Question about Cell Phones
Charger problem how to identify - Cell Phones
    New Friend:
    Problem Solver:
  • 7 Answers
You just need a QC 2.0.
https://www.amazon.com/dp/B01J5BO0RS
Posted on Dec 03, 2016
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Cell Phones Master
  • 1,001 Answers
Chornic USB quick charge 2.0 charger,you can get 75% power from empty in 30 minutes. It also charges your non-QC2.0 devices at up to 2.4 amps.ideal for travel use. Chornic Quick Charger 2 0 2port QC2 0 4port USB Charger 5V 9V 12V 60W USB...
Posted on Nov 28, 2016
    New Friend:
You will also need butter and rub it vilantly on your nipples this will make your charger tell you what is wronge
Posted on Mar 28, 2013
    Novelist:
  • 139 Answers
Hi, to identify charger. You will need to test another charger on the cell phone and test that same charger on another phone to confirm if the charger is working.
Also after testing for the charger and and if the charger works, that means the charging port of the phone where the charger is been inserted is damaged.
It will need to be fixed.contact you local repair person for help.
Take care.
Posted on May 22, 2011
Don't have charger, need to know what kind it is. all I can see is VGA Z00M MAX on the top
Travis
Remove the battery and battery door and look at the site label under the battery. You'll find the MEID or IMEI. Then you can go to Check your ESN IMEI MEID free and instantly with Swappa to identify the model. Then you can identify if you need a micro SD or MiniSd charger.
Mark
Motorola Support
Apr 19, 2015 | Motorola Cell Phones
Can you identify the problem?
Can you explain the problem? Other than being dropped.
May 19, 2013 | Acer Aspire Computers & Internet
Hiya, does anyone know where i can get a charger for a R M z91fr laptop ??
If you can identify what the battery / laptop power requirements are, then you can buy replacement 'universal' laptop power supply / charger units which come with a selection of different standard connectors to plug the charger into the laptop.
Amazon sell a Sumvision Universal Laptop AC Charger Adapter which is available in different power output wattages (95V 120W). - you just need to select the correct DC output voltage by a switch selector and the correct connector for your laptop.
Jan 01, 2012 | Computers & Internet
What kind of charger do a t103 use
T103 timer is operated with 120Volt AC power.
Open following link to identify correct wiring and identify timer.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
Oct 06, 2011 | Intermatic T103 Indoor 120-Volt 40-amp...
Charger 06 shuts off wile driving and idiling
You need to have an OBII scan (fault scan) done. Any good shop or parts store cab do it for you and most will for free. The scan will identify codes that OnBoard computer has tracked and will identify what's troubling your car.
Apr 04, 2011 | 2006 Dodge Charger
I don't think the charger is working
This concern will require a volt/ohmn meter. If I am not mistaken, this scooter requires two 12 volt batteries wired in series. That is, the positive post of one battery connects to the negative post of the other and vice versa. This then constitutes an operational voltage of 24 volts. On most scooter chargers there are 3 pins that plug into the scooter to charge the batteries. On mine, the pin in the center pin is "ground". However, it is easily identified by setting the voltmeter to ohmns reading (a horseshoe shaped symbol) and doing what ever dissassembly is necessary to reach the scooter side wiring then touch one lead of the meter to either of the negative posts and the other to the exposed wires until the meter reads 0 ohmns or very close to this. This is the charger ground. Then set the meter to read DC voltage. Disconnect the charger from the scooter. Place the black lead on the meter on the identified ground of the charger and the red lead on either of the other two leads. There should be 12 volts either location. If there is not. the charger may be the problem. If there is, the batteries could have an internal problem and any auto parts store will happily check them for you.
Good luck and good hunting. If I can be of further help my email is jimwntrs@hotmail.com
Oct 25, 2010 | Golden Technologies Buzz Around 3 Wheel...
InvaMed Sovereign Mobility Scooter Model S888NR battery charger red light flashing to indicate fault. I have a multimeter and want to know how to test the charger. I need a wiring diagram and to identify...
Hi. Its easy to identify the pins out. Put the probes into the socket on the scooter to read the polarity. the two terminals on opposite sides will be the positive and negative battery supply. The pin to one side is to disable the scooter when the charger is connected. This terminal is normally connected to negative when the charger socket is in place.
Most faults like this are caused by a broken wire in the charger plug orv by a faulty connection in the scooter. Sometimes the charger socket is faulty, check for heat damage or melted plastic.
Check the battery connectors. Good luck. Neil.
May 15, 2010 | Health & Beauty
Resistor burnt up, inable to identify due to skorched bands
I have the same exact problem in a 12 volt Lincoln battery charger. Burned resistor in R5.
May 07, 2009 | Lincoln 14.4 Volt Cordless Grease Gun,...
Cell Phones Logo
338 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
