Question about Toys
Have bought a new tire/wheel for the Wolf Feber Explorer Electrical Car- how do I change it? Need instructions please as they did not come with the wheel Thanks
3 Suggested Answers
SOURCE: Feber Exlorer Jeep Wheel Replacement
Call the Feber customer helpline on 0844 5610008. They quoted me a price of £30.54 inc P&p from Spain!
Posted on Sep 23, 2009
emissionwiz
  • 80444 Answers
SOURCE: I require the two rear
Hello
Here at Fixya we are a Technical advice oriented website, we offer that only and have no resources to either look up parts are any inventory to provide them. I suggest you try and find a local distributor for the product that can order what you need. I would also do a Goggle search for suppliers of small wheels, they may be able to match up what you have to a "suitable" substitute.
Posted on Jun 15, 2011
I have a rotational judder through one of the front wheels i believe. I can feel it through the steering wheel also and sometimes the steering wheel moves slightly by itself. when speed increases so does...
Jack up the front of the car and spin the wheels by hand. Try to look for a point behind the wheel and see how the tire runs, if you see it go up and down, you have deformed tires and you will have to change them. Also look at the inside of the tire for hernias (lumps) on the side wall of tire, if so, change the front tires. Do this check on the rear tires also. Have a nice day!
Dec 14, 2010 | 1997 Ford Explorer AWD
I just bought an2003 ford explorer 4x4 and i have a loud humming noise coming from the front end tires are brand new it has around 190,000km please help
If the noise is only when the vehicle is moving it sounds lek you have a bad wheel bearing. You can inspect ford move ment or play shaking the tires up and down and left to right while lifted up on hoist or jack. If there is no movement doesn't necesarily mean the bearings are okay, however if there is movement in bearing replace and drive again. Antoher way to determine Which wheel bearing is bad is to drive and turn to the left, if the noise gets louder than it mens the rightside wheel bearung is bad. If you turn to the right and noise gets louder replace driver side front wheel bearing. Also Rub your hands across your tires, does it feel wavy or uneven, you could have cupped tires, I DON'T KNOW HOW NEW THEY are but cupped tires will also make this noise. One way to see if it is the tires is to do a rotate If noise changes at all then you no its a tire causing noise. Hope this helps.
Oct 19, 2010 | 2003 Ford Explorer
2000 ford exploorer v-8 awd eddie bauer edition new wheels and tires new ball joints new tierods new shocks 3 front front end alignments started having a vibration in the front end at about 70+ mph had the...
Hello, I see you may a lot of changes and replaced a lot of parts. We leased an Explorer the same Year as yours. In our case there was a slight noise as well as vibration. The problem was the Front Hub bearings, They were bad at 18000 miles.
There are a few things I want to suggest. The spinning of the wheels on the lift will not load the bearings. A Dyno table can get everything turning with a load on it. As your vehicle is a 4x4, most Dyno's were 2 wheelers. You would have to call to find one for a 4x4.
Next, if the new Hubs do not help, have a look at the rotors. They are also balanced. You can spin balance the Wheel and rotor as a unit with a floor motor. It's not the best way to Balance because tire rotation or even shifting the Wheel on the lugs will UNbalance it. But this method CAN pinpoint a problem if a Balanced tire does not spin true when bolted to the vehicle. You will know the Rotor is off-balance and which axle is causing the problem.
Would be interested to see a Post of what you found.
Jul 09, 2010 | 2000 Ford Explorer
Steering wheel shudders when turning left 03 ford explorer
when my front wheel bearing went the ABS light came on common on ford (exploders) explorer anyway check the unaversal joint on front there thould be no play at all when moving from foreword and reverse actually easyest way to do this is to jack the tire off the ground and move tire back and forth and look for any play, and last tires ? Are they warn my exploder did the same thing the only fix is 4 new same size tires I changed my wheel bearing and tires and all is good at 94K good luck CJ
May 12, 2010 | 2003 Ford Explorer
Aug 09, 2009 | Nickelodeon Toys
Feber spare parts
Feber has a help line, they will post the parts to you. Helps if you have the instruction book the part numbers are listed in them. Tel 0870 2406463
Jun 16, 2009 | Toys
I,ve just purchased a Feber Buggy Bucaneer 12v, but it came with no instruction on how to build it can you help!?
I received this information from someone who sells their product.
FEBER does not have a Service Department here in the US..
They did; but it is no longer in service.
Contact:
CUSTOMER SERVICE EMAIL (FOR PARTS) ADDRESS IS: consumidor@feber.com
They will help you with the part you need.
If you want to call - Call 6 hours ahead. Phone No.: 01134 96 555 13 08
Call in the Morning. They will speak Spanish. Say Ask for someone who speaks English
You can also try this weblink
http://www.feber.es/feberweb.nsf/AyudaIng?OpenPage
Go to the Spare Parts section and click on the weblink hotspot. You will be able to email from here.
Apr 11, 2009 | Toys
1986 Audi 5000s tire change instructions
jack car up, put on jack stand,,remove wheel studs/bolts unbolt studs,,remove old wheel replace with new wheel.
Jan 16, 2009 | 1986 Audi 5000 CS
1998 ford explorer font end
Has the car been in an accident? You may have to replace the upper ball joints as well. And you will have to get an alignment after that. I would get the tire set correctly before I started changing bearings. Of course it may be that the bearing is so bad that that is what is causing the wheel to lean so badly?
With the car jacked up, can you move the wheel laterally - it should be very tight.
Aug 08, 2008 | 1998 Ford Explorer
Toys Logo
71 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
