Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
I have a craftsman model 917.255812 lawn tractor - was running fine, turned off to empty leaf catcher - got back on and it would not start - doesn't turnover at all. I have replaced the battery and starter - no luck
Check the interlock switch on the bottom of the seat. Sometimes you can just bang the seat up and down a couple of times to free up the switch. I actually replaced mine even though it appeared to be OK (using and ohm meter) and it solved my problem.
Posted on Aug 25, 2012
  • 110 Answers
Hello Pappy,
Sounds like it is the starter solenoid that is on the positive battery cable on the right side panel below the battery. Part # 146154. Jump the two main terminals with a screw driver and if the starter turns the engine that's your problem. Be sure to remove the negative battery cable when you go to change out the solenoid.
If this was helpful, please vote yes. Thank you!!
Posted on May 27, 2011
  • Dean Gruber Aug 27, 2012
    A Craftsman lawn tractor will still crank, but not start even if the seat switch is bad. Posted problem was that it did not turn over at all hence the solution would be either a blown fuse or bad starter solenoid.
How do I put a grass catcher on Model #247.288842?
if the hood does not have provision for a catcher connection , then it is something you will have to devise how to do
if it has the connections then get the catcher and connect it up
Jul 21, 2013 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
After emptying the grass from the storage on the back of the rider, when I start to mow again, the grass that is in the catcher from the deck to where it shoots out, gets clogged and will not move on to...
Clean out your chute also and don't let the catcher get so filled up, check it for readiness to empty more often.Don't cut wet grass that tend to stick and cause trouble. Good Luck...709
Apr 19, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftsman Lawn Tractor - Electrical
make sure you mower deck is not still engaged. that might make it not start with that safety switch.
Oct 04, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
200 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
