Question about Tools & Hardware - Others
Powerplus belt sander X046 I was given one, I have no instructions, the dust does not go into the dustbag. can I get a manual please?
mikeymiddles
  • 58 Answers
SOURCE: belt sander clogged dust collection
What have you been sanding?  Make sure the sander is unplugged. Remove the dust collector bag and use a flexible wire, like a coat hanger, to free the clogged material from the dust tube.  Replace bag and sand away!  Hope this solution works for you.  Michael Mittelsdorf
Posted on Jan 10, 2009
muttandjeff
  • 359 Answers
SOURCE: Porter Cable belt sander
try to rig the nozzle of a shop vac to the part where the bag would normally connect and run the sander simultaneously with vac for a few minutes and see if that helps
Posted on Jan 11, 2009
Editor925
  • 285 Answers
SOURCE: belt won't stay on belt sander
Check first that you have retensioned the belt... i.e. when you removed the other belt, you would have had to pull on a spring-loaded lever to remove the belt tension before you added the new one... make sure the tension lever is flipped back in to ensure the new belt is tensioned...
Next, and the likely problem you are having, is belt tracking... There should be an adjustment knob up near the front of the sander near the front roller, either on top of the front part of the sander, or to the side near the front roller... When you turn this knob, it makes the belt track either left or right over the sander's base. This knob will allow your belt to run square and true and not spin off to one side...You need to adjust the tracking using this knob while the belt sander is running and with the new belt tensioned and in place, so turn the sander upside down, and power it on with one hand, then turn the knob with the other hand whichever way is needed to have the belt track square and in the middle of the rollers. Make small adjustments on the tracking knob to begin with. They can be sensitive at times.
That should stop your belt spinning off to one side.
Posted on Mar 18, 2009
  • 384 Answers
SOURCE: Unable to remove dust bag
Get your wife to help you remove bag. Turn and pull.
Posted on Jul 22, 2009
  • 40 Answers
SOURCE: I need manual for Craftsman 315.11720 belt sander
On my model 315.11720 3"x21" Craftsman belt sander to change out sanding belts you push the front roller in until it clicks to lock in its retracted position (a pry bar may help here), switch out sanding belts then unscrew the tracking tensioner a bit on the opposite side with a allen wrench until the roller snaps back in place. I never remember anything about using a screw driver to force it back forward position again. Then readjust the tracking if necessary with a few short sanding load tests and you're good to go. Oil is dropped in the front roller center by removing the flat head screw - it should say "Oil Here" around the screw.
Posted on Aug 19, 2010
Please help me find a free owners manual for my porter cable 352vs belt sander
The ServiceNet site has the manual for most Porter Cable power tools here: http://servicenet.portercable.com/ . The 352VS documentation is here: http://servicenet.portercable.com/Products/Detail/352VS . Look in the right hand column for the Instruction Manual; you'll see an option to download a PDF or have the manual sent by email. However, you need to look at the sander and attempt to find the Type number. This will be on the label with the model and serial number. There are 7 different belt sanders that were released with the 352VS model number. Use this number to get the details for your sander. The direct link to the manual for the Type 1 version, today, is http://servicenet.portercable.com/Products/GetDocument?docName=EnA00111.pdf&productId=55856&productType=12187&documentId=32863&translatedFileName=http://documents.dewalt.com/documents/English/Instruction%20Manual/Porter-Cable/EnA00111.pdf .
I hope this helps.
Nov 20, 2015 | Sander Tools & Hardware - Others
I have acquired a makita 9924db belt sander, but not a manual. The dust bag is wide open on the bottom - shouldn't there be some sort of device on it to keep the dust in? Also, I would like to know...
there is usually a plastic clip that slides over the bottom to seal the bag, as for the manual go to "makitausa.com" and you can download a manual from there. Let me know if you need more assistance.
Jul 08, 2011 | Bosch 1274DVS 3" x 21" Belt Sander
Bosch 3 x 21 Belt Sander
Remove the dust bag and unplug sander for now. Everywhere you see an access hole (fan area, dust port, back of sander blow thru the tool to remove lodged dust that clogged the system, Also look for broken belt pieces in the back of sander. Then while running (remove belt) blow again thru all the ports to try and reomve as much contamination as possible. When finished you can feel to see if air coming from dust bag port, it not you still have a clog that might need more work. If I have clarified your request would you please rate this response accordingly and thank you.
Sep 10, 2009 | Bosch 1274DVS 3" x 21" Belt Sander
31-735 delta belt/disc sander - dust collection nightmare
The belt cover that does down the front of the belt, below the table, should have an opening inside the baes/vacuum unit. Make sure this isn't clogged with buildup.
Jan 27, 2009 | Delta 31 735B 6" Belt, 12' Disc 3 Ph...
Jan 11, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Belt sander clogged dust collection
Jan 10, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Tools & Hardware - Others Logo
111 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
