Question about toshibadirect.com
Printing from a computer, get paper jam, clear it, then the printing sarts over from zero again, so get too many copies. Any fix in the software? The counter on the machine doesn't operate when printing from a computer via USB.
  • seares2006 May 22, 2011
    Thank you, and what you say is true. But when it happens somewhere through a run of 200 the counting of printed sheets becomes more than a little laborious. This effect also occurs when paper or toner run out. This is not mentioned in the manual, but I will do my best to make users of the machine aware of it. It's a pity the counter isn't operative when ther machine is used as a printer, neither on the machine nor on the computer. But I guess that there isn't going to be a software fix. Good job we're a church with voluntary labour!
    Scholar:
  • 106 Answers
You can work this around by using a little manual labor. Whenever the paper jams and doesnt continue from previous page, you can unplug the printer from the electricity. (not just the on/off button). This way it loses the document that was printing from the memory. Then you can send the doc for printing again by designating which pages to print.
ex. if your document was stopped at the 12 pg and it has 20 pages.. go to print> and then choose which pages to print i.e. 13-20.
I hope this helps.
Posted on May 22, 2011
Testimonial: "Thanks to someone who has obviously come across this before! What you say is true."
  • 2 more comments
  • Eli Elle May 22, 2011
    I completely understand your pain, trust me. I used to work for a graphic design and printing company, and this was all i did all day long - had "fun" with a lot of printers. :) they just go bad for no obvious reason. I will try to help you further on, give me the brand and model of the printer and i will see if i can find something more helpful. You can always try to ask the manufaturer's customer service, their tech support might be helpful. Or even if it's still under warranty, you can ask them to send a technician to look at it, or have it replaced all together.
    The machine is a Toshiba e-studio 166, basically a photocopier but you can also use it as a printer from a computer via USB- there is a driver for this. In this use there is no operational counter on the machine or on the computer. When there is a jam OR paper out OR toner out the machine will start over from the beginning of the print run after the 'error' has been cleared.. Yes, I have had to count the copies to determine where it had got to but this is tedious in a run of 200+ (Luckily we are a church so the labour is voluntary!). It seems the softyware designers didn't care about the machine being used as a printer but I wondered if there was an update which took this into account or a fix to overcome the problem. Thanks for your helpful suggestion. Past midnight here- time for bed! Seares2006
    Hello again,
    There are some compatibility issues with Windows 7 and Vista. This was originally only compatible with XP. There's a new "viewer" driver at the support page. >>HERE<<
    Try to install that latest driver it was released 10/25/10. If you have it already, reinstall it.
    if it doesn't help, it could be an issue with the maximum capacities.
    then, what is the error code it gives you?? you can see this code this way:
    when the printer starts flashing "call for service" you need to press 0 and 8 at the same time and hold. the service menu will come up. Let me know what the error code is.
    Missed the link page on the previous comment. sorry.http://mba.toshiba.com/support/downloads...
Is there another way to stop unwanted copies from being printed if the reset/stop button does not work?
If printing from your computer...yes. Go to the cancel print function on your computer and cancel the print. That will stop more copies being printed once you have hit cancel.
Otherwise you would need to switch the power off to the machine and remove any paper. Then turn it on again and play with the controls until you can clear the print memory back to zero.
Jan 11, 2016 | Office Equipment & Supplies
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Printer jammed and paper was removed but now it says paper jam and won't print from a command from the computer
hi go into control panel find printer settings u will have to clear any printing commands in c whats printing........good luck
Sep 04, 2015 | HP PSC 1315 All-In-One InkJet Printer
Fix paper feeder that keeps jamming. How to clear jam and fix on-going jamming problem
What thickness of paper are you using? Also is the paper new/fresh or are you re-using paper that has gone through the printer already?
Mar 03, 2015 | Lexmark X4550 Wireless All-in-One Photo...
Paper jam message wont clear and alow printing, I have opened every possible area and there is no paper anywhere. I was printing fine when if gave me the message. the piece of paper it was printing at...
Check if there is a reset, or clear message function. or you may try this one:
1. With the printer turned on, if there is a door for the cartridge, open it.
2. Then, if there is a "Go" button, "Print", "Copy" button, press and hold it for 10 sec.
3. Close the cartridge door or cover. Turn it off then turn it on again.
Please advise what will be the result.
thanks
Jun 23, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Jamming problem 5600
Possible sticky ink spill or torn piece of paper in the rollers. Inspect and clean the roller areas.
RDO
Nov 17, 2008 | HP Photosmart 2410 All-In-One InkJet...
Hp psc 1610 printer ... error message alternates between carriage jam and out of paper
i cleaned the clear file strip behind the carriage by rubbing it between my fingers and my printer started working again. before that i had paper jam and carriage jam and it wouldn't do any printing or copying.
Nov 08, 2008 | HP PSC 1610 All-In-One InkJet Printer
Paper jam
I have had this problem, and have became very furiated.
Clear the Jam by removing and paper you see in from the rear access door.
If you are printing something from a PDF website....... make sure to have it still in the printer schedule.... It will still say printer jam..... but have it there regardless if its something you dont want to have to retype into the pdf form........ After that simply restart your computer. It should resume printer as soon as your computer boots up.....
Worked for me..... Hope this helps everyone else whos probably cursing your printer at the moment!!!!
Mar 22, 2008 | HP Deskjet F335 All-In-One InkJet Printer
PAPER JAMS
Does the fault clear when you open/close? If it does you probably don't have a jam.
Does the machine begin to try to make copies, then stop-if so it has probably failed to feed off the tray, hence the jam message.If this is the case, pull out the paper tray, check for obstructions, clean feed rollers and try again.Are there "skid marks on the paper(indicating the rolls have turned?) If so rolls could be dirty/worn. If no skid marks, can you determine if the rolls did in fact turn? Go from there
Nov 11, 2007 | Office Equipment & Supplies
toshibadirect.com Logo
186 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
