Question about Dualit Vario 4 Slices Toaster
Just stopped working. Fuse ok - Dualit Vario 4 Slices Toaster
No brake lights 05 park ave all other lites work,switch ok fuse ok under hood fuse box.
https://s26.postimg.org/63wl17p55/stop_lamp.jpg
Click on the link.
Did you use a test light and check for voltage at the stop fuse, hot all the time. Even if the fuse is good, if no voltage on the circuit, the circuit is still dead. At the stop switch, when activated, both those wire colors are hot.
Neither the high-mount or lower brake lites work? Could be a wiring circuit problem?
Sep 13, 2017 | Buick Park Avenue Cars & Trucks
96 s-10 4.3vortec vin x no brake lights...all other lights work...bulbs ok...Is there another fuse somewhere besides 2 in fuse box? Brake switch ok also.
The only applicable fuse is 20A STOP HAZ FUSE 1. The STOP LAMP RELAY or the TURN-HAZARD SWITCH (multifunction switch) could be defective.
Jun 28, 2017 | Cars & Trucks
Why did my micro stop working?
I guess the main plug fuse does not blow for the same reason it does not blow and you can wreck a PC, although not certain why that is. I have a feeling from past work on a Panasonic that there is an internal fuse as well. This may have blown with the power surge.
Jul 07, 2014 | Panasonic Nn-sn797s Countertop Microwave...
My dash lights on my 1997 subaru legacy outback just stopped working out of no where, What could be the problem?
ok fuse boxes are under the hood and under the dash around the hood release lever. should be the 5A fuse
Dec 27, 2013 | 1997 Subaru Legacy
Cigarette liter stopped working then the next day the blower motor stopped working, Now the buzzer for head lites being left on stopped working and interval wipers stopped as well. This has been within a...
no power, means, what, cig lighter plug dead,?
try something else there, like a cell charger, still dead.?
if it is truely dead, the fuse is blown.
does head lights work, and engine run?
ok fuses that bad are bad, blown. (blown elements)
ok fuse that look GOOD, can in fact be bad, (tiny cracks.)
we never fail to test good looking fuses or go nuts for sure.
you can test fuse 3 ways.
1: DMM ohms, 0 ohms reading
2: voltmeter shows, 12v, on both sides of fuse, key on.
3: a fuse tester dealy bob at any autostore. (ill pass)
there are other ways, but are way too complex to type.
(ok a battery powered test light , yes, all auto stores sell them.
glow with a good fuse)
bingo?
Sep 03, 2013 | 1991 Honda Accord
2 out of 3 brake lights dont work
If any light lights up when you apply brakes, then the brake switch is ok. The problem could be a fuse and/or a relay. or the bulbs. Those bulbs are dual filament so one filament could be bad, for stop or tail lights.
Oct 02, 2012 | 2002 GMC Envoy XL
My break light fuse keeps blowing in my 97 suburban any ideas why
Assuming it's a K1500, 15A STOP/HAZ fuse 1 in the instrument panel fuse block is the source of power. If the stop lamp switch checks OK, and the center high mount stop lamp is OK, the cruise control system gets input at this point and may be defective. Fuse 1 also feeds power through the turn/hazard switch to the stop filaments of the tail/stop/turn lamps and these presumably are OK
Sep 22, 2012 | 1997 Chevrolet Suburban
My ac stop working,I checked compressor ,it's ok ,no power to compressor
Some possible causes are the system is low on freon, a faulty compressor clutch, faulty low pressure switch, relay, fuse, or control switch.
Do you have power at the fuse and the relay ?
Jul 15, 2012 | 2001 Chrysler Sebring
1992 ford ranger wiper wont work wiper pump not working fuse ok?
check wire continuity with multimeter, have had switch go out on ranger as well.
Apr 05, 2009 | 1992 Ford Ranger
Dualit Vario 4 Slices Toaster Logo
37 people viewed this question
Top Dualit Kitchen Appliances - Others Experts
Ross Keen
Piyal Perera
Piyal Perera
Joseph Hoffmann
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
