HP2320 mfp worked fine for 4 to 5 months but now wants to run the cleaning cycle after every three to four copies
  • Russ Austin May 23, 2011
    I install new firmware dated 20110228 and continue to have the same problems. I also use OEM Cartridges
  • 1,915 Answers
Are you using OEM HP cartridges or remanufactured ones? As well, how current is your firmware on the printer? They may have made some changes that will fix this problem.
Posted on May 22, 2011
  • Mark Schmit
    Mark Schmit May 23, 2011
    Is it a cleaning cycle or a calibration cycle it tries to run? There is an issue with these units always calibrating after prints. HP's website is down right now so I cannot access the solution, but I have had a customer whose unit would continually calibrate.
  • Russ Austin May 24, 2011
    There is a way of stopping automatic calibration in the set up menu and I have turned off the calibration. This is a cleaning cycle and I do not see any way of turning it off. There is an option in the set up menu to run a cleaning cycle, but no way of turning it off.
Kenmore 417.43142200 final spin is slow
obviously the timers contacts are bad so replace the timer.
May 16, 2017 | Kenmore 43142 Front Load Washer
My Neptue dryer wont dry unless I run it more than one cycle. model no. mdg5500awq. all lights work and seems to run fine it just wont dry the cloths unless I run it at least twice and jeans are three or...
Turn dryer on and go outside to the vent and check for a good amount of air coming out. If you do not have a good amount of air coming out, take the exhaust tubes apart and clean.
Jun 07, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Hello, I have a Samsung DLP HLR5667 and it blew a lamp 4 months ago, I replaced the lamp and it worked fine for about 2 months and started shutting off after only running for about 90 seconds. I reset the...
You need to replace your color wheel. This is a very sensitive part and you need to take care when replacing. If you feel comfortable I can walk you through it. If not, I would take it to a authorized service center.
Apr 18, 2011 | Samsung Televison & Video
Black particles coming in when I wash my clothing
Lol! I just had this same issue! It's called "Scale," This is caused by hard water. You can fix this several ways. 1. Filter your water, 2. Filter your washing machine, 3. (This is what I did) Put an entire gallon of vinegar into the machine and run a wash cycle. If you watch, you'll be amazed....it will clean most of the scale from the unit. Run another cycle after this and you will be fine for a while. The acid in the vinegar attacks the scale and breaks it down. Most likely, your toilets and bathtub have scale stains as well....right? Yup! So now I do a gallon of vinegar every three to four months and all is well! Hope this helps! : )
Jan 07, 2011 | Washing Machines
Machine will not brew all of a sudden was working fine for months, what happened?
you probably need to descale it. Run white vinegar thru it for three cycles, then leave the last cycle in overnight with machine on. In the morning run three cyclkes of plain water thru it and it should work again
Aug 30, 2010 | Keurig B70 Coffee Maker
Honda Tiller revs and works for 30 seconds and then shuts down.
Hello. you have some gunk in the carburator. Get a can of starter fluid or carburator cleaner aerosol and a helper. Remove the air filter and start it up. Spray a little starter fluid into the air cleaner to keep it running for three or four minutes and the problem should clear. If it does not clear the carburator will have to be disassembled, cleaned and rebuilt. j.
Jun 16, 2010 | Honda 25cc 4-cycle Mini Tiller
LaserJet M4345 MFP Printer: how to cold reset in HP LaserJet M4345 MFP...
walid_sayed@hotmail.com
To perform a cold reset
1 Turn the MFP off and then on.
2 When the memory count appears on the control-panel display, press and hold 6 until all three
LEDs flash once and then stay on. This might take up to 20 seconds.
3 Press 3 four times until COLD RESET appears on the control-panel display.
4 Press 6 one time. The MFP continues its initialization sequence.
May 07, 2010 | HP LaserJet M4345 MultiFunction Printer
It takes my whirlpool dryer three or four cycles to dry clothes
Kenmore Dryers are almost all the same therefore am sending this;
http://www.youtube.com/watch?v=lHkIK8oy1K4
How to Clean a Dryer Vent Video
http://www.youtube.com/watch?v=5Dj4im31lRY&feature=related
Why is so inportant to clean the lint?
http://www.youtube.com/watch?v=9kxbF31Oh4s&NR=1
It was helpful?
May 15, 2009 | Whirlpool Dryers
CAR WON'T START
u probaly need to have the comp. tested
Jan 12, 2009 | 1995 Pontiac Grand Am
87 people viewed this question
k24674
