Question about KitchenAid KCM514 Coffee Maker
My KitchenAid Coffe Maker MOD KCM5150B-0 displays LED readout "Err 4". What does it mean and what is the corrective action? I've tried pushing buttons and plugging/re-plugging.
3 Suggested Answers
SOURCE: kitchenaid coffee maker model #KCM534OBO
The manual s available online here http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/P05032002.pdf
Posted on Mar 14, 2009
  • 145 Answers
SOURCE: Kitchenaid mod#KCM511 - error 2
An ERR 2 may be cleared by a simple reset of the coffee maker. This means unplugging the unit and plugging it back in. When powered back on, select a brew function to see if the error reappears.
If the code does reappear, ERR 2 indicates an internal error with the computer of the warming plate. This may be covered under Kitchenaid's 1 Year Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
Their toll-free telephone number is 1-800-541-6390.
Posted on Jul 08, 2009
Computer read out stuck on full
Assuming this is the readout on the server and not the LCD of teh brewer.
Clean out the servers with detan tablets following manufacturers instructions. Rinse and dry. If display remains unaffected and reads full then the sensor is likely faulty and this means a replacement section.
Jun 04, 2013 | Fetco International LUXUS® 5000 CBS-52H-15...
My Pioneer DVD player displays OC ERR 1
You need to replace the IC Amplifiers that is near the channels when you open the player (make sure it is NO LONGER under warranty or else you'll void it). The cause perhaps is that your speakers have been shorted.
Aug 20, 2012 | Pioneer HTZ-161 Theater System
Coffee pot does not work at all model KCM511ER-1 THE DISPLAY shows Err2
If it does, ERR 2 indicates an internal error with the computer of the warming plate. This may be covered under Kitchenaid's 1 Year Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
Apr 18, 2009 | KitchenAid KCM511 Coffee Maker
Feb 14, 2009 | KitchenAid KCM511 Coffee Maker
Kitchenaid coffee maker model #kcm515 displays err2--is there anything I can do to fix this? Thank-You! Scott
Jan 09, 2009 | KitchenAid KCM514 Coffee Maker
Err4
ERR 4 in a Kitchenaid coffee maker indicates a button is stuck in place. Please be sure to check all of your buttons and see if any are stuck depressed into the machine.
If this is not the case, I would suggest contacting Kitchenaid Customer Service to see what other options may be available.
Dec 31, 2008 | KitchenAid KCM511OB 10-Cup Coffee Maker
Kitchenaid coffee maker model #KCM534OBO
Err2 is a failed heating element. There is no fix or replacement parts sold. I was lucky I had a receipt, even out of the year warranty they(KitchenAid) are still replacing it.
Nov 07, 2008 | KitchenAid JAVASTUDIO KCM534 14-Cup Coffee...
I have a Kitchenaid coffee pot model KCM515 and have lost the manual. It is not working & display is err4. What does this mean? jgit
A .pdf user manual and exploded parts views for this machine are available online at Kitchenaid.com. Click "Customer Care" in the upper-right hand corner of the main page and then click "Locate Manuals and Guides." You will need to enter your model number exactly as it appears on the bottom of the appliance. You should find it on a white sticker.
If this is not helpful, I would suggest contacting Kitchenaid Customer Service to see what other options may be available.
Oct 16, 2008 | KitchenAid KCM514 Coffee Maker
KitchenAid 10 cup coffee maker Model # KCM511ER-1 Ser# WGT4409334 Pushed the Brew button after a Min. or two it beeped and Replaced the time with "Err2". the coffe maker did not warm up or...
Aug 16, 2008 | Black & Decker Spacemaker 10-Cup Coffee...
Re: KitchenAid Coffee Pot
I had a similar problem with Err 1, Err2, and Err 4. To resolve Err 1, if you have room, remove the coffee filter and coffee, pour more "warm" not hot water into reservoir. If you have 4 cups cold water add 5 cups warm. Then start coffee maker and let it run thru. Then drain coffee pot and start over to make coffee with tepid water. Err 1 indicates the coffee maker temp sensor is too cold from room temp or water temp.
Err 2 is a result of cleaning. First question "Did you remove the charcoal filter?" The charcoal filter can be removed form the filter stick by prying two tabs away gently and removing the filter for removal. The filters can be purchased @ www.Kitchenaid.com
One pot run thru with descaler can loosen scale and make sensor go "blind". Just run a full pot of clean plain water thru one maybe two times. A pot solution should be a solution of 1/4 pot WHITE vinegar, 3/4 pot clean cool water. Run this thru once, then two clean pots of fresh water as if you brewed a pot of coffee. NEVER USE CLR WITHOUT RUNNING NO LESS THAN THREE CLEAN WATER POTS THRU MAKER!!!! This is so you can continue to enjoy drinking coffee, nothing like a cup cleaning you out!
Err 4 is simple, you have a stuck button. Unplug maker and gently press each button making sure they aren't stuck in.
Jul 20, 2008 | KitchenAid KCM511OB 10-Cup Coffee Maker
KitchenAid KCM514 Coffee Maker Logo
403 people viewed this question
Top KitchenAid Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
