1= do not panic
2= Lube the deck belt
3= lube the roller bearing
4= adjust the REED switch see the diagram attached, clean and tigh the wires connector very well
5= lube the motor elevation very well gear and shaft.
6= adjust the potentiometer of elevation motor,
7a readjust again the speed sensor, see the diagram attached,clean it and tight wires connector very well.
7= Run again the software calibration for diagnose and troubleshooting
see the block diagram and fix it , maybe the main motor board is faulty, test it with the RUN s.calibration. God bless you
Proscan model PLDED3273A-B won't turn on/off or control vol but will change channels with universal remote (cablevision) UR2-CBL-CV04. tried codes listed for Proscan listed in user's guide, 144,160,161167 - no luck. Any suggestions would be appreciated. thanks
I am looking for a Speed Sensor for the Tunturi E80R bike, and a Memory Board Serial number 8f5A-10017L-E8R
Need repair service for my tread climber
I think a bearing needs replacing
