Question about Ovens
I do not have the manual for the Beko double oven DBC 5622
2 Suggested Answers
SOURCE: our beko dv 555 w
Beko DV 555w Electric cooker.Oven and clock is not working.
The hob and grill work.
Posted on Dec 20, 2010
Can someone please tell me why my top oven fan is running continuously? It is a Beko ODF22300X double oven and everything else on it works ok.
if it cuts on and off by a switch then maybe the switch is stuck or gone out completely in the on position.
Feb 03, 2015 | Ovens
Beko double oven the fan has started to make a loud noise and sometimes cuts out had oven 18 months
by loud noise do you mean squeeling squaking .
then its the fan bearing just order another fan motor.
Jul 25, 2014 | Ovens
Beko oven fan catching element everything secure making dreadful row
Your oven must be fairly level for the fan not to make a noise.
Jun 28, 2014 | Belling XOU492 Electric Double Oven
Beko built in oven fan makes a noise like it's catching on something, now the fan has stopped
you will need to change the motor
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 14, 2014 | DeLonghi DEBIGE 2440 Electric Double Oven
Beko fan oven making noise
If you have a problem with your cooker or oven then this diagnostic video will help you find the fault on your beko oven and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
Jan 08, 2014 | Belling XOU492 Electric Double Oven
I ve got beko electric cooker model DC543 and the oven doesn't work
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. For all you Beko elements
    If this helped you why not get me a beer?
Paul is from the Naturally he would appreciate beer How to Repair Home...
Jan 15, 2011 | Ovens
Our beko dv 555 w double oven bottom oven is not working as the clock display is not on
Nov 19, 2010 | Ovens
Beko dvc 62 ,all electrics tripped out ,put cooker
The element has blown. It will cost you around
May 16, 2010 | Ovens
No fan or heat
Hello..... have you (a) checked that you have power going to the oven...(b)...With the power to the oven switched off open the terminal block (where the cable from your socket enters the oven) check that all connections are secure....(c) remove the rear panel of the oven and check that the safety stat is ok.......(usually small square white or gray unit wit two wires running to it found on rear of main oven...it is usually fixed to a bracket or directly fixed to the cabinet...test for continuity with a multimeter if open circuit ..that is no meter reading relpace it
regards Sir Galahad
Jun 28, 2009 | Belling XOU492 Electric Double Oven
Remove beko oven door
You have to look under the door seal and you will find the screws you have to remove to get at the hinges screws
May 19, 2009 | Ovens
Ovens Logo
23 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
