Question about Kitchen Ranges
Kenmore 911.7137911 Gas Kitchen Range The oven is not working at all. I tried installing a new igniter but still not woking I don't think their is any power going to the igniter or gas valve. But I do have Power at the oven controller on top of stove. Hope you can help, Glenn
  • 3 more comments
  • scrubdog May 22, 2011
    I have gas to the top Burners and they work fine all four of them. So I know I'm getting gas to the stove. I have 110v power to the back of the stove where the cover is that houses the back of the oven light and wires that go to the bottom of the oven. What about the Clock & timer would that have anything to do with the igniter not working ?
  • scrubdog May 23, 2011
    Kenmore 911.7137911 Gas Kitchen Range The oven is not working at all. I tried installing a new igniter but still not woking I don't think their is any power going to the igniter or gas valve. But I do have 110 volts at the oven controller on top of stove. Hope you can help, Glenn
    Hi arjuun,
    Thanks for getting back to me so fast. The Glow Bar igniter is not Glowing. I do have a meter and I checked the thermosta and have 110 volts going in and coming out when tuned on. But I don't seem to have that at the Glow Bar. I will check the continuity of the units and get back to you. The only thing is that the stove is at my summer home so i will check it this weekend coming up.
    Thank you so much.
    Glenn
    P.S. Will the Clock & timer have any em-pack on the stove to turn on or is it just a timer that makes alot of noise.
    Thank you for your help. I will try that this weekend.
    Thanks again
    Glenn
  • scrubdog Jun 04, 2011
    Sorry it took so long to get back to you. Everything is working fine now.
    Glenn
  • 1,170 Answers
You did not indicate if your see the glow bar igniter glowing red or not. Open the broiler drawer and turn the oven on and watch to see if you find the glow bar igniter glowing or not. If you find it glowing but the burner never ignites, replace the igniter. If the glow bar igniter does not glow, then the failure could be one of the following: Broken or burnt out igniter (part #WB13K21) Failed safety gas valve Oven thermostat Loose or broken wire in the ignition circuit.
In order to diagnose the failure if you find the oven igniter not glowing will require a multimeter. The igniter can be accessed by opening the broiler drawer or by removing the floor of the oven if it's removable. First, disconnect the power cord from the power source. The igniter will need to be disconnect and checked for continuity. If the igniter has continuity then disconnect the wires from the gas valve and check the continuity of it. If the igniter and the safety gas valve both measure continuity then the oven thermostat will need to be check for continuity when it is turned on. Remove both wires from the thermostat and check the continuity across the two terminals of the thermostat. If it has continuity then you will need to check the wire circuit between the thermostat and igniter and gas valve for an open circuit. The ignitor must have voltage supplied to it or it will not glow and allow the gas valve to open.
Thanks
Posted on May 23, 2011
  • Kitchen Ranges Master
  • 2,605 Answers
Hello, welcome to FixYa. I'm not sure if you are aware of it, but those old gas ranges (this being 1979 would certainly qualify) if inadvertently set to "auto-bake" on the clock timer will not work...unless it happens to be the exact time the "auto-bake" is set to.
Turn the dial on the timer/clock which indicates "auto-bake" to manual or off and give that a try. If the ignitor isn't even getting voltage it must be in the clock.
I don't have access to a diagram of your range, but it certainly sounds like it is timer related based on your post..."I do have Power at the oven controller on top of stove"...yet no power to the ignitor.
Let me know what you find and I hope that helps. I'll watch for a reply and help in any manner I can going forward of course.Good luck.
Regards,
Macmarkus :)
  • Mark MacDonald
    Mark MacDonald May 23, 2011
    O.K. sounds good Glen.
    I will watch for your reply or progress report should you need any further assistance let me know.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Mark MacDonald Jun 04, 2011
    Hello again Glen,
    Thanks for replying, the time table is of no consequence so no need to apologize. Out of curiosity though, what ended up being the solution to the non-ignition problem ?
    I just like to follow up on any prior post of course for future reference, if it was the clock/timer for example (or whatever it was) that is good info to refer to if need be for similar models and problems.
    Thanks again for choosing FixYa for your inquiry. Good luck going forward.
    Regards,
    Macmarkus :)
  • 1,238 Answers
Good day!
Try to check the connection of regulator going to the stove.
When you already replaced the new igniter and not working so it means that there's no power/gas going to the stove.
Please check the following:
  1. the tank-if have a gas.
  2. the regulator--if the gas is pass through.
  3. check the proper connection of the hose.
  4. the gas stove and barner.
Thank you.
Posted on May 22, 2011
  • bonifacio gomez
    bonifacio gomez May 23, 2011
    if you replaced igniter before,please double check the connection of it.
  • bonifacio gomez
Oven range will not light. glow plug seems to be working
You need a new glo-plug. They still glow when they go bad but not enough to ignite the burner. It's a fairly easy DIY project.
May 28, 2012 | Kenmore 70102 Gas Kitchen Range
I have a 79012-19 gas range and when I turn on the regular oven or convection oven you immediately start to smell gas and then it never gets to the proper temperature. It has been taking a long time to...
You more than likely have a bad ignitor...and if you are getting a l;oud boom the you should also consider replacing the gas valve for the oven it should not be letting gas out until the ignition is hot.
Jul 19, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I have a Hotpoint gas range that has electric ignition for the oven. However, I don't have electric at my cabin. Is there a conversion kit for a straight pilot ignition available? The model number is...
Most gas ranges with electronic ignition aren't equipped to have a straight pilot ignition.
I'm don't even think they make conversion kit because of the routing of the gas tubing for the pilot source.
Usually you have to turn the gas knob way over to get the "click-click-click" of the igniter.
Its just as easy to turn on the gas and light with a match...or a long butane lighter.
Even a "striker" used in welding will provide a source of ignition.
A last ditch effort would be to get a replacement gas grill igniter...all ya gotta do is place the bottom of igniter on metal surface and press red button. (kinda works like a spark plug) and no A/C needed.
Hope this helps some.
Jul 18, 2011 | Hotpoint RGB745 Gas Kitchen Range
Kenmore gas range model # 970-331513 oven will not light, no such model number on their webpage. The burners light but not the oven. The igniter glows, there is no smell of gas. Range is new to us. Also,...
I cannot find the model number either, however, if you look on the enclosure into which the control board fits, there will be a label with a number beginning with 316 or 318. If you provide me with that number I will try to help you. I am familiar with these as I work for a company that repairs failed timers.
Mar 30, 2011 | Kenmore 71071 Gas Kitchen Range
I have a Kenmore gas range . The oven won't ignite. The ignitor gets hot , but it acts like there is no gas
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 01, 2010 | Kenmore 45702 / 45704 / 45709 Dual Fuel...
I have a kenmore range the oven burner does not work but the broiler does. The igniter on the oven element appears to glow in preparation of lighting but propane does not come out of the element. Now when...
heatman101
sgf
Nov 16, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore elite range oven problems
hi. thanks for the question . i would replace the igniter in oven .thanks the appliance doc
Sep 26, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore Gas Range/Freestanding/ Electronic Ignition
I have an electronic ignition Kenmore Gas Range. The Model Number is 790.78573407.
Am getting the error code F93 in the oven control panel. The manual says the likely cause is "Maximum oven door lock time exceeded". When I plug the oven the "door lock light" flashes and then the "F93" error code flashes. Am not able to use the bake or broil.
Aug 31, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Kitchen Ranges Logo
113 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
