I repaired my convergence problem on an RCA HD52W59 a couple of years ago by soldering a jumper.I found the fix here. That's when I joined, and found many fixes since! Now, all I find are kits for sale. Is it possible to do this for a Magnavox 51M392H, and if so, where would I jump?
  • 2,098 Answers
Since you've already replaced the convergence parts of RCA DLP yourself a couple of years ago, I believe you can also do it in your Philips/Magnavox DLP tv. Since you are familiar in the symptoms of convergence problem, all you need now is the replacement kit for that section.
If I'm not mistaken your model no (51M392H) used STK392-120 as convergence chip(IC) and a usual 6.8 ohms 1 watt resistors. This convergence kit is available at the link below.
Convergence Kit
STK392-120
6.8 Ohms/1watt Resistor
Just in case the resistor installed in the unit is color coded (some has an actual resistance value on its body itself) you may click the link below to determine the color code value of the resistor.
Resistor color code chart
Prepare tools like soldering iron, disoldering pump, soldering lead, silicon compound and your ready to go...
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on May 22, 2011
I have a 4 year old RCA Model # HD52W59 HDTV that just developed a convergence problem. Besides seeing all three colors the picture bow's inward on both the top & bottom of the picture. When you...
Hi
Thanks for using FixYa. This is often caused by failed convergence ICs. I don’t think the issue is with the power supply of the unit as the sound is coming fine from the unit. It’s not a difficult job if you want to do this yourself, you should require some basic knowledge about soldering-resoldering components. To start with you’ll have to open the back of the unit and then replace the ICs (STK ICs) which are located behind the black heat sink and also check the resistors as if they are short the ICs might blow again after sometime. There are
repair kits available which includes repair instructions with the parts, if you want to do it yourself, you can buy and repair it yourself. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 18, 2010 | RCA HD52W59 HDTV Projection Television
RCA HD52W59YX35
just change the picture tube.
Dec 09, 2007 | RCA HD52W59 HDTV Projection Television
The picture just changed & the convergence is off with the picture bowing inward on top & bottom of screen & you see the image in red,blue & green. The auto convergence feature in the setup...
U have a soldering iron,solder wick or a desoldering pump,and solders?U know how to do soldering?U can fix this problems like about 20 mins.The convergence fuse part (FL231) is dead.Very common on this model of RCA tvs.U can buy this convergence fuse (FL231) at Ebay.com pretty cheap like $3+ shipping.There 3 small brown or pinkisk sqaure look like caps.The one in the middle is dead.But they're fuses located right side of the Flyback transformer,call a FBT(a big black block of transformer).Resolders the FBT too.
How do i fix a rca HD52w59 =, when it bow's and has a 3D picture? please help, thanks
Ur convergence are dead.U must know how to solders?Must replaced 2 STK convergence ICS and some or all it resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost $300 for parts and labors.
Mar 23, 2010 | Televison & Video
I got a 52 in rca hdtv projection tv and it went all 3d looking. is it able 2 be fixed or were they recaled i only have had it 2 yrs. this christmas would have been3 yrs
Ur convergence it dead,know how to solders?Buy a convergence kit to repair.These websites have the kit.Tv repair World.com,Tv repair kits.
Dec 12, 2009 | RCA HD52W59 HDTV Projection Television
I AM HAVING A PROBLEM WITH MY RCA ITS SHOWING MULTI COLORS HOW DO I FIX.
Ur convergence it dead.U know how to solders?Tries these websites for a convergence kit,use what in that kit.Tv repair World.com,Tv repair Kits.
Nov 08, 2009 | RCA HD52W59 HDTV Projection Television
I have a 52inch rca projectin tv model hd52w59 i
Ur convergence it dead,U know how to solder?Buy a covergence kit,replace what in that kit.Tries these Websites,Tv Repair World.com,Ebay.com.
Sep 30, 2009 | RCA Televison & Video
RCA HD52W59 Wavy lines
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Dec 28, 2007 | RCA HD52W59 HDTV Projection Television
RCA HDTV blurry
this indications that you have a problem with convergence. first try to go into customer menu...setup....convergence. and see if the convergence will adjust.. if it wont then you have a problem with the convergence cuircit boards.
Oct 05, 2007 | RCA HD52W59 HDTV Projection Television
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
