Question about Your One Source 100 Amp Main Breaker
I have a hot water heater that i changed the elements and the heater worked for at least 3-4 month and now i will have hot water and then i won't
  • 32 Answers
Check the thermostats.
Posted on May 27, 2011
Hot water not working
Might need to change hot water element. In hot water heater. Not too bad to change.
Jun 28, 2013 | Home
We just installed a hot water heater that's
1) Test elements, and if elements are good, then replace both thermostats.
Takes about 20 minutes. Power is off.
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
2) Label on side of water heater shows volts and watts.
For 4500 watt elements, you need 30 amp breaker and 10 gauge wire.
Move water heater wires to different same-size breaker.
http://waterheatertimer.org/Color-codewire.html
3) Open the links and do the work, or call plumber to do work, or call manufacturer for warranty coverage.
If your wire and breaker are problematic, then service is not free.
Feb 07, 2013 | Water Heaters
Hot tub won't get hot enough
Low Heat -
This problem is not usually associated with the heater element but more often a result of water flow issues. Specifically blockages such as dirty filters, partially closed valves etc... But... excessive scale/mineral build up on the element is on uncommon and can result in reduced heating. The fix is easy, use chemical treatments to reduce scale build up.
No Heat
No heat or water is only heating to 60F- 80F? If you are getting a low reading this is because the water is only being heated by the friction caused by running through the plumbing system and pump. Assuming there has not been a dry fire (visual signs of burn/overheat marks/ damage to the heater tube) and your temperature sensor and hi limit are in working order.
A bad element. Like a light bulb, spa heater elements will burn out over time & there are many factors which affect their longevity.
Nov 25, 2012 | Home
Hot tub won't heat over 86
Your problem is likely the heater element has failed.
The water is only reaching, mid 80's due to friction and heat from the pump. This is an intermediate problem, we recommend calling an spa technician. If you want to read: how to do to test a spa heater element.
Nov 02, 2012 | Pool & Spa
50 gal. reliance electric heater. Water is getting way too hot and the settings were not changed. elements must be working for the water to be so hot. My guess would be the thermostat(s) since it won't...
Thermostats is in need of replacement and sounds like they are sticking. So it would be best to change both out. Turn power off to change them out it would be best for safety issues to change out as soon as you could. I have seen thermostats burn up in compartment on water heater.
Sep 20, 2011 | RELIANCE ELECTRIC WATER HEATER
We have a Richmond 50 gal Rheem model 8MV50-2 that blew out the bottom element. We changed both elements and refilled the tank but the water heater won't heat. Do we need a new tank?
Electric water heater is fully repairable unless it is rusted out.
All 2-element tanks are 240Volts.
If you have NO hot water, then suspects are 240Volt circuit supplying only 120V, reset button is tripped out on upper thermostat, bad upper thermostat, bad upper element.
If elements were not completely covered with water when power was turned on, then elements will instantly burn out.
When filling water heater tanks, open bathtub spout. Wait for water to come out full stream. Then open TP valve on water heater for a moment to remove last of air. Then turn on electricity.
Open following link for complete troubleshoot walk-thru.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Aug 20, 2011 | Water Heaters
My new heater stopped working after 3 months upon inspection I had 240 volt to the heater and top element and nothing to the bottom element. I replaced the bottom element and both thermostats and their is...
The elements do not operate at the same time. They are designed to take turns coming on. Try setting the temperature of the top element 10 degrees lower than the bottom one, turn the hot water on in the bathtub. The bottom element should come on first. When you are done checking, turn the top element 10 degrees higher than the lower for normal operation.
Aug 28, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
New Rheem electric 50 gallon not heating
Check the elements, if you have access to a meter to check them. If they are getting power to elements and you have no hot water.
The elements are not working correctly. I had some elements check out ok till the thermostat's turned on and the elements didn't heat.
Sounds like the elements are bad.
Jun 01, 2010 | Water Heaters
Rheem Hot Water Cylider Thermostat keeps tripping
Sounds like you have a faulty thermostat.  This is the unit that detects the water temperature, and if it is not where it is set, will kick the switch to allow electricity to flow to the elements you replaced. The thermostats are relatively cheap and if you have the knowledge to change the elements, changing these thermostats should not be a problem.
Mar 07, 2009 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Your One Source 100 Amp Main Breaker Logo
Top Your One Source Electrical Supplies Experts
Steve
Lisa
Lisa
ray gallant
Are you a Your One Source Electrical Supply Expert? Answer questions, earn points and help others
