Question about Audiovox D1210 Portable DVD Player with Screen
What kind of external antenna do you use and where do you connect it?
    Top Expert:
  • Audiovox Master
  • 74,232 Answers
Hello
It is best to use a yagi antenna. It is highly directional, but if direction is in right way, it will give you best clarity picture. The signal strength will be greater than other type of antennas. OK.
Posted on May 22, 2011
How would I attach an external antenna?
The manual may be generic, covering a number of models with and without external antenna connection provisions.
Aug 26, 2015 | Radio Communications
I can't get my swr to go down on my general lee cb radio
what kind of antenna do you have? Does it have antenna adjustment screws on it or is it a fiberglass antenna? If it is an adjustable antenna you have to raise the whip or lower it depending on what you have for a reading . Use an external SWR meter,don't go by the one on the radio,that's just for quick reference .Get the match down to at least 1.5 - 2 and you are good but now, if its a fiberglass antenna ,some have an adjustment screw others don't. If it doesn't have a screw on the tip and you have to shorten the antenna you will have to trim off some of the tip but if you have to lengthen it you may want to add a spring at the bottom connection to your mount.
Aug 11, 2015 | Radio Communications
I have a old raymarine c80 navigation sometimes it gives me a fix when i turn it on and sometimes it will not. Do i need a new antenna if so what kind.
The issue is related to the antenna, either bad connection, low voltage or faulty gps. Start by checking the voltage supplied to the antenna (most probably through SeaTalk from the plotter), if you find this to be 11V or bellow - beef it up by adding external 12V. You can also check the wiring, if all looks ok - it is time to get a new gps antenna. Raymarine has a retrofit pack for the new RS130 which also includes SeaTalk ng converter. With some luck it's only the power...
Oct 22, 2013 | Raymarine C80 GPS Receiver
How do I switch from cable to external anten ae
Is it a satellite antenna or regular outside antenna ? What kind of cable do you have? Is it dish network or cox, cableview, radio shack?
Aug 15, 2013 | Toshiba Ct885 Remote Control
Yes i order an antenna adapter for a 2005 dodge dakota.. The end that goes into the radio fits perfectly but the end that attaches to the antenna itself will not fit.. the antenna has a round black plastic...
The adapter is not exactly the same which is required.but yes you can get the external connection for adapter which will fit in adapter and also get connected to the antenna.You will have to get this external connection from
www.walmart.com or from
www.radioshack.com
check out.thanks.
Jun 05, 2010 | Car Audio & Video
My radio wont stay playing it keeps cutting in and out like wires are wiggling even when not moveing any ideas
You need to check the connection of your car radio to the external antenna for reception issues. Ensure that your speakers are also well connected and your tuning knob is not broken.
Thanks & Kind Regards
Oct 19, 2009 | 2001 Isuzu Trooper
How do I connect an external radio shack AM enhancer
I presume that you wish to connect an external antenna/aerial to a portable radio with no antenna connection. Wind several turns of your antenna wire around the telescopic antenna - should work ok!
Mar 30, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
How do I see the rest of this solution? Garmin Nuvi 660 GPS Receiver Problem: Garmin Nuvi GPS won't acquire satellites Solution by: wingflinger (1 solutions) There is a known hardware bug in the...
you should see it now
There is a known hardware bug in the Garmin 600 series relating to the detection of the connection of an external antenna. The GPS is supposed to do this automatically and when it detects an external antenna plugged in it switches out the internal antenna. Unfortunately, this circuitry doesn't work correctly in some versions of the unit and sometimes it get's comfused and thinks there is an external antenna connected when there is not. This causes the behavior you describe because, for all practical purposes, there is no antenna connected.
Garmin can fix this and they've been known to fix it even on units that are out of warranty. There is a fix that can be done by someone with the right equipment and know-how which requires disassembling the unit and bypassing the antenna switch. Not to be attempted by anyone not experienced in micro surface mount PCB re-work.
Wingflinger
Dec 12, 2008 | Garmin GPS
Toshiba
There are no connectinos for an external antenna on your laptop model sorry.here is a picture of what it looks like though: The connectors at the top for the antenna cables. If you know someone that is an electronics guru, then order another card ( just in case ) for about $15 + shipping, and have him/her connect
those wires to a TMC or SMA connector somehow. Otherwise,.. just buy a good quality USB Wi-Fi adapter with an external antenna. ( which wouldn't cost much more than the spare Toshiba card and less if you figure in what a good dB gain antenna costs)
Feb 24, 2008 | Toshiba Tecra M2-S730 Notebook
Audiovox D1210 Portable DVD Player with Screen Logo
46 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
romy sibug
romy sibug
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
