Question about Belkin Computers & Internet
Adapter appears to have lost the driver on my wireless connections
  • 2,961 Answers
Unplug the usb adapter, restart the pc and the plug back in, it sould then automatically install the driver or as you for the installation disc
Posted on Aug 15, 2008
I don't have my user name and password for my wireless network and need it to connect a wireless printer
If you have the CD that comes with the adapter then you can try uninstall Linksys software and install only the drivers of the adapter.
Remove the Linksys Adapter and un-install the Linksys Software from Programs menu. To re-install the Drivers insert the Linksys Setup CD into your CD-ROM drive. When the Welcome screen appears click Exit. Connect your USB adapter to the computer. When the Found new Hardware Wizard window appears, click Install the software automatically (Recommended) then click Next. Click Finish when the installation is complete.Try to connect to the wireless network again. See if that works. You can also download the latest drivers from Linksys website on any other computer. Save it on a Flash drive and transfer the drivers on your computer.
Oct 10, 2011 | Linksys 2.4 GHz 802.11b Wireless - B...
NetGear Wireless Router and NewGear WG111 Adapter
I imagine you bought the WG111 Kit. It could but throught the Router and/or the adapter. Uninstall all netgear software and drivers. Unplug the adapter. Reboot machine. Plug the adapter in and install the software drives. Basically your starting over. This will take the quess work out of trying to repair what was lost. After reinstalling go to this web page to configure the SSID,IP and adapter.
Jun 27, 2007 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Tobhiba Satellite M35-S320 - Downloaded Windows 7 - can not connect to internet - I use a wireless connection - appears I lost network adapter during download of 7
you lost your PC drivers, You must find driver for network adapter for windows7, after install it apdate you drivers for windows 7 from
May 28, 2011 | Toshiba PA3235U-3BTM Network Adapter
My toshiba laptop with a realtek rtl8187b wireless 802.11b/g usb 2.0 network adapter, is connected to a wifi network with internet, but periodically the connection is lost (connected and automatically...
This is not a problem. Wireless connections sometimes tend to be inconsistent. Try closing the distance between your laptop and the wireless network adapter.
Mar 17, 2011 | Toshiba Realtek RTL8187B Wireless...
Cant access wireless network
Wireless zero configuration is the feature of Windows XP that allows Windows to detect the available wireless networks and automatically connect to the most preferred wireless network.
It is enabled by the Wireless Zero Configuration service in Windows XP. It provides auto wireless network detection when you switch on the computer.
Follow the steps below to verify that the service is running:
1. Go to Start and right click My Computer. Select and click Manage.
2. Computer Management window will appear. Under Services and Applications, select Services.
3. Check for the service Wireless Zero Configuration. Make sure that it is started and that the startup type is set to automatic.
computer-management.jpg4. If it isn't, double-click the service. If the startup type is not set to automatic, click on the dropdown arrow and and change it to automatic. Click OK at last.
autostart-wireless-zero.jpgIf your wireless adapter driver does not support wireless auto onfiguration, you will notice the following:
- The network adapter does not appear as a wireless network adapter in Network Connections. It appears as a LAN adapter, similar to an Ethernet connection.
- The properties of the wireless connection do not have a Wireless Networks tab.
- You do not receive a Windows XP notification bar message indicating that wireless networks are available.
To get the most out of your Windows XP wireless experience, you should contact wireless adapter manufacturer to obtain the latest version of the drivers that support this XP feature.
If not, you must manually configure wireless network settings using the configuration software supplied with the wireless network adapter.
Dec 01, 2010 | ASUS Eee PC 4GB Notebook
The installation CD contains a driver of the adapter to run the device.If you lost the CD, you can let your computer find the driver online.
Connect your computer to the internet .Plug the USB device to your laptop. Go to device manager , look under network adapter , find Compact Wireless-G USB Network Adapter w/ SpeedBooster, right-click it, hit update driver, there will be a windows update pop-up page, so just hit search automatically.
Nov 08, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
Lost cd
Please download the drivers from the following link.
Feb 14, 2010 | D-Link Air DWL-122 802.11b Wireless...
Lost Wireless Network Adapter
check the driver status on device manager, if your wireless adapter is indicated there are not
Nov 10, 2008 | HP Compaq nx7300 Notebook
Laptop computer and wireless router problem
re-installed the driver of adapter and check the wireless zero configuration is start is start then off then on after then check and one more thing yuor firewall will be disable
Nov 18, 2007 | Computers & Internet
Need drivers
The driver you need is Realtek RTL8180 Wireless LAN (Mini-)PCI NIC. I connected my laptop with a ethernet cord and allowed windows to connect to their website and this is the driver it chose. I just downloaded it and am using it now. Good luck.
Oct 05, 2007 | Tekram (TM802B) 802.11b Wireless Adapter
Computers & Internet Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
