Hello - Samsung CLX-3185FW printer - I have loaded software into my mac and each time I print it tells me that the printer is offline. Can you please help? Claude
  • 2,574 Answers
Download and install Printer Driver (Mac OS) -->start download
Scan Driver->start download
Smart Panel Driver ->start download
You could try a different USB port on the MacBook and a different USB cable
Posted on May 22, 2011
SAMSUNG CLX-3185FW SPL-C ERROR - INCOMPLETE SESSION BY TIME OUT
try printing with the right driver and make sure if ur computer is 32 bit or 64 bit...
Mar 30, 2013 | SAMSUNG CLX-3185FW COL LASER MFC Projector...
Samsung CLX 3185FW. ..paper stuck in fuser unit
I have clx3185 and paper was jamed inside fuser. So. These 4 screws from behind + one screw close to power outlet and then u need to lift up plastic side of printer,start from bottom - will be very hard. If done - remove from main board 2 connectors and release cables to fuser unit
Nov 10, 2012 | SAMSUNG CLX-3185FW COL LASER MFC Projector...
Removing a error message on a samsung CLX MFDevice
Hello.
Causes :
  • The remaining life of the imaging unit is less than 10% of its life.
  • The remaining life of the imaging unit is less than 0% of its life.
solution:
  • Replace the Imaging unit (Toner). remove the old toner and replace it with a new one, look in the user manual for detailed steps.
Additional help :
if you need further assistance on how to replace the Toner, please give me the Printer's Brand and Model and i will provide you with detailed steps.
Thank you.
Aug 29, 2012 | Samsung CLX-3185FW MFC / All-In-One Color...
Bought a Samsung CLX-3185FW to be able to print wireless from my macbook pro with snow leopard OS X 10.6. Software seemed to load ok, but each time I try to print, the mac is saying the printer is of
it really works ! you just simply have to update the printer drivers ( if it is connected to network and supports wireless printing) . I have done so in my office and everything works just fine. i
Jan 21, 2012 | SAMSUNG CLX-3185FW COL LASER MFC Projector...
Samsung clx-3180 printer is showing printer offline and will not print from pc.
CHECK
Printer is connected and power ON
In panel contro
go to Printers
choose Samsung Clx rigth click
unmark the check Use printer offline
Try printing a test page
rigth click Properties
click on
Print test page
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 20, 2011 | Samsung CLX-3160 All-In-One Laser Printer
Samsung CLX 3185FW WiFi Printing from MacBook Pro.WPS connected, Unable to send trailing nul to printer.broken pipe. What does this mean???
it means that your printer is connected via WiFi but the data can not be transferd. Could be the distance to the printer is to far.
May 15, 2011 | Samsung Office Equipment & Supplies
How to turn off wireless of samsung color laser printer clx-3185FW
The manual doesn't specifically state this but it appears that if the printer is connected to a wired LAN connection the wireless function will be disabled if the printer is set up in infrastructure mode. When I tried this the 'wireless' light turned off and I wasn't able to find the printer's WiFi SSID using a nearby netbook. If your goal, like mine, was to disable the printer's WiFi from transmitting to reduce extra WiFi noise then this seems to work. One of the wireless troubleshooting tips in the manual states to disconnect the wired connection before attempting to set up a wireless connection so it appears the two can't be used simultaneously. It seems odd that there's no specific "off" setting for wireless though. The printer will provide a WiFi connection when also connected to a wired LAN port if it is set up as part of an ad-hoc wireless network so make sure you set it to 'infrastructure' mode to disable WiFi.
Feb 11, 2011 | Samsung CLP-315W Laser Color Printer
How can I turn a CLX-3185FN into a CLX-3185FW?
Buy a Netgear WNCE 2100 which has one wired ethernet port connected internally to a wifi radio which is a 2.4GHz transceiver with WPA security. Fully compatible with most routers from D-Link, Netgear, Buffalo, etc. The samsung printer has a USB port to which you can connect and power the WNCE2100. This product is called by two different names. Sometimes it is called a Universal Ethernet Adaptor and others it is called a Network Bridge--which is more accurate. The Netgear product is b/g/n compatible. Try to place it not more than one room away from the router because the signal strength drops very fast if it is more than one wall and or 40feet from the wireless router.
Jan 03, 2011 | Samsung CLX-3175FW Multifunction Laser...
457 people viewed this question
k24674
jasbo
jasbo
