Question about Samsung HCN436W 43" Rear Projection Television
When i power on the set the standby light blink for about a minute and go back to standby
  • 9 more comments
  • lawrence adekunle May 22, 2011
    hi walesarumi
    i have checked no bulged capacitors and no lamp. the problem of the set is when you on it the red light flas for some sec and go back to red
    thank
    hi
    pls i ve checked but ther is no bulged capasitors, allso thes set has no lamp.
    the problem is when i put the set on the red light blink for few sec and went back to red.
    thanks
    hi am having a problem wiht my samsung real projector tv sp43w6hpx . when i put it on the red light flash for some sec and went back to red
  • lawrence adekunle May 23, 2011
    is a crt projection with 3 picture tube.
    is a crt projection with 3 picture tubes
  • lawrence adekunle May 24, 2011
    yes it has the B+ voltage but the voltage drop after viwe sec.
  • lawrence adekunle May 25, 2011
    sorry i dont know what you mean by hang the B+
    yes i have the 125vdc but not stable drop to 0v in sec.
    yes i did and the votage drop
    what am saying is that when i hang the b+ connected to the ply-back the i dont have a stable supply .
  • lawrence adekunle May 27, 2011
    hi i have check but no bulged capacitors the h-out is ok. pls were can iget the complty board to buy.
  • 1,238 Answers
Good day!
If you TV is on stand by mode and the screen is not appear may be the problem is in the power supply section.
You have a better chances if you have a failing capacitors on the power supply section.If you found it replaced with the same type ratings and value.
Thank you.
Posted on May 22, 2011
  • 10 more comments
  • bonifacio gomez
    bonifacio gomez May 23, 2011
    what type of TV you have it is crt projection or dlp?
  • bonifacio gomez
  • bonifacio gomez
  • bonifacio gomez
    Ok try to check the B+ if it is have a voltage (115vdc) using multimeter (range in dc).
    If you have B+ then try to check the base of the h-out(horizontal output) transistor.It should have 5 to 7vac,
    If no voltage on the base try to hang it and check the voltage again if you have voltage while you hang it..The problem could be the ply-back transformer.Please replaced it with the same type,ratings and value.
  • bonifacio gomez
    bonifacio gomez May 24, 2011
    please don't forget to rate my answer.
    thank you
  • bonifacio gomez
    bonifacio gomez May 25, 2011
    try to hang the B+ connected to the ply-back if you have a stable supply when its hang.try to connect it again if the voltage gone when you connect the problem could be the ply-back please replaced it
  • bonifacio gomez
    look at the primary of the ply-back and look the 3rd pin.try to hang it by using solder iron and soldering pump.and try to check the voltage if stable to 125vdc or above
  • bonifacio gomez
    did you try to hang the connection of b+ on the ply-back?
    as I mention above
  • bonifacio gomez
    Ok so your ply-back is defective please replaced it
  • bonifacio gomez
    bonifacio gomez May 26, 2011
    OK please check if any bulged capacitors.check the h-out if shorted and also check the regulator (TRANS) if shorted.
    That is all at the power supply section
    thanks
  • bonifacio gomez
    bonifacio gomez May 27, 2011
    actually the board is not available only spare parts.
    If the problem is major.I suggest to give it to the nearest service center.
    or you need to buy a new TV.
  • bonifacio gomez
    because the expenses of the repair is almost the same to the price of new TV,please try it
  • Samsung Master
  • 6,993 Answers
Remove the TV wire from the wall plug, wait for about 30mins for TV to settle, plug it back into the wall and power on the TV and see if problem will persist.
If problem persist then problem is either from a dying lamp or a power problem. If the blinking light it green, then it means you need to replace the lamp, but if the blinking lamp is red, it means your TV is having a power problem.
Red blinking light on your TV is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
All these can be checked on the power supply board.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Regards.
TV goes to blank screen standby after one second of normal functioning green power light on. When in standby state, the TV is blank like it's off and the red standby light blinks FOUR times.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Oct 16, 2015 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
My LCD Sony KDF-60WF655 Powr/Standby light started to blink and automatically cut off after 10-15 minutes of being on -- the cooling fan comes on and then it powers back on. Now it is happening about...
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jul 28, 2011 | Sony KDF-E60A20 60 in. LCD HDTV
I own a Sony KP-51WS520 that has been down in the basement unused (unplugged) for 2 years. I decided to set up my "man cave" and went to turn on the TV. It started right up but after shutting...
Hi Hank,
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. There is no user replaceable Lamp in KP51WS520 TV.
Jul 16, 2011 | Sony Televison & Video
I have a KDS-55A2000 and thegreen light flashes for 1 minute then goes out and red light flashes no sound or picture. Removed bulb and it is clear, no smoke or brakeage
Jul 16, 2011 | Sony KDS55A2000 55" HDTV
I have a sony trinitron wega 32HS20 when i power it up the standby/timer light blinks 11 times then the picture appears sometimes it will stay on all day and sometimes just a few minutes then it powers off...
Mar 19, 2011 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Sony 3 lcd rear projection tv hd w/ wega gate. kdf-e42a10. tv will atempt to turn, shuts down, greem power light blinks 12 times on average. red standby light blinks 4 times. i replaced lamp [ xl 2400...
Mar 02, 2011 | Sony KDF-E42A10 42 in. LCD Television
The tv powers on and the standby light flashes, there is sound but no picture and the the tv powers off and the standby light flashes usually 6 times.
Feb 09, 2011 | Sony KP-57WS520 57" Rear Projection...
My Sony Trinitron TV 1999 (KV-32V42) made a strange popping sound and I lost both the sound & picture. When I turn it back on, the two red lights on the front of the TV(standby/Timer light & Stereo...
Feb 04, 2011 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony KV-32FS200 standby light blinks repeatedly for 15-30 minutes before it powers on
Jan 18, 2011 | Sony FD Trinitron WEGA KV-32FS200 32" TV
Blinking standby light
Please provide a model# and brand name & chassis if possible.
Jan 13, 2008 | Televison & Video
Samsung HCN436W 43" Rear Projection Television Logo
44 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
