Question about Canon PIXMA MP160 All-In-One InkJet Printer
Canon PIXMA MP160 E5 error.
Ginko(GURU)
I have followed your suggestion,by taking out the power cable for2/3 minutes,but it does not appeared to have worked.
  • 2 more comments
  • Anonymous Feb 02, 2009
    When I turn on my canon pixma mp160 ,the screen on canon just shows E5 .
  • Anonymous Apr 25, 2009
    my printer show E5.i tried restarting the printer but it didnt work. i then decided to clean the internal parts. it finally worked. maybe you should try.
  • ratvivian Apr 25, 2009
    My printer show E5. i tried restarting the printer but it didn't works so i decided to wipe the internal parts with a tissue. i finally worked. maybe you should try and see whether it works with your printer. =D
  • First Stop Tech
    First Stop Tech Nov 04, 2016
    My e5 was cleared by taking both carts out and reinserting them. Much less work than cleaning.
  • Canon Master
  • 19,396 Answers
The unplugging procedure is called hard reset, and is useful only when there is no real problem on the printer.
Error E5 means a problem with cartridge chipset, here follows reset procedure, it does not always work:
Error E5 is a problem with cartridge ink counter. This happens when you use refilled or not original crtridges.
Try removing cartridges and putting them back in place.
Here is the whole service procedure for Pixma, you must use this to reset the ink counter:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
If it does not work you will need to buy a new set of cartridges, possibly original ones. If you just bought cartridges tell the seller they are faulty and ask an original set of cartridges as replacement.
Posted on Aug 15, 2008
    Genius:
  • 1,847 Answers
Printer show E5 error ... people from canon put chip in cartridge, and depend of time or number of printings, chip just send to other electronic on printer board that "cartridge is bad", or incompatible" - error E 5 (blinking).
    Master:
  • 848 Answers
What is your problem ............ provide details about your problem ...
  • 28 Answers
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-6
Posted on Sep 04, 2009
De ce-mi da eroare e5
Posted on Sep 20, 2009
SOURCE:
What is error e5 in mp 198 printer
E5 - The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly..
  • In certain models of Canon Pixma printers such as the Canon MP160 and Canon MP150, you may receive an E5 error when trying to print. In this state, you will not be able to use any of the functions of your printer. The error itself is an ink cartridge error. It may be that you are using generic or off-brand ink cartridges in your Canon Pixma printer. Canon Pixma printers do not work with other brands of print cartridges; invest in Canon brand ink cartridges and this should take care of your problem.
  • Nov 18, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
    HOW TO REMOVE E5 EARROR
    make sure you removed the orange tape from the cartridge.
    usualy E5 is when the color cartridge is faulty but if the orange tape is on the cartridge it will show E5.
    if you removed the orange tape an it still shows E5 go with the cartridge to the store where you purcess it for excange.
    Nov 18, 2010 | Canon PIXMA MP150 All-In-One InkJet...
    What is e5 error
    E5 error code occurs in certain models of Canon Pixma printers such as the Canon MP160 and Canon MP150, you may receive an E5 error when trying to print. In this state, you will not be able to use any of the functions of your printer. The error itself is an ink cartridge error. It may be that you are using generic or off-brand ink cartridges in your Canon Pixma printer. Canon Pixma printers do not work with other brands of print cartridges; invest in Canon brand ink cartridges and this should take care of your problem.
    Feb 25, 2010 | Canon PIXMA MP160 All-In-One InkJet...
    CANON MP160 PROBLOM E5
    E5 - The ink cartridges are not installed, or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly.
    E28 - Ink cartridge temperature rise error.
    Replace the cartridges.
    Call to authorized service center.
    Jun 19, 2009 | Canon PIXMA MP160 All-In-One InkJet...
    E5 error
    hi try to install a new driver from here http://support-my.canon-asia.com/EN/search?canonsearch=1&lang=EN&category=Multifunctional+Printers&series=PIXMA&model=PIXMA+MP160&menu=Download otherwise ur error code means The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly. Install cartridges properly. so try to clean the cartridge pinout well by using Acetone or something like that also try to clean the pinout of the cartidge mount inside the printer when it's power is off.
    Jun 09, 2009 | Canon PIXMA MP160 All-In-One InkJet...
    Cannon MP160 printer error message E5 and alarm light remains on
    Problem with catrige.Printer not detecting the catrige so clean catrige,and insert.
    Oct 19, 2008 | Canon PIXMA MP160 All-In-One InkJet...
    Error E5 is in operation,after putting in "Cartridge World"compatible inks
    try first unplugging the printer from power cable for two minutes, sometimes this clear the error.
    Aug 15, 2008 | Canon PIXMA MP160 All-In-One InkJet...
    Error code E5 on LCD Canon Pixma MP160
    Yo tambien tengo una canon pixma mp160 y me da el mismo error por culpa de los cartuchos. La solucion simple y llanamente pasaría por comprar cartuchos nuevos originales, pero a veces te sigue dando el mismo problema incluso con ellos. Asi pues, lo que yo recomendaría es no comprar esta impresora.
    Ah! se me olvidaba, que piden que escriba en ingles, porque dicen que "esto es america", no amigos, esto no es america, esto es internet. El mundo globalizado, irse acostumbrando a usar mas de un idioma.
    Jun 27, 2008 | Canon PIXMA MP160 All-In-One InkJet...
    Canon PIXMA  MP160 All-In-One InkJet Printer Logo
    33,479 people viewed this question
    Clive
    Clive
    old marine
    old marine
    Ekse
