Question about NAD T742 Receiver
Have a HD cable set-top box and a blu-ray player both of which would be better with HDMI input and of course an HDMI out to the TV. But the NAD T742 doesnt have any HDMI in/out. Any idea how I can fix this?
  • 961 Answers
If this is your system;
http://www1.epinions.com/specs/pr-NAD_T742_5_1_Channel_Home_Audio_Receiver
It has two "digital optical" inputs for sound. The video doesn't need to pass through the receiver so, your HD components, box and Bluray player, should hook to TV directly then, providing your TV has digital optical out, you could run your audio out of the TV from a digital optical out, to receiver. This would allow you to select your video through your TV's menu and the sound would come through the receiver through the one input. You can pass your video through the receiver but, it doesn't have the best outputs to handle it. You also may notice lags beteween the audio and video if you go this route.
Posted on May 22, 2011
I have red,yellow& white come out my dvd and only white & red plug in on the back of my tv how do i make that work and which source and channel i put the tv on
Red and White are audio, yellow is video. On the back of the TV there should be a yellow jack if it takes external inputs. There are two ways to connect your Blu-ray Player to your amplifier. Via HDMI output: Connect the player's HDMI OUTPUT to the corresponding INPUT on your amplifier using an HDMI cable. If your amplifier has an HDMI OUTPUT, connect that to the HDMI INPUT on your TV using an HDMI cable. See if these links help.
Five Tips to Successfully Set Up Your Blu ray Player How to hook up your Sony Blu ray player to TV How to Connect TV to Blu Ray Player CONNECTING YOUR SMART BLU RAY PLAYER TO YOUR TV
Obviously if you gave better information you would get a better answer.
May 30, 2016 | Televison & Video
Tip
So you just got your new HDTV and the piture isn't as good as you thought.
There are some things you need to know when setting up your HDTV.
First off, you need to use HDMI cables to connect your tv to your cable box or you will not get HD. That being said the first thing you will find is that HDMI cables are expensive. Although you can buy a really cheapo cheap one, be careful. Make sure it can support 1080p or the max resolution your TV displays at. Some of the cheaper ones can only support up to 720p.
So you hooked it up to the cable box using an good HDMI cable and you still do not have the picture you should. There are a few things you may still need too do to get 1080i out of it. Yes, I said 1080i. Even though your tv may be up too 1080p, cable and dish networks only transmit up too 1080i. But don't worry, 1080i is amazing for cable/dish.
First thing you need to make sure of is, does your cable/dish receiver support HD? If you have had the same box for a long time, it may not. You will have to call your provider to get an updated box. If you recently got cable/dish and the box is new, most likely your good to go. Also, it will most likely say on it, HDTV, 1080i or something related to HD on it.
Now you are good to go with you box because it is in fact HD compatible. Some cable boxes may need to be configured for HD. You don't need an HDTV signal if you don't have an HDTV, and not every one does, so why send the unit configured for HD. You need to go into your cable/dish settings and make sure you set the HD set up to display in 1080i.
Okay you set the box to 1080i. There still could be some setting on the TV if your not getting the best picture.
Make sure you are on an HD channel. Make sure you do not have zoom on, and that the TV is set to display an aspect ratio that is determined by the program, or auto. Not all TV's have these settings. Likewise, some tv's allow you to select the max resolution, if this is the case make sure it is set to 1080p, the max it can be.
You should at this point have an excellent picture on the HD channels. Not all channels are HD.
Now, a few other things not worthy as a new owner of an HDTV.
a standard dvd player does not play in high def. they have a max resolution of 480p. 480p is going to look really good if its the first time you watch a dvd on an HDTV, but it can be a lot better. For around starting at $45 and up, you can buy a DVD player that can upscale your dvd's to 1080p when you use HDMI and you will get amazing picture. But for around starting at anywhere from $100 to $150 and up, you can get your self a blu-ray player that will play blu-ray disks, and give you amazing beyond belief picture, and it will upscale your dvd's.
So you got a blu-ray. First thing I can say is I hope your refresh rate is at least 120hz or better. 60hz may disappoint you with a blu-ray player.
Blu-ray can play movies in their native 24 frames a second format of which they were filmed in. However, at 60hz, you will run into a problem trying to play the movie in 24fs. now I am not going to get technical with this, just to let you know, you need 120hz or better to use 24fs. You can turn it off, but you will get blur and it will not be as smooth. As well, with most players you must enable 24fs in the settings, usually by default, it is off,
So to recap:
  • Make sure your cab/dish box is HD compatible.
  • Always use HDMI cables.
  • Check settings on cable/dish box and make sure its set to 1080i.
  • don't use zoom.
  • If applicable, make sure tv settings are at max res of 1080i
  • you need an upscaling DVD player or Blu-ray player to watch your DVD's in HD.
  • Also must us HDMI.
  • Can't use 24fs if you have 60hz refresh rate, but can if 120 or better.
  • 24s is usually off by default.
on Mar 06, 2010 | Televison & Video
Why is there no power to DVD box?
Check your power cord and plug for damage, do a wiggle test with DVD plugged in and see if it comes on while moving and bending wire plug. press the helpful button
DVD power supply repair tips
Press Release Consumer Electronics Video Audio Camera TV
DVD Player Repair Guide Covers Every Detail
Jan 26, 2016 | Televison & Video
How do I hook-up Netflix through a Sony Blu-Ray player and a LG television
If your Sony Blu-Ray player and LG TV are recent models, each should have an HDMI cable connection. HDMI is an method to connect your digital video and audio devices with just a single combined cable. In the case of your LG TV, using an HDMI cable will allow you to send the HD video signal to your TV's screen, and allow you to hear the sound through the TV's speakers.
Your LG TV may have multiple HDMI connectors, to allow other devices to send signals to your TV, such as a cable box or satellite box or digital video recorder (DVR). Your Sony Blu-Ray player will usually have just a single HDMI connector.
Purchase an HDMI cable from your local electronics store. There are different versions of the HDMI specification, and you should get a cable that you can verify is certified for the HDMI version 1.4 specification.
Plug one end of the HDMI cable into the Blu-Ray player, and the other end into one of the HDMI connectors on the TV, noting which one you selected.
When you turn on your Sony Blu-Ray and your LG TV, you should use the remote for the LG TV to select the input source. Your LG remote should allow you to select the HDMI input connector you used, at which point you should see the display of a DVD playing on the Blu-Ray player. If you cannot hear the sound, use the LG remote to increase the TV volume.
Mar 02, 2015 | Netflix
Can not get my hd channels to work. other tv in house also with hd channels works fine. regular channels working but the hd chanels are not working. not sure what to adjust or why.
You can't change the resolution on the television itself. You change the resolution on whatever you have connected to the television. Let's say it's a cable box or a blu ray player you've got connected to the television. First off you have to connect it to the television with a component (green, blue, red, white, red) cable or an hdmi cable. Then you make sure it is only connected to the television with either a component cable or an hdmi cable. This may sound ridiculous but there are some people that have their cable boxes and blu ray players connected to their televisions three different ways ( an hdmi cable, a composite cable, and a component cable) when they only need to have it connected one way.
Select the proper input on the television. Set the cable box or blu ray player's resolution to 1080i or 1080p (in the case of the blu ray player if it the tv will allow it).
Jun 08, 2011 | Pioneer Elite PRO-1140HD 50 in. Plasma...
I just got the Toshib 46rv530u and can't figure out how to get it to change video to 1080p
hi,
1080p full hd video can obtain only through hdmi. for that u need a full hd blue ray player or full hd sat receiver . the tv automatically changed to full hd according to the input connecting to it .go to hdmi setting and check whether hdmi connectivity is ON. also check the hdmi setup of ur input device.
ok
Dec 16, 2010 | Toshiba REGZA 46RV530U LCD TV
Just connected our directv hd receiver to the tv via component cables, because we just bought a blue ray player and the only output for that is HDMI and since there is only 1 DVI input we had to change the...
You may be able the settings of your directTV box to stop frustrating you. If you help me identify the model you are using, I can research the proper menu choices you will need to choose to select the correct features. There are many different directTV set-top boxes available.
My own home theater setup did the same thing, and my solution was to use component cables from the PVR instead of HDMI cables. It is too bad your blu-ray doesn't allow for this configuration.
My work-around until I realized that using different interconnects fixed the problem, was to turn the TV off and then on again whenever switching from HD to non-HD sources. This fixed my problem, maybe it will fix yours.
I hope that helps.
Mar 28, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Cable TV blinks on and off when connected to my Onkyo receiver.
I have the same problem.  It only occurs with my HD DVR (HDMI cable), not my blue ray (HDMI cable), or my xbox and wii (component video).  Video and audio cutout is random and drives the family nuts.  I am desperate for a solution.
Mar 21, 2010 | Audio Players & Recorders
HDMI and or Receiver problem
While Bluray pluged into the TV change the resolution from AUTO to 720P then plug Bluray back to the receiver and see if it solve your problem.
Nov 27, 2009 | Hitachi 51F59 51" HDTV Projection...
I have the following hardware: Marantz SR-4003 Receiver, Samsung LN52A650 HD TV, Samsung BDP-1500 Blu-Ray player, Scientific Atlanta Explorer 8300HD cable box, two Paradigm Millenia 20 LCR Bookshelf...
Remove the HDMI cable (out) to the speakers from the receiver.
Connect regular speaker wire from the receiver to the speakers.
Of course, remove the (now extra) HDMI cable from the tv.
That will remove the loop.
Jan 25, 2009 | Marantz SR-5600 Receiver
NAD T742 Receiver Logo
169 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
