Question about Bulova Harley Davidson 100th Anniversary , Limited Edition, Only 2,003 Made, No Longer In Production, Rare, 97905 2V Watch for Men
How do i change the battery in a harley davidson bulova 100th anniversary clock?
I need the entire watch bulova Harley Davidson ladies 78L108 recently lost off my wrist while riding my motorcycle
I did a worldwide search.....there are not any 78L108 watches listed anywhere.
Do you have a photo of it?
Jun 13, 2016 | Bulova Watches
Tip
HARLEY-DAVIDSON watch instructions.
Follow this link and scroll down for HARLEY-DAVIDSON: http://www.bulova.com/service/servicecenter.aspx
on Feb 02, 2010 | Watches
Wich battery number may i use in this watch bulova 96t63 ??thanks
cant see that model watch on the Bulova web site user manuals
http://www.manualslib.com/brand/bulova/watch.html
if unsure if it needs a battery go to a jeweler or watch or battery seller
some model Bulova Watched instructions
IF YOUR NEW WATCH IS A MECHANICAL WATCH
(no battery)
Mechanical watches differ from Quartz watches in several
respects:
1. No battery changes are needed - they are powered by a main-
spring, which is wound either by wrist movement; or in some
models by daily winding of the setting crown.
2. Because it is a mechanical device, it's accuracy is subject to
the effects of gravity and temperature. You can expect, on the
average, a daily variance of up to 10 to 20 seconds for
mechanical watches.
3. Just like automobiles, these watches require routine mainte-
nance. Due to their mechanical complexity, mechanical
watches require cleaning and new lubrication every 3 to 5
years to run at optimum efficiency.
FOR THE AUTOMATIC SELF-WINDING
MECHANICAL WATCH
it must be wound at least six or seven times before you wear it.
After that, your daily activity should wind the watch sufficiently
to keep it running at night when it is not being worn. If your
normal daily activity is not sufficient, occasional supplementary
manual winding may be necessary. It is suggested that your
mechanical watch be cleaned and oiled periodically to insure
optimum performance. As a mechanical watch, quartz watch
accuracy cannot be expected. References to the power cell do
not apply to Automatic watches
May 02, 2016 | Bulova 96T53 Watch for Women
My battery operated anniversary clock keeps perfect time, but the pendulum has stopped. It is on a different battery, have changed batteries, to no avail. Can u plz help me? My clock is beautiful, with...
There is a very fine spring wire which makes the pendulum go, they often break when people touch or spin them. Replacements are available. Best to get it done professionally, suspension springs shouldn't cost too much
Sep 28, 2013 | Watches
I have a Bulova westminster chime battery operated clock that the chime is off. how do I reset it?
You may call Bulova customer service at 1-800-233-3350 they are usually open 9 until 4 eastern time. It may just be a setting or you may need the battery movement replaced. I hope this helps you!
Sep 18, 2011 | Bulova Watches
Lost winder to harley davidson
mcdevito75 here, If you mean the crown, look for a small watch repair shop in your area for a new winder (crown).
Jul 20, 2010 | Bulova Watches
I have a Bulova Mantel clock that is chimming off the hour how do I reset it?
I have a B1987 bulova baradwell mantel clock that is chiming off I can't find my instructions book. please help me to fix this problem thanks
Aug 02, 2009 | Bulova Watches
Bulova Harley Davidson 100th Anniversary , Limited Edition, Only 2,003 Made, No Longer In Production, Rare, 97905 2V Watch for Men Logo
43 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
