Question about Marshall Mg100dfx 100-Watt Combo Guitar Amplifier
The clean wount work on this amp - Marshall Mg100dfx 100-Watt Combo Guitar Amplifier
    Problem Solver:
  • 6 Answers
It sounds like a bad IC to me. Also, it could be a bad solder connection at that channel's volume pot or the pot itself.
Posted on Jan 12, 2012
My peavey amp pv 2600 only plays on channel A. No output on the B side
Check the "BRIDGE" switch position, "IN" for "BRIDGE", "OUT" for "STEREO", and clean ALL back switches with a cleaning spray and then run the amp again, also check the two green lights activation at front, if they activate, then amp is certainly working, let me know further.
Jan 28, 2013 | Peavey Pv 2600 Power Amplifier
I run a pod HD 500 into the amp and It breaks up, like there is a blown speaker sometimes.
The Marshall is a super clean acoustic amp.
The POD is overloading the amp.
Try the electric guitar input and keep the gain on the amp down, keep the EQ level and use the POD and the end volume to adjust the final volume.
The normal inputs is for a low output acoustic pickup - the POD is a high output electronic source.
Start with the Marshall gains low and get the clean sound good, then work on the gritty sound.
The amp is voiced for a sweet clean sound - if you want grit'n'ball change to a 50w Marshall valve head and a 4 X 12 cabinet.
Horses for courses
Mar 07, 2011 | Marshall Amplification Marshall AS100D 2x8...
I've had (i don't know the model) a marshall 4 way foot controller (1.Clean/crunch, 2. Overdrive/clean overdrive, 3.Tempo, 4. tuner) for about 2 years now. Its been working fine untill i tried to plug it...
Make sure the pedal and the amp ae compatible. MANY pedals can only be used with one type and model amp. If this was used with a different model amp originally, it is probably incompatible with the ine you are trying to use it with now.
Jan 22, 2011 | Marshall Amplification Marshall PEDL90008...
Fender HRD - clean channel works fine, drive & more drive VERY low volume, like a headphone across the room w/ all 3 volumes at 10. LED works fine in drive/more drive. All same w/ footswitch,...
Wayne, There's a time to take the amp to a pro shop andf get it done right. It' saves time and headaches, and also keeps you from inadvertantly smoking other parts or yourself. Now is that time.
Apr 17, 2017 | Fender Hot Rod Deluxe Guitar Combo...
My amp has 2 channels, clean and distortion. distortion works, but the clean channel doesnt. When i hit the button, it switches the distortion off, but there is no sound. The distortion light stays on...
initially you want to think bad solder joint, but it think its a bad mosfet or rectifier or diode. it would be hard for an untrained person to identify your problem let alone an experienced tech. it may be time to move on to another amp. in my shop it would be at least 65 bucks for the repair. so where did the "heat"/energy go from that point and what parts were affected. there may be a domino affect. burn one part, not usually.
yostamplifier.com
Jan 17, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
How do i clean the pots and switches on my guitar amp
Radio Shack sells sprays for that kind of work check it
Oct 06, 2009 | Music
Electric Guitar wont play through Amp
the buzzing is indicative of an open ground connection, check the cord by substitution or with an ohm meter, if the cord is good look at the connections to the jack inside the amp ( im guessing you built the amp from a kit). Is this a solid state amplifier? Tube amps have lethal votages and should not be experimented on without knowledge of electronic safety. Also if there is more than one input to the amp try plugging the guitar into another one and see if its still the same.
Dec 30, 2008 | Yamaha Electric Guitar
My echo wont turn off when im on my clean setting
Hi, try holding down the clean channel button when you start up the amp. If that doesn't work, try turning up the delay, then turning it all the way down.
I have the exact same amp and this always works. If this doesn't work for your amp, you may need to take it in.
Dec 28, 2008 | Line 6 Spider Iii 15 Modeling Guitar...
Guitar amp channel switch repair
Replace the switch. You gave no make/model number for your amp but if it has a jack for foot pedal operation of clean/dist function then try that. (on most amps) it will switch in spite of a bad front panel switch.
Dec 21, 2008 | Music
Marshall Mg100dfx 100-Watt Combo Guitar Amplifier Logo
81 people viewed this question
Top Marshall Music Experts
Michial Gueffroy
matt martin
matt martin
Bruce Grant
Bruce Grant
Level 1 Expert
Are you a Marshall Music Expert? Answer questions, earn points and help others
