Minimum total system memory: 128 MB • Non-ECC DIMMs • Serial Presence Detect • DDR2 533 or DDR2 400 MHz SDRAM DIMM
hope it helps, if so rate the solution
Nov 16, 2010 | Intel D102GGC2 Motherboard
Want to upgraded Pentium 4 2.8 GHz to Pentium 4 3.2E GHz
Yes, it will work just fine, as you can see for yourself - on the mb's link is the third processor from the second group (Prescott).
Jun 03, 2010 | MSI PM8M-V Motherboard
What cpu can the motherboard 661M03-G support?
Vendor Type FSB Frequence
Intel Pentium Northwood 400MHz 2.0, 2.5GHz
Intel Pentium Northwood 533MHz 2.4-3.06GHz
Intel Pentium Northwood 800MHz 2.4-3.0GHz
Intel Pentium Prescott 800MHz 2.8GHz
Intel Celeron Northwood 400MHz 2.0-2.4GHz
Intel Willamette 400MHz 1.8GHz
Intel
Jan 30, 2010 | Foxconn 661M03-G-6EL Motherboard
2.4GHz 533MHz FSB to 2.4Ghz 800MHz FSB
Yes, you can put any Pentium 4 or Celeronsocket 478 processor in there, including those with an 800MHz FSB onthe processor. Don't waste your time with only a faster FSB unless youjust happen to have one laying around, the performance won't improvethat much. This one is $50 from Newegg.
Upgrading the components is not overclocking. Overclocking is when youforce the components to run faster than they are rated for. Yourmotherboard is set up to allow this, through the BIOS. Severaloverclocking features areintegrated into the BIOS, including the ability to adjust the FSBfrequency, and the Vcore, DDR, and AGP voltages.
If you choose to overclock, be prepared to make frequent changes toachieve best performance vs. stability. I would suggest upgrading yourcooling to the best you can afford as well. Your PC may lock up orrefuse to boot for no apparent reason if you overclock. Be preparedfor that and know what to do about it before you start youroverclocking career.
Mar 17, 2009 | ASUS Computers & Internet
Cpu upgrade
Your computer has one of these options:
spacer.gif level2_arrow.gif Intel® Celeron® Processor 560
(1MB L2 cache, 2.13GHz, 533MHz FSB)
or
Intel® Celeron® Processor 550
(1MB L2 cache, 2.0GHz, 533MHz FSB)
or
Intel® Celeron® Processor 540
(1MB L2 cache, 1.86GHz, 533MHz FS
or
Intel® Celeron® Dual-Core Processor E1400
(512KB shared L2 Cache, 2.0GHz, 800MHz FSB)
or
Intel® Celeron® Dual-Core Processor T1400
Check the features with Acer first and see if your motherboard model support that speed processor.
Contact tech support directly to the manufacturer right here:
http://acer.custhelp.com/cgi-bin/acer.cfg/php/enduser/ask.php?p_sid=8P57rbgj
Oct 13, 2008 | Acer Aspire 5315 Notebook
Computers & Internet Logo
David Payne
David Payne
