Question about LG Washing Machines
I have a lg wm-11220fd. it has hot and cold pipes at the back. ive recently moved and the plumbing in place has only a cold pipe feed for washing machine. can i use the machine using a 'y' hose connector instead and will the machine heat the water instead ?
DISCO KID
SOURCE: washing machine
HOT WATER VALVE IS FAULTY
Posted on Apr 21, 2007
sdanville
  • 5 Answers
SOURCE: Water overflowing from drain pipe
I had a stubborn clogged drain pipe. It took 4 times with a 3/8 " power snake until I stopped getting calls from the tenants. The chemicals I bought were no use.
Posted on Nov 10, 2007
skotkolr
  • 558 Answers
SOURCE: Cold water Washes
It is normal for the machine to cycle between hot and cold water when filling even if selecting a cold cycle. The reason for this is because even a cold cycle requires the water temperature to be 78F for the soap to break up efficiently.
During the cold months the water in your pipes is probably less than 78F so the machine will need to add some hot water to bring it up to this temperature. Basically, it is adding cold and then hot water to maintain a temperature in the tub of 78F for cold water cycles.
Hope this helps, please rate my solution.
Posted on Apr 07, 2009
blueextc3221
  • 15935 Answers
SOURCE: Washing machine drain hose/pipe leak
Make the standpipe longer (the black pipe).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 13, 2010
  • 196 Answers
SOURCE: I have been given a
You will need to use a Y-piece on the cold water valve, any hardware store will have them
  • 9k=
Then simply run 2 hoses to the machine from the 1 valve.
Posted on Mar 14, 2011
Hot water not coming into washing machine
The solenoid valve that lets hot water into unit is not opening. Check out the valve itself and the timer cam that feeds power to the cam.
Jul 04, 2015 | Maytag Washing Machines
Only hot water is coming . cold water none
Ensure the hose's at the back are in the right places, Could be you or the fitters has put them in the wrong place.
Feb 20, 2012 | Kenmore Washing Machines
Have been given Hoover HC6-110 (fitted with hot
This machine does not have a heater. You could use a Y connector or just cap off the hot and only use the cold settings.
Feb 24, 2010 | Hoover HC6 110M Front Load Washer
When my top load washer is first filling with water, our pipes sound like they are clanging - is something not hooked up correctly?
NO IT SOUNDS LIKE A PLUMBING PROBLEM CALLED PIPE KNOCK THE MACHINE TAKES IN WATER FROM THE MAINS WHICH CAUSES THE PIPE TO MOVE TIE DOWN WHERE THE PIPE IS MOVING AND FIT A CLAMP
Dec 23, 2009 | Washing Machines
Why is my warm water is cold? The hot is hot and cold is cold but warm is cold.
There is too much pressure on the cold feed, reduce the pressure on the cold by partly closing off the tap on the cold.
Or ensure the hot feed is fully open and not blocked, check if there are filters inline - remove the feed pipes at the washer end and look into the inlet valves - clear if blocked.
The inlet valve is common to hot and cold water with only a small pipe to fill the machine, the cold water is being forced back up the hot water pipe due to the pressure you can feel the pipe cool down after running hot then go to warm, if hot water is flowing the pipe will stay hot, if not then cold is going up the hot pipe.
Jun 28, 2009 | Admiral AW22 Top Load Washer
Never Runs Cold Water LG Model WM0532HW
When set to Cold it Fills Hot ?
What does it rinse with ?
Have you had the fill pipes off the back for some reason and put them back wrong or has a plumber been messing with the supplies
If the machine is told to fill cold it should, it should also use cold water to rinse with.
What hapens if you tell it to fill Hot only
Jun 13, 2009 | LG WM-1832C Front Load Washer
Cold water Washes
Apr 07, 2009 | LG WM-1832C Front Load Washer
Hot water goes into cold water washes
Jan 12, 2009 | LG WM-1832C Front Load Washer
Plumbing
it depends if you have the connections already there. If not then you can make a tee branch from the hot and cold pipes running to your kitchen sink. Then solder 2 15mm branch pipes. this will now be your hot and cold feeds to your machine. At the end of the branches attatch a washing machine valve (red for hot, blue for cold. You can now attach the hoses from the machine to the valves you have just fitted. Really easy
Sep 15, 2008 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
35 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
