Question about Refrigerators
Refrigerator fan not working. Cooling not effective
  • 17,970 Answers
I suggtes start checking this link troubleshooting about "refrigerator is running but not cold enough"....
Keep us updated.
Posted on May 22, 2011
Freezer not freezing but cools like the refrigerator would. Refrigerator not cooling enough. the cover in the back of the refrigerator was off. I reconnected but the freezer still won't freeze
is the freezer fan running? is there frost on the rear freezer wall if so it would be a defrost issue. if no frost on freezer rear panel it would sound like a bad compressor or sealedsystem leak.
Jun 06, 2011 | Kenmore Top Freezer Refrigerator
Side-by-side refrigerator - freezer is working just fine, but the refrigerator is not cooling.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 27, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Frigidaire frs26r4a the freez and fridge stoped cooling found evaporator was cold but fan wasnt working replaced fan still did not work whats keeping the fan from working thanks
Either the defrost timer or the door switch...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Sep 19, 2010 | Frigidaire FRS26R4A Side by Side...
My Refrigerator has cooling problem. The evaporator not working properly, actually compressor working well and cooling system is working OK. The evaporator fan time to time stop and not working and other...
ok the evap moter will only run went the doors are closed and a standared run time for a defrost is 20min every 6 hours if no electronic pc boards are in effect
Aug 10, 2010 | Bosch KSU49630 Top Freezer Refrigerator
Refrigridaire Galleria Refrigerator is not cooling
ck your FAN in back of freezer / and also the dampner in top of fresh food area . if these ck ok the pc board needs replacement ( called the jaz board . ) the jazz board is verry common for your problem .. mm.
Dec 11, 2009 | Maytag MFD2560HES Bottom Freezer French...
Freezer working fine although refrigerator not
I assume you have tried adjusting the refrigerator temperature level.
If this has no effect, check the fan inside the freezer compartment. This fan must operate properly for cold air to be distributed throughout the freezer and refrigerator. It should be behind an access plate in the freezer. If the fan is turning, you should be able to hear it. If you can't be sure, remove the access plate and look at it. If it's not turning, the fan motor must be replaced.
Oct 18, 2009 | Refrigerators
Fridge is no longer cooling. ER where the
Sounds like the FF(Freezer Fan) is wearing out or is worn out. This assembly supplies the circulation for the freezer as well as the refrigerator. When is slows down or stops the circulation of cold air to the refrigerator is the first thing that is effected. The minimum cost to replace this assembly is around $300.00
Jul 10, 2009 | LG LRBC22544 Bottom Freezer Refrigerator
Fan is not working and fridge is not cooling
heatman101
ARHGADF
Jun 03, 2009 | Amana ARB2557CSR / ARB2557CSL Bottom...
Top refrigerator part not cooling, bottom freezer and fan working
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Nov 26, 2008 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
