How many bushels of wheat does 10 ft of 9350 grain drill hold? How many pounds of tertilizer does 10 ft of 9350 grain drill hold?
I am trying to buy a hog feeder and it says it holds 1.5 bushels of grain how many pounds it that? Thank you Denise
difficult to work out
1.5 bushels volume =12 gallons volume = 128 lbs mass
the difficulty is that a bushel is a volume measurement and as can be appreciated a bushel of oats will have less mass than a bushel of wheat even though the volume is the same
by converting to gallons and applying the mass of water (10lb to the gallon) as a base line , the result is as close an approximation that you will get
Of course a simple method would be to simply weigh the bushel of what ever you have and read the mass directly off the scale
Dec 14, 2017 | Kitchen Appliances - Others
How many pounds per bushel of something?
Hi Doug:
- Bushel is a unit of volume, and is typically associated with unprocessed vegetable or grain products.
- Pound is a unit of weight.
Depending on the product, ie. corn, carrots, potatoes, oats, etc.
The weight will be different for a bushel of each product.
If you reply as a COMMENT to this post with more information I may be able to assist.
Cheers.
Mar 31, 2016 | Kitchen Appliances - Others
Wat are bushels
Bushels or Bushings?
A bushel is a weight of measure for things like grain or apples.
Bushings are typically used to cushion suspension and steering components. Worn bushings will create noise when turning or going over bumps and reduce precision of suspension. Depending on wear, initially not dangerous but should be dealt with before they get too bad.
Sep 02, 2015 | 1998 BMW Z3 Roadster
How may pounds is 11/9 bushel
Pounds of what? The weight of a bushel varies with the commodity in the bushel. Go to this website and you will find the weights of various items in bushel:
http://www.alpharubicon.com/primitive/bushelssitkastan.htm
Find the commodity,then divide the weight by 9 and multiply by 11.
That's your answer.
Aug 31, 2015 | Cars & Trucks
2010 kia rio lx spark plug torque specificatons
Ignition coil hold down bolts are thin and could snap if over tightened. Just run the bolts down snug by hand and then give it 1/8 turn . Its just enough to keep the coils from vibrating loose.
Feb 14, 2014 | Cars & Trucks
Is this a whole grain? Or is like white flour?
Burgoul or bulgar is wheat hearts, it may not have wheat germ or bran in it. So it is more like a white flour with nutty wheat heart pieces
Nov 03, 2013 | Baroody White Burgoul Wheat Grain Grams 2...
Organic wheat
Visit a produce shop as they will have regular wheat and all other grains for sale
Apr 28, 2013 | Zynga FarmVille by Zynga
What characterizes whole grains and refined grains?
Whole grains are grains that have the entire grain kernel: the bran, germ, and endosperm. for example, whole wheat flour is a whole grain.
Refined grains have been milled, so do not have the bran and germ. This makes the grain finer and it will last longer, but it takes out the vitamin B. iron, and dietary fibers. An example of a refined grain is white flour.
Apr 17, 2013 | Cooking
Computers & Internet Logo
David Payne
David Payne
