Question about Dell Latitude D505 Notebook
My latitude D505 have two blue verticale stripe on the screen, about 2 and 4 inches from the left side. If I add some physical preassure on the upper left hand side of the screen they dissapeare. When loosen the preassure, the stripes are back. I have checked the the cables, and there are no bad connection or other defects with the cables. I have dissambled and assambeled the display a couple of times without finding anything wrong. Must be a bad connecton somwhere, but I don`t know how to find it. Can you please help me? There are a trim screw at the back of the screen, do you know what this is for?
  • 53 Answers
The screen seems bad, happened to me a few times on a few laptops
Posted on May 22, 2011
Dell Latitude D505 half of screen is black with colored vertical lines.
Sounds like you have a section of dead pixels. This can happen if the laptop has been dropped a lot or stepped on or some type of impact on the laptop. This is a hardware issue. You will need to have the screen replaced. In my opinion, by the age of the laptop, its better off getting a new one.
Oct 01, 2014 | Dell Latitude D505 Notebook
UN MOUNTABLE BOOT VOLUME ERROR - BLUE SCREEN on a dell latitude D505 laptop
try to boot to safe mode using F8 key on boot and then recover system or reinstall OS
Nov 13, 2012 | Dell Latitude D505 Notebook
How do I adjust brightness on my Dell Latitude D6...
Look for a key labeled "Fn" (blue lettering) on the lower left side of the keyboard
Hold the "Fn" key and then use the Up/Down arrows to adjust brightness.
If that doesn't work, reboot your laptop and get into the BIOS. There is a screen for brightness. I don't recall how it is labeled, but it's one of the last pages as you cycle through the BIOS options.
May 20, 2010 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Hello, on my screen i've got 2 little verticale lines with the collors yellow and pink/red. i put a extern screen on my laptop and i don't have hem anymore. so can you help me
Hi there! Try these things,
Since you have already tried to put an external monitor and you didn't see the vertical lines, there's a high
chance that your lcd is having a problem,
because when you plugged in the external monitor that is the test to check the video card,
try to run the lcd bist on the lcd,.. while the computer is off press and hold D + power button at same time,
you should see colors flashing then after that in that test you should see the vertical lines if not then go to bios setup that will be f2 when you turn on the computer.
hope this helps!
Feb 28, 2010 | Dell Latitude D505 Notebook
A pink-blue stain has appeared on the screen of my laptop
the screen may be physically damaged, or the cable that connect the screen to the rest of the stuff
Sep 23, 2009 | Dell Computers & Internet
Dell Latitude D510 Screen Failed
The 14.1" inch screen is compatible with Latitude models D500, D505, D510, D600, D610 and Inspiron models 500m, 510m, 600m.
You may also need a screen inverter - in fact that is often the reason a screen is considered to be failing. The lcd inverter can be one of the most common items to become defective in a laptop computer. You may need a lcd inverter replacement if your screen is dim, dark, colored oddly, blinking, flickering or has dark stripes. Just something to keep in mind.
Hope this helps,
Chris
Mar 20, 2009 | Dell Latitude D600 Notebook
Keyboard variance
Click on start then control panel the there are three things you need click on the language and change to the one that is closes to you (English/American?) also change the setting under keyboard and the third thing you need to do is open a program MS Work will do and click on the grey area near the bottom and changed to English/American the last one is for spell check
Jan 22, 2009 | Dell Latitude D505 Notebook
2" vert. red stripe
I have worked on many Vizio televisions under warranty and what you are descriping is often a result of the X boards going bad. If the telelvision is under warranty, contact Vizio at 1-877-MYVIZIO, if it's no longer under warranty, the cost of repair is probably going to be more than the cost of a new tv unfortunatly. I always recommend buying the extended warranty's with these televisions.
Oct 04, 2008 | Vizio P4 46 in. HD-Ready Plasma Television
Blue vertical stripe
The bad news, it sounds like tou have a bad plasma panel.One of the vertical drive arrays are in the process of failing.This part is part of the display panel.
Mar 02, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Dell Latitude D505 Notebook Logo
60 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
