Question about Vivotek IP7133 Web Cam
Having problems configuring e-mail alerts. Sending e-mail address is @btinternet.com address just says error when sending e-mail in the test mode
I receive gmail but can not send out
With all email, sending uses the SMTP protocol which, by default, is associated with port 25.
Usually you would not experience a problem sending a message using gmail with its webmail interface, but if you are using an external email address or have gmail set up to use POP3 for a business account, you will need to find out what port is used for sending from the owner of the mail server (such as your company).
Without having access to your settings, I can't know how your have your email configured, but you can click on the gear icon in the upper right hand corner of your gmail page and choose 'settings'.
Areas to check:
1) Accounts and Import
o Look to see how alternate email addresses (if any) are set up.
o Check to see of there are POP3 accounts and check any to
see how they are configured for sending.
2) Forwarding and POP/IMAP
o See if there is anything set up here for a different email address
or for POP mail.
Chances are, possibly with the help of your IT department or someone else where you work, you will find that your SMTP port
should be set to a different value so you can send mail.
One other possible place to look... if port 25 (or whatever port you are using to send email) is blocked in your firewall, you won't be able to send. In that case you will have top un-block the port.
Jan 27, 2016 | gmail.com
I cannot get or send emails. my server is not working
This indicates either an incorrect password or server settings. Make sure your account is setup as follows:
IMAP
Incoming Mail Server: mail.btinternet.com
Port: 993 (this should be automatically populated if you tick the SSL Encryption)
SSL Encryption: Enabled (but not STARTTLS)
Username: your email address including the @btinternet or @btopenworld.com part
Password: your btinternet password
Root folder/path:
Folder separator: . (full stop)
Please do NOT enable "secure password authentication" (SPA). It's not needed when you use SSL encryption and won't work.
If your IMAP client supports it, we recommend you also set up the following folders:
Trash
Sent Items
Drafts
POP3
Port: 995 (this should be automatically populated if you tick SSL Encryption)
POP from folder: By default, POP will pull emails from your Inbox
SMTP
Outgoing Mail Server: mail.btinternet.com
Port: 465 (this may not be automatically populated on selection of SSL, so you'll need to check this)
Authentication: PLAIN
Online Virus Removal 39 99 Online Virus Removal and Online PC Help
Feb 22, 2015 | Computers & Internet
Sandra4609g@btinternet.com
Every iPad should be capable of sending email. You first have to setup the account, in settings, then email, then add new account.
While entering a new account, you have to fill in all settings correct, so you need to know it it is a POP or SMTP server, you must fill in the complete and correct e-mailadres and server name and the correct password. if filled in and you press next, the program will check the validity of the address. Only if the address exists and the password is correct it will tag everything green. Then you can use the mail address. It must be an existing mail address. You can't create new addresses in that part.
I'm not sure if you are running the iPad on a G3 or G4 network from BT, because that firm can try to block other mail, to save bandwidth, but I don't believe that.
You should be able to setup the BT account. If you keep having trouble setting up the BT account, visit a bt store and ask them to setup your mail address
Jul 18, 2014 | Yahoo Mail
I am unable to setup my email wizard in my samsung corby
Standard instructions for email inbox setup:
i have finished my corby pro email settings & i can send and recieve emails. the problem with only recieving & not able to send is the confusion between port numbers. in secure connection box three options available ' off ', ' SSL ', ' TLS '. use only SSL or TLS because the port numbers for SSL & TLS differs. just try this & you will be able to send and recieve emails.
                                                    SMTP port - 465
                                                    POP3 port - 995
Enable POP in Gmail. Don't forget to click Save Changes when you're done.Configure your client to match the settings below:Incoming Mail (POP3) Server - requires SSL:pop.gmail.com
Use SSL: Yes
Port: 995Outgoing Mail (SMTP) Server - requires TLS or SSL:smtp.gmail.com (use authentication)
Use Authentication: Yes
Port for TLS/STARTTLS: 587
Port for SSL: 465Account Name:your full email address (including @gmail.com or@your_domain.com)Email Address:your email address (username@gmail.com orusername@your_domain.com)Password:your Gmail password
Unless you're using recent mode to download mail to multiple clients, make sure you've opted not to leave messages on the server. Your Gmail settings determine whether or not messages stay on the server, so this setting in your client won't affect how Gmail handles your mail.
Please note that if your client does not support SMTP authentication, you won't be able to send mail through your client using your Gmail address.
Also, if you're having trouble sending mail but you've confirmed that encyrption is active for SMTP in your mail client, try to configure your SMTP server on a different port: 465 or 587.
You're now ready to use POP with your Gmail address.
Mar 08, 2011 | Samsung S3653 Cell Phone
I keep getting the following when opening or sending mail: The message could not be sent. The setting for your outgoing email [SMTP] server might need to be configured. To find the server settings for...
Quick summary:
It appears that email address does not exist - which is why your email program was unable to send the message. There may be a small typographical error in the address - which you would need to correct in order to send the message successfully.
Background:
The error message you received says the "domain does not resolve". That means your outgoing server (which is used for sending messages) couldn't find the information about the recipient's address -- and more specifically, the "domain" of the recipient's address. (That's the portion of an email address following the "@" sign.)
The error message indicates the domain of the recipient's address is "quickfireprocuctions.com". But a quick check of domain registration records indicates there is no registered domain by that name. And if a domain is not registered, there can't be any websites or email addresses which use that domain name.
However, there is a properly registered domain "quickfireproductions.com" (with a "d" rather than a "c"). That seems much more likely - as the combination of recognizable words ("quick" "fire" "productions"). That domain is registered to owners in Florida, USA. See details at: http://whois.domaintools.com/quickfireproductions.com
Solution:
If that registered domain name sounds right, then you should revise the email address in your message to use the correct domain name (i.e., replacing the "c" with a "d").
Feb 23, 2011 | Microsoft Windows Live Mail
Sending mail with Vista Windows Mail
Window Vista also have Outlook Express.. please enter the full info for your email account..
On the E-mail Settings page, enter your email account information as follows:
Your Name
Enter your first and last name.
E-mail Address
Enter your email address.
Account Type
Select POP3.
Incoming mail server
Type for your incoming mail server.
Outgoing mail server (SMTP)
Type for your outgoing mail server.
User Name
Enter your email address again.
Password
Enter the password you created for your email account.
After this please check for "Test Account setting"
If everything is working fine, then remove the previous account
And let us know the error message if come up any.
I hope it will resolve the problem and you will be able to use the Outlook.
May 01, 2009 | Microsoft Computers & Internet
Unable to send
thank you for choosing Fixya.com
please check if the address of the receiver is correct..
make sure that it is not in the capslock mode.
e.i marrk26@yahoo.com
Feb 19, 2009 | Yahoo Mail
Sending email
here are the settings for btinternet, if you use "outlook" you must manually configure them!
  • The POP3 server (incoming mail) is mail.btinternet.com
  • The SMTP server (outgoing mail) is also mail.btinternet.com
  • Both need your BT Yahoo! email address and password; you will have to tell your e-mail program that the SMTP server requires authentication.
  • The SMTP server can use either port 25 or port 587.
The most common fault is to provide your ADSL username and password when your BT Yahoo! username and password is what's required.
good luck and regards
Nov 21, 2008 | Computers & Internet
E MAILS FAIL TO GO
Dear Geoff, There can be multiple reasons for this. When you reply and error shows up it can be:
a) Your internet speed is slow and your email client has not been able to send your message.
b) Check the email address you're sending the email too. Recipient email address can be full.
c) Check your email settings to ensure that your outgoing and incoming mail servers are working.
d) If you are still facing problems maybe you can make new email address on relatively more user friendly websites like Yahoo, Hotmail or Expedia.com.
If thats helpful kindly press solved.
Nov 25, 2007 | Adobe Photoshop 7.0 for PC
Vivotek IP7133 Web Cam Logo
93 people viewed this question
Top Vivotek Computers & Internet Experts
justwinwin
U-Spy Store DBA Pro...
Level 1 Expert
Are you a Vivotek Computer and Internet Expert? Answer questions, earn points and help others
