Question about Hayward 116k BTU HeatPro Digital Heat Pump HP21003T
I have a Hayward heat pump, S3 Sum Heat Silent System, and the screen shows F5 or FS. Can you tell me what this code means? Thank you, Lilo Klemme
5 Suggested Answers
  • 3 Answers
SOURCE: I'm looking for the owners
if you go to haywards web site you can down load their manuals.
Posted on Jan 19, 2009
thepool
  • 78 Answers
SOURCE: Heat pump will not start
Could be a firmware issue and require a new mother board. Unfortunately, you probably have done all you can on your own. Time to call the local HVAC service person...
Posted on Apr 22, 2010
thepool
  • 78 Answers
SOURCE: Hayward HeatPro Heat Pump for pool won't turn on
Power to the unit but not the display + mice = bad board probably. Service call required...
thepatioman
  • 52 Answers
SOURCE: Can you please tell me the correct wiring for a
Follow diagram on the tag. typically low voltage and high voltage volt are diagramed on the tag. Most manufactures send pumps out already for 220. the A and B terminals are for pump wires. and the lines are for the power cord. follow the diagram and you can't go wrong;
The Pool Tech
Posted on Jul 14, 2010
Swimrite pool heatpump not heating pool
heat pumps do not heat as fast or effectively as a direct heat system such as propane or ng. they are only effective when the outside air is very warm otherwise they will actually cool the pool water.
Jun 11, 2014 | Hayward Pool & Spa
What does the LP code mean?
low pressure ,MEAN low water pressure going to the unit or low pressure refrigerant is heat pump correct ?
Jun 09, 2013 | Hayward Pool Products Hayward Heat Pro -...
I have a Aqua Pro heat pump P130 with error code F5 does anyone know what that means
Error FS?
Unit has started defrost cycle and will reverse operation in 5 minutes.
If coolant has nor res=ached desired temp, unit will shut down and display FS
Other models:
FS can mean not enough water flow in cooling mode.
Mar 25, 2013 | Aqua Pro Swimming Pool Heat Pump 125000...
Heater has power but flashes code L.P
• The low-pressure switch senses the refrigerant pressure in the sealed refrigeration system to protect
against certain conditions that could be detrimental to compressor life. The switch turns the heat
pump off in the event of loss of refrigerant, fan motor failure, evaporator freeze-up, or airflow
blockage. The heat pump will automatically reset the switch after the system pressure rises to the
normal operating pressure. The display will show "LP", if this switch is tripped.
For more info, look at page 7 on this manual:
http://www.hayward-pool.com/pdf/manuals/Manual280.pdf
Either you need to defrost the coils, clean the air-flow chamber, get a new air-flow switch or you are running low on refridgerant.
Dec 09, 2010 | Hayward Pool & Spa
LP (low pressure fault) is on screen.
This could be something as simple as a dirty filter. Heat pumps are notoris for pressure problems as they are very fickel. Make sure your filters are clean, then their should be a by-pass assembly on your inlet, outlet pipes for water this valve needs to be set at just the right spot to keep the water flow high enough to collect heat but not so high as to not warm enough. Setting this flow is easy enough with the unit on restrict the flow till the unit starts and wait to see that it keeps running. use a gentel hand and do this very slowley as the unit takes time to respond. But first make sure your filters are very clean and your baskets also. These are usually the culpret's when it comes to low pressure and low flow. The switch usually just tell's you that is where the problem is. If their is no corrosition or leaking at the pre. sw. more often than not it's ok and just tell's you to start looking for the problem. Good luck.
May 30, 2009 | Water Warehouse Hayward HeatPro In-ground...
May 27, 2009 | Hayward 116k BTU HeatPro Digital Heat Pump...
Hayward pool heater - p5 code
The code is "PS" for Pressure Switch and means there is insufficient pressure to operate (low flow) or the switch itself is bad.
May 26, 2009 | Hayward 116k HeatPro Heat Pump HP3100
Low pressure is usually a dirty filter ob basket. If you have a by-pass on the plumbing you can shut this down a little to get more flow through the heater. Or you may have a clog in your pump impeller. Hope this helps.
Mar 12, 2009 | Water Warehouse Hayward HeatPro In-ground...
Hayward 116k BTU HeatPro Digital Heat Pump HP21003T Logo
140 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
