Question about Lands Phones
Platinumcaller internet card
I cant sign in my acoount as my a/n number is having 12 digits and pin number is having 16 digit.so i cant enter the numbers in concern fields respectively
  • 1 more comment
  • prakash123 Nov 21, 2008
    The report is coming that, the sevice may be temporarily unavailable or you may not be correctly connected to the internet. Please also check any fire wall setting
  • Anonymous Dec 02, 2008
    call not going
  • Anonymous Jan 31, 2009
    I am regular customer of platinium caller, Ihave12 digits a/c number and 16 numbers pin no. but it cant accept what i do
Hi
i am unable to sign into my a/c number and pin number,b'coz they hold 12 digit and 16 digit numbers
respectively.
Posted on Oct 25, 2008
Install platinum caller
Posted on Sep 18, 2008
SOURCE:
I'd like to register my Winn Dixie rewards card
Join Plenti Rewards Program with WinnDixie ' Plenti
https://www.plenti.com/winndixie/verify-cardPlenti is the rewards program that lets you earn Plenti points at one place and use them at another, all with a single rewards card. Join for free and start saving. Enter your Plenti rewards card number and activation code below: 16-digit Plenti card number. Four-digit activation code. Can't find your card number? Card Details
Feb 25, 2018 | Computers & Internet
How can i get a pin for my greendot
Search Results
ATMs ' Help ' Green Dot Prepaid Cards
https://www.greendot.com > Green Dot Help > Using Your Card Top Searches: How do I Get Started? How to Add Money to my Green Dot card? How to Send and Receive Money on to Green Dot Card? How to Use my Green Dot Card? How to Manage my Green Dot Account? How to Direct Deposit my Tax Refund?
Forgot User ID? - Green Dot
https://secure.greendot.com/account/auth/forgot-userid Forgot User ID. Confirm your identity to receive your login info. Social security number. Please enter your social security number. 16-digit card number. Please enter the card number. CVV. The CVV is the 3-digit security code printed on the back of your card. Please enter the 3-digit security code. Submit ...
Forgot Password? - Green Dot
https://secure.greendot.com/account/auth/forgot-password Forgot Password. Confirm your identity to reset your password. Social security number. Please enter your social security number. 16-digit card number. Please enter the card number. CVV. The CVV is the 3-digit security code printed on the back of your card. Please enter the 3-digit security code. Submit.
Welcome to Green Dot!
https://m.greendot.com/activate This PIN will replace the PIN you chose when you set up your Temporary Card. You can use the same number or create a new one. Your PIN cannot be all the same digit, like 3333, and it cannot be a sequence, like 6789 or 4321. Last 4 digits of your Social Security Number. Please enter the last 4 digits of your Social ...
Help ' Green Dot Prepaid Cards '
https://www.greendot.com/help/ How do Green Dot Prepaid Debit Cards work? How much does it cost to order a Green Dot Card? How to Set up Direct Deposit on Green Dot Card? How to deposit a check on to Green Dot Card? How do I get a Green Dot Card? How to Register/Activate my Green Dot Card? How to add cash on a Green Dot Card? How do ... ‎Card Help · ‎Using Your Card · ‎Getting Started · ‎Adding Money
FAQs - Green Dot
https://secure.greendot.com/greendot/account/faqs Jump to What do I do if I have a question or think there is an error on my card? - You agree that any unauthorized use does not include use by a person to whom you have given authority to use the card or PIN and that you will be liable for all such uses by such person. For example, if you have given your card or card ...
Dec 31, 2017 | Computers & Internet
How do you access trouble codes on 2003 harley davidson deuce?
With the newer HD Security Systems using proximity FOBs where the key FOB needs to be close to the bike to start, this is now more important then ever. If the battery in your FOB dies and you have not set your Harley Alram Override PIN Code, you will not be starting your bike. It is just as important for those with oler Harley Davidsons with the push button alarm FOB. It you set your alarm and the battery dies before you return to your bike, again you will not be starting the bike.
If you haven't set the PIN over ride for your HD security alarm system...do it now! Here's how you do it...
(To view how to deactivate the security system with the manual PIN code, see below.
Setting or Changing Your Security System Alarm Override PIN
Button less fobs (Smart FOB)
1. Select 5 digit code ( each digit being a 1 thru 9) and record it on the wallet card in the owners manual.
2. With an assigned FOB present, turn IGN key ON - OFF - ON - OFF - ON
3. Press Left turn signal switch 3 times.
4. Press Right turn signal switch one time and release.
*Turn signals will flash 3 times. Current PIN will appear in the odometer. The first digit will be flashing.
5. Enter first digit (a) of the new PIN by pressing left turn signal (a) times.
6. Press right turn signal 1 time and release.
*The new digit (a) will replace the current in the odometer window.
7. Enter second digit (b) of the new PIN by pressing left turn signal switch (b) times.
8. Press right turn signal 1 time and release.
*The new digit will replace the current in odometer window.
9. Enter the third digit (c) of the new PIN by pressing left turn signal (c) times.
10. Press the right turn switch 1 time and release.
*The new digit (c) will replace the current in the odometer window.
11. Enter forth digit (d) of the new PIN by pressing left turn signal switch (d) times.
12. Press the right turn switch 1 time and release.
13. Enter the fifth digit (e) of the new PIN by pressing left turn signal (e) times.
*The new digit (e) will replace the current in the odometer window.
14. Press the right turn switch 1 time and release.
15. Before the module rearms, turn ignition key to OFF.
* The odometer will return to mileage display.
**Turning the ignition to OFF stores the new pin in the module.
Push Button fobs
4. Press button on fob twice
5. Enter first digit of the new PIN by pressing left turn signal until the desired number appears.
Press button on fob twice to enter number.
6. Enter second digit of the new PIN by pressing left turn signal until the desired number appears.
7. Enter third digit of the new PIN by pressing left turn signal until the desired number appears.
8. Enter forth digit of the new PIN by pressing left turn signal until the desired number appears.
9. Enter fifth digit of the new PIN by pressing left turn signal until the desired number appears.
Turning the ignition to OFF stores the new security PIN.
Using the Security Alarm PIN Override to Start Your Harley Davidson
1. Turn the IGN key to IGNITION and immediately hold both turn signal switches until 5 dashes appear in the odometer window.
2. Enter the first digit of your PIN (a) by pressing the left turn signal switch (a) times.
3. Press the right turn signal switch 1 time to move to the next digit.
4. Enter the second digit of your PIN (b) by pressing the left turn signal switch (b) times.
5. Press the right turn signal switch 1 time to move to the next digit.
6. Enter the third digit of your PIN (c) by pressing the left turn signal switch (c) times.
7. Press the right turn signal switch 1 time to move to the next digit.
8. Enter the forth digit of your PIN (d) by pressing the left turn signal switch (d) times.
9. Press the right turn signal switch 1 time to move to the next digit.
10. Enter the fifth digit of your PIN (e) by pressing the left turn signal switch (e) times.
11. Press the right turn signal switch 1 time to move to the next digit.
12. Press the right turn signal switch one time and the security system alarm is turned off.
May 20, 2014 | 2003 Harley Davidson FXSTDI Softail Deuce
Samsung puk code and pin number
Lisa, PUK codes and PIN codes are not associated with phones. Rather, they are a function of your network. That is to say, they are related to your sim card.
Pin codes are a range of 4 to 6 digit numbers initially assigned to your sim to enable you lock and unlock it. You could change this to digits of your choice.
PUK codes are some 10 digit code, also assigned to your sim card by your network providers, (but which unlike pin codes can't be changed).
If in the event of trying to enter your PIN, you enter the wrong number 3 times in a row, your sim would be blocked, and would prompt you for your PUK code.
The correct PUK code must be entered, because after the 10th wrong attempt, you line would be blocked permanently.
Now, if you check your original sim certificate, you would find both your PIN and PUK. But in case you cant find it, contact your network providers, they should provide you with the codes, and when they do, write it down and keep somewhere safe.
I hope that helped?
Have a lovely day.
Jun 08, 2011 | Cell Phones
Where can i get the unlock code for lg dlite or gd570 it keeps saying to enter the puk code also it says pin code blocked
Hello - The PUK code is the 16 digit code that can be found --
1 On the original Box (bar code) for the phone or 2 The long number (16 digits) next to the SIM card inside the phone or 3 - Press (star) (hash) 06 (hash) on the keypad.
This will solve the PUK number - the PIN number is the 4 digit security code that you would have set when you first purchased the phone.
Try -putting back to factory settings and re-setting to ZERO -- Ray
Mar 07, 2011 | Cell Phones
Wrong pin i entered on ma new phone
if its troubling u abt pin code and if u dont remember it, then u've a very simple procedure.
Read this section & u'll surely be able to enter a new pin code.
Enter Pin code of ur wish, u just need to block the sim so that ur phone asks u PUK code.
i guess pin code tries are abt 5-7 times.
So it will say Sim card Blocked Enter PUK code.
Now call to customer care from other number of same newtork provider & ask then ur PUK code.
they will ask u a 16 digit code, which is printed on ur sim card. after u provide 16 digit code to customer code, they will provide u ur PUK code,
Enter the PUK code given & now enter ur New pin code.
This is quite lenghty process but 110% working.
If u like my post, please rate me up, i really need some good ratings..
Thanks.
Sep 02, 2009 | Lands Phones
Puk code comes up cannot get a code to unlock it
PUK stands for PIN Unblocking Key, and occurs when you enter the PIN incorrectly three times. If you get this status message, you must call your mobile phone carrier to get the PUK, which, when entered correctly, will allow you to enter a new PIN.
If you enter the PUK incorrectly 10 times, you will have to visit a carrier store to get another SIM.
Jun 26, 2009 | Pantech C810 Pocket PC
I need my 4 digit id code b 4 i can get my puk number but i forgot it
you have to phone 07973100450 from a land line. it will ask you for your phone number a few times then it will pass you to  a REAL person who will ask you ask you a few security questions like what are the last four numbers of your top-up card and vol lia that is how you get your four digit id code!!!!!!!
Feb 22, 2008 | Nokia N73 Cellular Phone
Replacement flash card connector
I had the same thing happen... broken pins. I purchased a card reader at Wal-Mart.
Take your pics, pop the card out of the camera, pop it into the card reader and plug into your pc to upload.
Sep 18, 2006 | Konica Minolta DiMAGE S414 Digital Camera
Lands Phones Logo
579 people viewed this question
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
