Question about Little Giant Submersible Sump Pump, 1/4 Hp
The pump leaked out the oil so i replaced the seal what quntity oil to use
Hello,my 2000 odyssey leaks oil.guy said its front oil seal but im gonna need time belt,water pump,vtec valve and oil pan gasket.Do i really need all that just to change front seal? $400 for labor?
A leaking front seal will allow oil to get into the area where the timing belt is located. This will cause oil to get on the belt and can cause damage. Since the timing cover must be removed to access the front seal, it is recommended to replace the belt while you are in there. Also, the water pump is driven off the timing belt. Replacement of the water pump is always recommended when replacing the timing belt for two reasons. First, it is easily replaced at this time and it is good preventive maintenance. Secondly, the water pump bearing is under tension from the timing belt and develops a wear pattern. Replacement of the belt without replacing the pump will cause the new belt to wear the bearing in a different pattern, often causing leaking in a very short time after the replacement. This would then result in having to repeat all the labor again to replace the pump. It is easy to see that for $400.00 labor, you don't want to do that again in only 2-3 months. as far as the VTEC valve is concerned, I don't see a relationship to the oil leak. It could just be something else the mechanic found during the inspection. I can find nothing in the remove/replace procedures that requires replacement of the oil pan gasket. Again, maybe something additional that is needed from visual inspection, but not needed for the front seal.
Apr 03, 2016 | 2000 Honda Odyssey
I replaced emerson 1hp pump to my hayward max pump and leaks any ideas all seals replaced
Hi, this is John the Hayward tech. Sounds like the mechanical seal is leaking. If you replace the spring loaded seal the problem could be that it was installed backwards. It is ceramic against carbon. if installed the other way it will leak. Any debris or oils getting on the seal will also cause it to fail Running pump without any water will heat up the seal and cause it to fail.
Jul 21, 2014 | Hayward Pool & Spa
Oil leaking trans 1999 chevy S10 replaced torque converter seal leaks at front
ou may need to remove the front pump and replace the seal on the pump and the converter seal as well
Aug 08, 2012 | Cars & Trucks
Oil leak 2000 alero, just replaced plug, not it, leaked out all the oil after I drove it 20 miles, please help, could it be a gasket or what
Check the oil filter. The old gasket might be stuck on the engine (two gaskets stuck together), or the new gasket might be defective, misaligned or missing.
Nov 05, 2011 | 2000 Oldsmobile Alero
Do the timing belt cover on a 1996 camry have a seal or gasket that can leak oil, mine seems to be leaking for around that area. If so how to replace the seal/gasket?
The timing cover itself does not seal any oil from leaking. It is just a cover to prevent debris from getting into the timing belt and ruining it.
To find the oil leak you will need to remove the timing cover and inspect the seals behind the cam gear, crank gear, and oil pump drive gear, and the oil pump to block seal. The most common leaks on these are the cam gear.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Jan 31, 2011 | Toyota Camry Cars & Trucks
96 subaru legacy oil leak coming out from behind timing belt covr
you have to replace the seal on front of crankshaft before it gets worse
Apr 02, 2010 | 1996 Subaru Legacy
Leaking both oil and a mixture of oil and water
well when you have water and oil both leaking it most of the time means a head gasket or in your case a jug gasket
May 25, 2009 | 2004 Yamaha YZ 250
I dont know where the oil pump is on my 89 toyota
On a 22RE the oil pump is on the timing cover behind the crank pulley/harmonic balancer,it has the crank timing pointer built onto it,generally they don't leak around the pump seal but as Monster80 pointed out they leak from the front main seal wich is installed on the front of the oil pump,pretty common for the 22R/RE to leak around the timing cover gaskets or out the bolt holes on the timing cover also,usually due to uneven tourqe on the bolts,to check the front main seal you need to look at the the crank from the underside right after you've shut the motor down,if the seals bad you'll see oil starting to form a drop on the backside of the pulley or the front of the oil pump housing.
Apr 03, 2009 | 1986 Toyota Pickup 4WD
Oil leak in my 98 mazda protege
Could be a rear main seal.
Apr 02, 2009 | 1998 Mazda Protege
1999 cross country v70 awd crankshaft seal replacement
Your info is confusing. The rear cam seal is not inside the timing belt cover, and the crank seal is at the bottom of the engine, while the cam seal is at the top.
Is there oil at the top, around the cam seal? Or just at the bottom? It's common for the oil pump seal to leak. If you get the oil pump reseal kit, it contains the oil pump seal and gasket, as well as the crankshaft seal. Make sure you seal the oil pump bolts, Volvo has special copper washers for this purpose.
Just try to locate the oil leak before replacing any more parts. Sometimes it can be something simple like the oil cap seal or the oil trap housing.
Bret
RepairPal.com
Nov 23, 2008 | 1999 Volvo V70
Little Giant Submersible Sump Pump, 1/4 Hp Logo
Top Little Giant Garden Experts
Jim Goldsmith
Jim Goldsmith
Mike Squire
john h
Are you a Little Giant Garden Expert? Answer questions, earn points and help others
