Question about Refrigerators
I opened up my frig and the temp said the freezer was -13 and the frig is at 55 degrees. When I presed it down it changed to 2 in the freezer and 32 in the frig part. Put after about 3 to 4 seconds it would go back to reading -13 and 55. Any ideas
    President:
  • 2,468 Answers
The damper vent door between the freezer and fridge compartments is frozen shut or if motor operated it broken or the motor is bad or power to motor is missing to open and close this door to let cold air into fridge from freezer also there is an evaporator fan near here make sure it is operating or cold air wont be moved
Posted on May 22, 2011
I have Samsung fridge model RS267LBSH. The freezer works but why won't the frig side cool?
If the door temp is reading low then it will not cool as that is the temperature the fridge thinks it is at (regardless of the real temperature). Try setting the door temp lower and see if there is still a 14 degree difference between the 2 readings. If it does cool down further and the difference is the same then I would suspect the thermostat.
Aug 16, 2015 | Samsung Refrigerators
GE PROFILE PSW26SGRB SS
If your frig is freezing the food in the chilling compartment as well as the freezer, it means one thing--its thermostat isn't shutting down the compressor when the set temperature has been met. You stated that you had it checked by, I assume, a professional service technician. Being a retired tech myself, I'm surprised that he didn't check this out and discuss it with you. Check the temperature in the freezer! If it is less than 10 degrees F., turn the thermostat to "warmer". If the temp in the freezer is 10 degrees F., leave it alone and go to the temp control in the frig, which is a damper that controls cold air flow from the freezer compartment. Close this damper until your temperature in the upper part of the refrigerator is 38 to 40 degrees F. If these efforts don't shut down the compressor and correct your problem, then the answer is simple. Your thermostat is bad and needs to be replaced. It isn't expensive, and should cost you less than the labor for a tech to install it. Good luck!
Oct 12, 2008 | GE Profile PSW26P Stainless Steel Side by...
Whirlpool Frig/Freezer - Frig side too warm at 60 degrees
Check for another fan to cool the fridge side. It could be bad.
murf427
Aug 01, 2012 | Whirlpool Refrigerators
Amana bottom freezer temp 16 below. Turn temp down a little temp goes to 20 above
With that kind of spuratic actions I would strongly lean toward that the temperature control, also know as the cold control , is probably malfucntioning. Before I can 100% call that fact I would need more inforamtion, model number the most important. Also, a description of how the machine looks on the inside, like frost on the wall, ice, etc.
Apr 29, 2012 | Refrigerators
I noticed in the mornings that the temp on my freezer and frig will increase a few degrees then go back down. Then occasionally here and there during the day it will go up a little again. Sometimes the...
if it is a frost free the temp will vary room temp and the warm food you put in will affect it or the electronic controler is not operating properly frost free also defrosts its self in a 24 hr time frame this will affect the flux temp
Nov 07, 2011 | Refrigerators
Freezing problem in maytag frig
the probe from the temp panel is not sensing correct temp or the panel itself is bad...call a tech to check it out
Feb 04, 2010 | Refrigerators
My frig. in the garage.. The freezer works great in summer months but in winter months it doesn't. Why is that?
Good day,
That is normal. The thermostat that runs the whole machine is located in the refrigerator compartment.
When it reaches normal temperature, it shuts off. In winter months that may mean as long as 12 hours or more. Thus not enough running time per day to keep the freezer near it's normal temperature.
Engineers design domestic refrigerators to be in an area comfortable to humans. Normally 70 degrees or higher. Thus your problem.
The only solution is to bring the machine inside.
Sorry.
Thank you for using FixYa
Dec 29, 2009 | Refrigerators
We have a LG Two Side Fridge.
Look for the air ciculation regulator sliding vent between frig & freezer section open accordingly. Set both sides to #3 on dials if frig not cooling to less than 40 degrees, might need new cold/temp controller behind frig dial
Apr 30, 2009 | LG LRSC21934 Side by Side Refrigerator
Refrigerators Logo
129 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
