Question about Vacuums
During the winter i turn the dehumidifier off. but when i turned it back onthis spring because you can feel the dampness in basement, it turns on but it does not absorb any water. i cleaned filter??? it turns on and sounds normal but it isn't taking any water in??? help
    President:
  • 2,080 Answers
Turn the machine on maximum and let it run for an hour or so. Then check the coils in the back with your hand. If they are not getting cold at all, then there is a significant problem with the refrigeration process in the unit. It may have developed a leak over the winter and allowed your refrigerant gas to escape, or there may be another internal problem with the compressor. Either way you will need to have it serviced by a fridge technician, or more likely just replaced with a whole new unit since both options will probably cost about the same.
You can click on the following link for a troubleshooting guide:
http://www.allergyconsumerreview.com/dehumidifier-advice-troubleshooting.html
Good luck.
Posted on May 22, 2011
Hoover nano cyclonic shut off while in use/no suction when turned back on
That is more than likely the problem, NEVER put wet or even damp filters back into your vac
Oct 23, 2014 | Hoover Nano Cyclonic Compact Bagless...
Condensation dripping from ceiling in all electric home with no basement
The wall of the daughter's bedroom is NOT insulated. Moisture from normal activities (showering and cooking) within the house are causing the realtive humidity to be above 50%. When that moisture enters the wall or ceiling, the temperature drops below the dewpoint and condenses out. The moisture that condenses makes a nice environment for the growth of black mold which is highly toxic. The mold will spread by airborne spores. If you have return air ducts for your HVAC system in the room, the spores might be dispersed throughout the entire house, depending on how good you HVAC filter is. Note that if you have a swamp cooler on the roof, it could be leaking water through the ceiling and causing the problem.
You need to immediately move you daughter to another room and remediate the situation -- tear out all the drywall and anything that is damp or has signs of visible mold. Get the humidity in ther house below 50% with a dehumidifier. I would recommend the Winix 50-pint model (refer to link below). This will condition 1500 square feet, which is a lot, but you will need one on each floor.
Amazon com Home Kitchen
Jan 29, 2014 | Kirby Shampooer Shampoo Hose G3 Ultimate...
Rollers not working
Hi Heather,
I'm sorry to hear you're having difficulty with your DC33. If the brushbar isn't rotating, please run through the steps shown in our online Support guide to make sure everything is correct with your machine:
http://www.dyson.co.uk/support/dc33/dc33-multi-floor/my-machine-is-not-working/i-can-see-something-wrong-visual/my-brushbar-is-not-rotating/does-the-brushbar-turn-with-the-power-on
This should resolve the issue, but if you'd like any further assistance or advice, please give our customer Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Apr 03, 2012 | Dyson DC33 Animal Bagless Upright Vacuum
Dyson dc15 animal brush won't turn
Your DC15 is equipped with a sensor which shuts off the brushbar if something jams it. Once you've checked the cleaner head for obstructions and removed any threads or hair from the brushbar, you should be able to reset the machine. For guidance on doing this, please refer to our online support guide:
http://support.dyson.co.uk/support/dc15/dc15-the-ball-animal/my-machine-is-not-working/i-can-see-something-wrong-visual/does-the-brushbar-turn-with-the-power-on
This should resolve the issue, but if you'd like any further assistance, please call us on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Feb 07, 2012 | Dyson DC15 Animal Bagless Upright Cyclonic...
I purchased my dehumidifier last night, plugged it in, all?s running, seems fine, however, I have no water in the basin yet. It?s been operating overnight. How come there is no water in basin yet? Does...
Rather than try to repair it or look into it, call the dealer or take it back to him as you will invalidate your warranty if you do anything to the unit, and that is not worth it. Let the dealer worry about it.
Jun 08, 2011 | Vacuums
It turns on and shuts off just like it is supposed to but the thing is bone dry. The humidity is at 56% so it should be able to dehumidify. It is just a little over 1 year old, help me please?!!
If the machine's compressor runs when you switch it on, then turn the machine on maximum and let it run for an hour or so. Then check the coils in the back with your hand. If they are not getting cold at all, then there is a significant problem with the refrigeration process in the unit. It may have developed a leak and allowed your refrigerant gas to escape, or there may be another internal problem with the compressor. Either way you would need to have it serviced by a fridge technician, or more likely just replaced with a whole new unit since both options can potentially cost about the same.
If the unit runs normally and the coils are getting cold, then make sure they are not totally icing up which will impede the unit's performance. If your dehumidifier is freezing up then that probably means it is actually working well. The humidity level in the room is probably just relatively low and you probably have the unit turned up too high for the conditions.
Try turning down the setting on the unit so that it cycles on and off every few hours and does not run continuously.
Also try using some warm soapy water to clean off any dust or oily residue from the cooling coils in the rear of the unit. Remember to also clean the air intake filter while you are at it.
The ambient temperature in the room may also be a bit too low, so you can try adding some heat to the room if necessary. A dehumidifier will not work properly if the ambient air temperature is too low. Basically, the warmer and more humid the room is, the better they work.Since warm air rises, you can even try lifting the unit higher up off the cold floor onto a bench or table where the air is warmer.
You can click on the following link for a general operating and troubleshooting guide with additional tips on effective dehumidifier operation:
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
May 24, 2011 | Kenmore Vacuums
My dehumidifier shuts off within a few minutes of turning on. There is humidity in the air but it is not collecting any water in the bucket. I feel air being sucked in the front and blown out the back. I...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Apr 21, 2011 | Vacuums
Karcher 4.91 m leaking a lot of water as soon as hose is turned on, also rsulting in low pressure. It's approx 15 months old and used approx 12 times. Stored in spare bedroom during the cold winter. Was...
I could be that the rubber washer that is on the piece that the hose screws on to is dried out. Try replacing it. Any outdoor products store would have it.
Mar 27, 2011 | Vacuums
The water does not shoot out of my bissell proheat shampooer. The red spinner has stopped spinning.
I'm not sure I have the same kind of machine as you because I don't think I have a red spinner. However, I did have the problem of water not shooting out (although the solution was being used up, just not the water). The problem turned out to be the plug underneath the main tank. To find out if this is your problem, lift out the main tank and take it to the sink. Feel underneath for the plug. Push inside of it. Water should squirt out (assuming there is water in your tank). If it doesn't, turn the tank over, unscrew the plug, and push the thing inside until you get it to spring up and down. If it won't do that, you might need a new one. If it springs, screw it back and try your machine again. Mine worked good as new after I did this. Good luck!
Dec 26, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissel 7920 Diverter Valve Install
With the top cover off, turn it over, put the knob in the water only setting, the piston will fit in the slot (only one way), turn the knob some so it will stay on. Put the cover back on, but just before you push it down, turn the knob to the water only setting again, then push the top cover all of the way down. Turn the knob, you can feel if it is in the chamber or not. If not, it won't turn or be hard to turn.
Sep 16, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
