Question about Ac Delco Vehicle Parts & Accessories
I am trying to replace the CD player, AC delco part # 3596429c1, in the 2007 international dt466 I drive for work. There are 10 green wires, one blue and one white that come from the truck and I need to know which are speakers, powers and ground. Thanks for any help
  • 158 Answers
SOURCE: Power IC Damaged Displayed
if it displays "power IC damaged ,your CD player is as good as DEAD.
For giving it a new life ,take it to PIONEER SERVICE and get the IC replaced and any other repairs that may be needed.
Posted on Jul 25, 2008
  • 4234 Answers
SOURCE: New speakers to an old (1960s) record player
It is difficult to say with 100% confidence because the pictures are out of focus, but it looks like you have just a regular turntable. The wire connections you show are the bridge between the tonearm and the external RCA style cables. The extra wire (#5) is the ground wire. You should be able to connect this to any receiver that has a phono input.
For confirmation, can you update this with the model number of the turntable? That will allow me to confirm what I have stated above.
Thanks,
Dan
Posted on Nov 13, 2008
Tech Jenkins
  • 359 Answers
SOURCE: where do you connect the blue wire
Next time don't lose the instructions.....
Black is your answer...
If just simply hooking the blue and black together with the black from the switch/power supply does not work you need to replace the wire going to the fan with a 12/3 wire(white,black,red,ground) along with a switch, what you have now is a 12/2(white,black,ground)
Here is the following way it should be hooked up using 12/3 romex to the fan from wall switch.
White,Black, ground power supply
Make sure 12/3 is fed to the fan location.
From the power you Y off the black to the red with a piece of red wire to the switch.
Then from the switch is red wire.
Then at the fan red connects to blue, black connects to black, white to white, and ground to ground.
Posted on Nov 15, 2008
  • 328 Answers
SOURCE: cd player install in my truck
there are install kits that you can get that have a factory plug on the end that plug directly into your truck and the wires at the other end are color coded the same as the radio so then its a matter of matching colors and taping the wires together
http://www.tune-town.com/wire/1973-87_Chevrolet_Blazer_(Full_Size)_NOVA7016771_CWB7116771.htm
this one is for a 73-87 full size blazer but it also fits full size pickup you didnt say if your truck is full size or not .......if you have an s10 it is also available at that site
hope this helps
Posted on Dec 31, 2008
johnny5846
  • 379 Answers
SOURCE: 1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
cheers
djmac62 is also an excellent answer
Posted on Jan 10, 2009
2000 delco Toyota radio schematic
Anonymous,
Go to
http://www.the12volt.com/
Look at the top under "Vehicle Wiring" and search for your car.
Press the tab that says "Car Stereo" and Presto, lots of good information. I hope this helps, Ray
Mar 01, 2015 | Ac Delco AM-FM Radio Cassette
I'm trying to fix my Delco stereo on Chevy Malibu '99. When i bought this car the stereo was not even connected. So i connect it and it does not work and does not show anything. Only if i press hr, mn and...
http://electronics.kellysearch.com/profile/doctor+don's/us/tx/huntsville/77320/900324575
Try Doctor Don's. He is an AC Delco expert who can repair a lot of AC Delco radios. He put some new amps into my Radio/CD player for my 1990 Cadillac Deville so it would play in my AC Delco Radio's place. He really knows what he is doing when it comes to radios.
www.doctordons.com is his website.
Good luck on this repair.
Jan 14, 2011 | 2001 Chevrolet Malibu
Trying to wire in a 92 chevy s-10
Buy a wiring kit for your vehicle (available at walmart, autozone, etc) It takes the guess work out of which wire is which coming out of your dash.....Panasonics wiring is standard to that of other cd decks....Red=ignition Yellow=memory or battery Black= ground Blue=remote turnon for amp or antenna, Orange=illumination, Then the green, white, grey & purple wires are speakers (positive and negative).
Sep 19, 2010 | Panasonic CQ-DP133U CD Player
2004 truck delco radio 5 disc cd player. cd
Common for the CD to get stuck on the Delco radio, Try resetting the radio by disconnecting the battery for 5 min and then reinstalling the cables. This will reset the radio and you should get your CD to work again, if there is an issue. You going to have to go to the dealer and they are going to have to use a Tech2 scanner to reset and reprogram the radio. If there is any mechanical issues the Tech2 scanner will identify the issues, but 90% of the time. It's just a simple reset and the other 10% is a reprogram or replacing the unit.
Thank you for using fixya and good luck.
May 09, 2010 | 2004 Chevrolet Suburban
Sony cd player, CDX-3100 wiring diagram
This is the pinout shown on the Sony website for the CDX series players. Pin numbering is as follows:
1 2 3 4 5 6 7 8
9 10 11 12 13 14 15 16
This is looking at the connector with the wires towards you.
Pin Number Wire Color Description
1 White Left front +
2 Green Left rear +
3 Purple Right rear +
4 Gray Right front +
5 Blue/white AMP Remote
6 Blue ANT Remote
7 Red Accessory
8 Black Ground
9 White/black Left front -
10 Green/black Left rear -
11 Purple/black Right rear -
12 Bray/black Right front -
13 Sky blue ATT
14
15 Orange/white Illumination
16 Yellow Battery
Feb 24, 2010 | Sony Car Audio & Video
Compaq 701tu cd drive does not spin
check if the green light comes on when you insert a disk,if no?
1. switch off the pc,
2. open the case cover
3. check the power cable is connected to the device"compaq 701tu cd drive"
4. if still not working
5.try other cd device and if that work,it means your compaq 701tu cd drive is faulty and to be replace.
Jul 31, 2009 | Sony CDU 701 (CDU701-10) Internal 32x...
Clarion vrx 485 vd.tuner works with amp but cant get dvd or cd to play with amp.screen works cd an dvd are playing but no sound.an with key off tuners playing till i open door?what have i hooked up wrong?
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
grass green handbrake but if u want to play dvd's
whilst u drive connect this to earth
pls rate people arnt rating hope this helps
it sounds like you have hooked the power wires up wrong try trace back your wires with this diagram
Mar 29, 2009 | Clarion VRX485VD Car DVD Player
How to wire up g.m. radio cd stereo?
If plugs do not match, here are the color codes:
BLACK PLUG
Orange-12v constant
Yellow: 12V acc (be careful. There are 2 yellows.The other is a speaker wire. Use the wire that turns on with the key.)
Gray:Illumination (be careful. 2 grays. the other is a speaker wire. Use the gray wire tht turns on with the lights)
Black: Ground
Brown: Digital Illumination (BCareful. There are2. One is a speaker wire. Use the one that lights up with dimmer switch)
WHITE PLUG
Tan: LF+
Gray: LF-
Lt.Green: RF+
Dk. Green: RF-
BLUE PLUG
Brown LR+
Yellow: LR-
Dk Blue: RR+
Lt. Blue: RR-
Laterz,
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 27, 2009 | Car Audio & Video
Stereo theft
try this to see if the right wires are there it normally cost about 130 to get a professional to do it
Radio Constant 12V+ Wire: Blue/Yellow
Radio Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Dark Green
Dimmer Wire: White/Green
Antenna Trigger Wire: None
Front Speaker Size: 6 1/2′
Front Speaker Location: Doors
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Green
Right Front Speaker Wire (-): Blue
Rear Speaker Size: 6′ x 9′
Rear Speaker Location: Rear Deck
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
May 25, 2008 | Sony CDX-F7710 Car Audio Stereo CD MP3...
Vehicle Parts & Accessories Logo
16 people viewed this question
Top Ac Delco Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Andrew Gaitan
Level 1 Expert
tfelton3
Are you an Ac Delco Vehicle Part and Accessory Expert? Answer questions, earn points and help others
