Question about Yamaha RX-V800 Receiver
RX-V800 Shutdown on Function Change
Hi, the above unit is able to be switched on and appear with the screen.
However when I press the mode function button to switch between CD, Video, Tuner etc I hear the relay click and the unit switches off. I can not get it to switch back on, but can hear the relay clicking trying to do something.
If I turn the mains off, leave it for a minute or two I can switch it back on, but still have the problem above.
It was working great one day, then the next this problem.
Any ideas on what I can do?
I have read the other posts and I am hoping it is not the amp. Might not be worth repairing.
Regards Kevin.
  • jasonmolinar Dec 08, 2008
    I have a similar problem, except that my V800 goes into protection mode after 3 seconds. In diagnostics it says DC PRT :023, which i take it to mean that the 5V supply is off by 23% (according to the diagnostics manual).
    Thanks to Serafis' post above, i traced on the schematics where i can find the +5V and -5V are generated and rectified (Power Schematic E-68/J-64 Power 4 and Power 6). I will check those voltages. But Serafis is saying i need to replace the blown out transistors too in the amp stage which i think is Main Schematic Main 1 E-67 / J-63), but there are dozens and dozens of transistors in that schematic. Am i to check them all!?
    Can anyone help me narrow down what i need to check in the power amp schematic?
    thanks
    jason
If you can get it to turn on, you can check the problem by holding down the A/B/C/D/E and Right Preset buttons (on the amp not the remote) while turning it on (pressing Standby). This enters diagnostic mode and displays a message. If it says NO PROTECT then the protection circuits have not been triggered (see below).
If it won't turn on at all, try unplugging it and leaving it for a few days to let all the capacitors discharge. You often only get "one hit", so turn iton in diagnostic mode first.
If the dignostic message says "DC PRT nnnn" then one or more amplifier output stages have DC voltage and you will need to identify which one(s) and replace the blown output transistors and any other affected components. They aren't all that expensive, but dismantling this model is a bit of a struggle! However, if it turns on and stays on until you press a button, then the amp output stages may well be OK.
In which case, it is more likely that the microprocessor is detecting a voltage or current anomaly (PS PRT :nnnn or I PROTECT).
I had the same problem and, after replacing all components on the three main power boards, the problem went away until I reassembled it all, then it suddenly started again.
I now think this is possibly a grounding problem. Many of the boards are grounded via the chassis, and after some years use a grounding /chassis screw may get loose or oxidised causing the problem.
I dismantled the amp and soldered a length of hookup wire from a grounding point on each board to a grounding point on the next, so that all of the main boards' grounds are directly connected back to the power supplies grounds. I didn't worry about the front panel boards.
Also replace the 0.047F 5.5V memory backup button capacitor near the top of the input / microporocessor main board (second board from right) as this is prone to leakage, and check / clean any leaked electrolyte from this board. Icouldn't get a 0.047F capacitor so I used a 0.1F 5.5V one.
So far (touch wood) this has worked and I am running the amp as my main receiver for a while to make sure it's fixed the problem.
Hope this helps someone.
Serafis.
Posted on Nov 16, 2008
The problem is a cold solder on the front panel. Yes replacing it does fix the issue. But just resoldering the front panel will be good. I have done 2 now and both worked. Also check and or replace C633 it is a known leaky cap. It is for memory.
Posted on Oct 13, 2009
Change the front panel board ant it will work
Posted on Nov 02, 2008
Comment faire pour r?soudre le prob?me du code E000001-0010 pour faire fonctionner ma IR5570?
Hi. you need to enter in service mode
in the control panel do the next key secuence:
press adittional function
press 2 and 8 at the same time once
press again adittional function.
service mode should appear in the screen: if doesn't repeat the procedure
press COPIER
Press FUNCTION
press CLEAR
In the list below select ERR and press ok in the lower corner of the touchscreen.
turn off the machine from the main switch for about a minute and restart it. try to make some copies, if problem persist there is a malfunction in the fixing unit, get technical support.
if this answer was helpfull , please rate it. thanks
Feb 17, 2018 | Canon Office Equipment & Supplies
What does e000003-0002 on canon ir c3380i,e000025-0002,e000045-0000 refers to?
Hi. That error ( 0003-0000) is related to the fixing unit. You need to clear it from service mode first.
You need to be quick doing the next process because machine will automatically turn off after a few minutes.
With the copier turned on press the next key secuence
Press adittional function
Press 2 and 8 ( at the same time )
Press additional function.
Service mode should appear in the screen . If it doesn't repeat the secuence until it does .
When service mode appears press in the touch panel COPIER
Then select FUNCTION
Then select CLEAR
then select in the lower list ERR
Then press ok in the lower corner
Turn off the machine from main Switch. Wait a few seconds and turn it on again .
Try to make some copies . If error persist there is a malfunction in the fixing heater and need to be replaced
The other error is related to the developing units
Jun 24, 2017 | Canon Office Equipment & Supplies
Ir3235 canon system code E000002-0000 Solution to fix this problem
Hi. That error is related to the fixing unit. You need to clear it from service mode first.
Then select CLEAR
Try to make some copies . If error persist there is a malfunction in the fixing heater and need to be replaced.
Mar 30, 2017 | Canon ImageRUNNER 3235 Black and White...
First i changed the fuse gear and put the fuse unit back to machine . when i turn it on the machine show the error 000005-000010 what can i do ?
hi. I assume your machine has a cleaning web. there is a sensor in the front side that detect when that Web is empty. maybe the sensor is dirty or misplaced. you have to clear that error from service mode.
press aditional function
service mode should appear in the screen m if isn't . try again until appear
in service mode select
COPIER / FUNCTION /CLEAR / ERR and press OK
disconnect the machine from the ac outlet for 5 seconds .
turn on the machine and make some print / copies tests
Feb 27, 2016 | Canon Office Equipment & Supplies
Fixing unit error e000 0000
Its been a while since I worked on it but that means fixing unit is bad.
Apr 29, 2014 | Canon imageRUNNER 3300 All-In-One Laser...
Copier Canon iR3300 error E000003-0000. How can I reset the copier if the monitor shows the error and it is not otherwise operable. I turned the main switch off and on to no avail. Can anybody help?...
Hi you need to enter in service mode first
in the control panel press the next secuence:
service mode should appear in the screen. if don't repeat the procedure until it does
in service mode press
COPIER, then FUNCTION, then CLEAR
turn off the machine from the main switch for about a minute.
restart the machine and try to make some copies, if problem persist there is a malfunction in the fixing unit. get technical support. i hope this can help you
Oct 26, 2012 | Canon imageRUNNER 3300 All-In-One Laser...
As soon as I power on My Dell D610 in boot screen appear : '' MANUFACTURING MODE: LEVEL '67''' ''PRESS FN + X TO RETURN THE SYSTEM TO NORMAL MODE'. This does not appear to work, it then shows hit F1 for...
''PRESS FN + X TO RETURN THE SYSTEM TO NORMAL MODE'. This does not appear to work, it then shows hit F1 for shutdown, nothing happening with that operation either.
Jan 19, 2010 | Dell Latitude D610 Notebook
Constant RX mode on Cobra Microtalk Walke Talke
I have the same walkie talkies and on mine I can hold down the mode/lock button and it will come off of the Rx mode. Also, you should be able to press the talk button and it will come off of the Rx mode.
Jul 06, 2008 | Cobra PR4100-2WXVP 2-Way Radio
Yamaha RX V800 w/ iTunes Airport Express
thats cause your patch cable is mono get a stereo 3 ring connector.
Apr 01, 2008 | Yamaha RX-V800 Receiver
Yamaha RX-V800 Receiver Logo
355 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
